It is currently Thu Mar 23, 2017 5:53 pm
Post new topic  Reply to topic  [ 488 posts ]  Go to page Previous 18 9 10 11 1233 Next
PostPosted: Tue Jan 14, 2014 3:32 am
How much spacers do you run with the Time?
My Bikes
My Photoblog
PostPosted: Thu Jan 16, 2014 5:11 am
None. Stem is slammed!
 Post subject: BH G6 Sizing Help
PostPosted: Thu Jan 16, 2014 6:01 am
My apologies if this is a topic that has been discussed before, but I've googled every possible incarnation of my question and have yet to find a definitive answer.
I have an opportunity to buy a 56 cm (MED) BH G6, full Sram Red, 2013 at an absolute steal.
Wondering if anyone has ever had any experiences with the G5 (same geo) or the G6? OR any other BH frames for that matter?
I'm 181 cm (5'11 ish), 170 lbs, and usually ride a 56 cm on all my bikes. I currently own a 56 CAAD 10, and rode a foil last year. I know stack and reach are quite a bit different on a 56 foil vs a 56 BH, but I sat on the BH, and although it felt great, it does LOOK smaller than my foil and my CAAD.
Anyway, if ANYONE could potentially give me a heads up to what they have, it would be greatly appreciated. FWIW, I have a 33" inseam, and am mostly torso.
Thanks again!
PostPosted: Thu Jan 16, 2014 1:05 pm
I looked up the geometries for both, made some assumptions (such as the head tube angle for the Colnago which is not listed, and fork lengths/rake and BB drop being the same for both frames) and looks like a traditional size 52 C59 will give a very similar fit to your Time ZXRS XS if you use a 110mm stem (makes the reach about 5mm longer than your time) or a 100mm stem (makes te reach about 5 mm shorter compared to your Time), and 8 to 10mm of spacers under the stem (assuming 5mm tall headset cap for both).
Looks like a 48s (sloping) would have pretty much the same effect also (except the head tube is a couple mm taller so you could use less spacers).
My Bikes
My Photoblog
PostPosted: Thu Jan 16, 2014 2:55 pm
Thanks for the reply and work. That is pretty close to what I had figured from just eye balling it online. Needing the spacer for the Colnago would be fantastic as I could use the front end being lower, but currently can't as I am limited by the head tube size in the Time. The front end sits higher than my Look 595, but because the reach is longer on the Time it sort of compensates a tiny bit having me more "stretched out".
:beerchug: :beerchug:
PostPosted: Mon Jan 20, 2014 6:21 pm
Looking at a new frame and trying to determine sizing. My current bike has a external headset with about 25mm in spacers and a 100mm stem. I would like to replicate this fit.
Below is my current geo along with 2 options for the new frame
Current Bike:
Head Tube Angle:71.5
Seat Tube Angle: 74.2
Top Tube: 530 mm
Head Tube Length:125 mm
Stack: 540.0 mm
Reach: 377.2 mm
New Bike:
Small
Head Tube Angle:72
Seat Tube Angle: 74
Top Tube: 520 mm
Head Tube Length:120 mm
Stack: 53.51
Reach: 36.57
Medium:
Head Tube Angle:72
Seat Tube Angle: 74
Top Tube: 530 mm
Head Tube Length:135 mm
Stack:54.86
Reach: 36.62
PostPosted: Mon Jan 20, 2014 7:14 pm
They both pretty much seem the same thing and near identical fit between the S and M. Get the M to loose a few spacers, and a 10mm or so taller stem.
The Shivenge
PostPosted: Mon Jan 20, 2014 7:51 pm
I also vote M.
