Swissstop BXP 2013 Pads
1415chris
by 1415chris
Full set, two pairs, four pads :wink:
On the pads subject, there is noticeable difference between them and the green ones. Better modulation, stopping power seems to be better as well. Really nice pads :thumbup:
Have to wait a bit to find out how long they will last.
BdaGhisallo
by BdaGhisallo
I have been using the green Swissstops for the last few years with mavic ceramic reflex rims. They have been great. I never had to worry about toeing them in to avoid squealing. Just snugged them up flat against the rim and off I went.
I recently tried the BXPs and they squealed like hell when set up the same way as I was doing with the greens. I can't be bothered to fiddle with toe in of the pads so off the BXPs came after a few rides. It's time for me to stock up on the greens.
RJKflyer
by RJKflyer
BdaGhisallo wrote:I recently tried the BXPs and they squealed like hell when set up the same way as I was doing with the greens. I can't be bothered to fiddle with toe in of the pads so off the BXPs came after a few rides. It's time for me to stock up on the greens.
Fitted them to my Campag Chorus - which seem not to require any toe-in - and they did the same. However, it really WAS cured by toe-in immediately so don't let that put you off.
Suspect it's a combination of wearing in and alignment, as not a peep now after 400 miles.
My opinion versus the SR pads:
1. Seem less aggressive on the rims (seem to be wiping less 'metal' off of everything)
2. Outstanding under hard braking - tried on Boxhill yesterday - and the effort vs. stopping power is lower
3. And modulation is good. Slightly less 'bite' than SR pads, but a less 'wooden' feel
Barrie
by Barrie
Barrie wrote:
ProBikeKit.com have them in stock in the UK for around £20
I have just got a set but it will be a few weeks before they will be used
Barrie
Is that for one pair or two? (IE one wheel or two?)
Cheers!
That`s for the pair,
I`ve had them on now for a few weeks and I am impressed, I had a ride over Fleet Moss ( Yorkshire Dales ) and a stray sheep had me on panic stopping mode on the way down
I can thoroughly recommend them for alloy rims
Barrie
RJKflyer
by RJKflyer
FWIW< a chum has also now fitted them to replace his integrated Tiagra pad/shoes and considers them a very significant upgrade.
MileHighMark
by MileHighMark
743power wrote:The pads from those red brakes aren't available anymore. Sram switched to the greenish swissstop compound a year or so before the switch to 2013 red. Go for the r55c3 or c4 alloy compound from shimano for a great all around replacement for those. Very similar if not better.
Is the C4 what's spec'd on 9000?
http://db.tt/kzHd7NB8
GRAVELBIKE.COM - ride everything
ZeroChalk
by ZeroChalk
Can anyone comment on the rim wear of SwissStop BXPs? Does better stopping = more rim wear?
Debating on whether to use Kool Stop Salmons versus BXPs. I currently have SS Blacks.
stella-azzurra
by stella-azzurra
The pad should be wearing out not the rim.
I have the koolstop salmon and black pads for campy
http://www.bicycletires.com/pkshdd/kool ... set/pp.htm
and they work great on machined aluminum rims.
