It is currently Tue Mar 28, 2017 1:35 am
Post new topic  Reply to topic  [ 4 posts ]
PostPosted: Sun Mar 24, 2013 4:18 am
Does anyone know if you can take the white logos off an Extralite stem? I know the logos are laser etched so I am wondering if there is a way to stealth out the stem.
PostPosted: Sun Mar 24, 2013 4:27 am
Ok; I did a search and people talk about possibly anodizing the piece to "ghost" out the logos on other laser etched products. Is this the only way? Has anyone done this so I could see a before and after shot? And last one - if this is the only way and does work does anyone know of a shop that can do this and has experience doing it?
PostPosted: Sun Mar 24, 2013 4:31 am
Yes, that is the only way.
If you want to, have the piece sandblasted first - that will remove the laser etching a bit (and, technically make it a weeee bit lighter) (and, technically, make the aluminium thinner on an already heavily milled piece) (but it should be o.k.). The sandblasting will reduce the liklihood of the ghosting effect. No sandblasting, just straight ano, will leave a ghost.
It isn't that complicated: look up 'anodizing services' in your area. Or "sandblasting services" or "Metal finishing services" as some shops can offer both sandblasting and anodizing (and other options) in the same shop.
If you're set on black, might as well go with Hard Type III - it will be able to withstand outdoor environments better.
PostPosted: Sun Mar 24, 2013 5:15 am
This may not be the perfect solution, but firearm people have been using special blue pens to cover scratches on their rifles. Not sure how close a match blue (not the color) pens are to black another but may be worth a try. Check midwayusa.
Current Stable:
The Snob Machine
The Ex's:
Litespeed Siena: 6.21kg | Parlee Z5 SLi: 5.9kg | Litespeed Xicon: 5.76kg | Colnago C59: 5.7kg | Cervelo R5ca: 5.09kg | Fuji Altamira SE - 6.2kg | Scott Foil - 6.2kg
There are no new unread posts for this topic. Old Orbea Logo
rossjm11
Fri Apr 01, 2016 7:21 pm
sungod View the latest post
There are no new unread posts for this topic. eTap Quarq removable logo?
stripes
Wed Jul 06, 2016 6:10 am
stripes View the latest post
There are no new unread posts for this topic. This logo sucks - give me ideas please!\
McGilli
Mon Aug 15, 2016 7:23 am
kevosinn View the latest post
There are no new unread posts for this topic. removing logo from chain ring
Timujin
Fri Mar 10, 2017 8:23 am
marynoland View the latest post
There are no new unread posts for this topic. Bontrager xxx bottle cage logo removal anyone?
burglarboycie
Fri Apr 08, 2016 3:57 pm
nickf View the latest post
Users browsing this forum: FLtrooper, Google Adsense [Bot], HFGent, jch3n, KWalker, PaulDunn, Samklee15, silvalis and 13 guests