PostPosted: Mon Jan 20, 2014 8:25 pm
If the new model you're looking at has an integrated HS you're going to need a lot more stack than those options you've shown. Headset height likely 25-30mm which means a lot of spacers even on the M shown above
http://www.speedtheory.co.nz
http://www.velogicfit.com - 3D Motion Capture and Frame Finder Software
PostPosted: Mon Jan 20, 2014 8:26 pm
It does not have a integrated HS. I plan to run a Chris King which adds some nice height
PostPosted: Tue Jan 21, 2014 5:37 pm
Old bike:
Seat angle: 73.5
ETT: 53.5
Stack: 530
Reach: 378
Stem: 90mm
head tube: 133 + 10mm spacers
New bike:
Seat angle: 74.5
ETT: 51.1
Stack: 52.4
Reach: 366
Stem: 110mm
head tube: 132 no spacers
Am I in the same position as I was before or does the new bike look longer? How much does a degree differ in terms on the seat angle?
I feel that the new bike feels longer BUT I think it's because my position has gone lower on the headtube , but I'll let you guys decide on the geometry first.
PostPosted: Thu Jan 23, 2014 7:42 am
g32ecs wrote:
Old bike:
Seat angle: 73.5
ETT: 53.5
Stack: 530
Reach: 378
Stem: 90mm
New bike:
Seat angle: 74.5
ETT: 51.1
Stack: 52.4
Reach: 366
Stem: 110mm
provided you position your saddle in the same spot in relation to the bottom bracket the seat tube angle does not matter
simply adding reach and stem lenght you'll find that your overall reach increases by a little less than 1 cm (again, proviced the saddle is in the same spot)
 Post subject: Canyon Aeroroad CF?
PostPosted: Sun Feb 09, 2014 6:26 pm
Hi,
I am looking at getting a Canyon Aeroad CF in a size medium and I have some questions for owners/dealers.
1.) My saddle height is 73.2- will that look funny on the medium? Headtube length on size small is way too small.
2.) On bikecad it shows that I would need the 16mm topcap and 7mm of spacers to get exact height.
Do spacers look funny on top af that Acros topcap? Are their other options?
3.) What is the actual length of the seat collar above the toptube on the medium Aeroad CF? I know that the entire center to top measurement if 531mm. In picure collar looks to be about 2cm?
4.) also wondering if the Aeroad CF fits fat wheels- Specifically Zipp 303 Firecrest? or is it tight?
5.) Lastly wondering about cable routing. I guess you have to choose mecahinal or electronic- is it convertible in both directions? Or one or the other?
Anyone have pics of a setup that would be similar to what I would have?
Feedback and pics appreciated!
 Post subject: Re: Canyon Aeroroad CF?
PostPosted: Sun Feb 09, 2014 9:36 pm
Sometimes you can fall in love with a frame but the geometry can be unsuitable for your needs. If you and the type of cycling you do is more suited to endurance-type frames - these typically have shorter reach and increased stack - then there might be other frames out there that you are more suited to.
PostPosted: Sun Feb 09, 2014 11:09 pm
Endurance frames have too much stack and not enough reach.
There are no new unread posts for this topic. Attachment(s) new Bike size and fit questions
RQBL2016
Tue Jun 28, 2016 7:57 pm
Allen254 View the latest post
There are no new unread posts for this topic. Attachment(s) Bike fitting on Colnago v1-r
pdiomidis
41
2586
Wed Dec 28, 2016 5:21 pm
Fiery View the latest post
There are no new unread posts for this topic. bike fitting and suggestions help
bigpab
Sun Jan 22, 2017 11:40 pm
mpulsiv View the latest post
There are no new unread posts for this topic. Frame questions + best frame you ever rode
[ Go to page: 1 2 3 4 5 ]
iliedanila
69
9330
Sun Jul 17, 2016 5:01 pm
jerrybrabus View the latest post
There are no new unread posts for this topic. buying an ebay frame from Canada...questions
chiltonp
Wed Jun 08, 2016 10:39 pm
BRM View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], cyclespeed, dak, darnellrm, djcharlou, oldnslow2, TiCass, Yahoo [Bot] and 34 guests
