Crank ring size help needed
Notstrong
by Notstrong
How can I tell what size my crankset rings are the outer one says 53-A and the inner ring says 42-A does that mean they are a 53/42 ??
koulis1984
by koulis1984
Yes it does
Sent from my GT-N7000 using Tapatalk 2
Current : Look 675 Light 2015 / Brompton S3 / Dahon Vitesse D7HG / SBC Allez Steel 2010
Previous : SBC Hardrock 2009 / Giant TCR Composite / SBC Tricross 2011 / Scott CR1 2010 / Planet X N2A / OnOne Inbred 29er / Bianchi Eros / Scott Cr1 Pro 2012
Notstrong
by Notstrong
I have counted the teeth and they match the numbers so I assume they are
Thanks
Juanmoretime
Administrator
by Juanmoretime
To add a little more they are designed to work together to shift best. A 53B and 39B are designed to work together. From what I understand the tooth profiles and shift ramps are different depending up with combination you have.
RESIDENT GRUMPY OLD MAN.
