It is currently Fri Aug 18, 2017 5:40 pm
Post new topic  Reply to topic  [ 25 posts ]  Go to page Previous 1 2
PostPosted: Fri Mar 22, 2013 2:13 pm
No way is the steerer tube flexing. Fork blades maybe. Not steerer tube.
PostPosted: Fri Mar 22, 2013 2:20 pm
Steerers can be flexy. I had a light carbon steerer on my Lefty that flexed so much that it felt like the headset was constantly loose. I switched it for a different one (also carbon) and the problem was immediately resolved.
PostPosted: Fri Mar 22, 2013 3:52 pm
@Privateer: out of curiousity, what carbon steerer did you find flexy and what did you replace it with (and find stiffer)?
Rise Bikes
Wilier Cento1SR Disc
PostPosted: Fri Mar 22, 2013 4:47 pm
The fork is stock on my Museeuw MC-2 (http://en.museeuw.com/bikes/race/mc-2). I'm not saying the "test" I did was scientific in any way. I can't imagine what kind of situation I would find myself in where the front wheel is trapped in place and I needed to twist the bars. I've also noticed bar movement when I get out of the saddle on the trainer, so something is flexing. The fork legs may be the more likely culprit. In any event, I can only report that when I perform the same "tests" on my MC-2 and my Team Carbon, there is less movement with the latter.
__________
Seven 622 SLX
Cannondale CAAD9
Merckx Premium (in progress)
Blue CXc
PostPosted: Fri Mar 22, 2013 5:33 pm
Given that the diameter of the legs is much larger than the steerer, I don't see why some people think it must be the fork legs. I once swapped a cheap Trek carbon fork with an alloy steerer for a Look full carbon fork and there was a massive difference in stiffness that I think was definitely attributable to the steerer tube change. Not that this helps you do anything about it of course, other than removing spacers and /or changing the fork.
Rise Bikes
PostPosted: Fri Mar 22, 2013 8:12 pm
Whether its the fork blades or the steerer, what does it matter? The fork itself is still flexy. It could be the headtube too, but the bottom line is that the frame or fork has to be swapped.
PostPosted: Fri Mar 22, 2013 10:58 pm
Seriously. I thought I was talking to a bunch of weight weenies. Nope, I must've missed the renaming of this website to stiff weenies.
PostPosted: Sat Mar 23, 2013 12:47 am
In the Olde Days race mechanics would drive a broomstick down the steerer tubes of bikes to be ridden in Paris-Roubaix to reduce steerer breakage.
You could expoxy an appropriate sized carbon or aluminium tube in there, as was suggested above.
PostPosted: Sat Mar 23, 2013 2:16 am
All interesting ideas, but none seem (a) worthwhile or (b) appropriately WW. I think I'll live with it and take this as a license to ditch my bulky compression plug in favor of something lightweight.
__________
Seven 622 SLX
Cannondale CAAD9
Blue CXc
PostPosted: Sat Mar 23, 2013 5:25 pm
It was a Hellore. I replaced it with a Black Cat Bone.
There are no new unread posts for this topic. Steerer tube too short?
Lightweenie
18
1521
Tue Jan 03, 2017 5:40 pm
mattr View the latest post
There are no new unread posts for this topic. steerer tube fatigue and fatality
[ Go to page: 1 2 3 4 ]
mrgray
48
3735
Fri Dec 02, 2016 4:18 pm
joec View the latest post
There are no new unread posts for this topic. show me your steerer tube ( inside )
stormur
Wed Jan 18, 2017 6:36 pm
stormur View the latest post
There are no new unread posts for this topic. Bad form to ask retailer to cut steerer tube down when ordering online?
Shrike
11
1063
Tue Jan 03, 2017 8:02 pm
RussellS View the latest post
There are no new unread posts for this topic. Parlee Altum owners- Let's Talk tire sizes
boots2000
23
1785
Mon Feb 27, 2017 10:58 pm
RichTheRoadie View the latest post
Users browsing this forum: Baidu [Spider], bilwit, brahl, corky, Majestic-12 [Bot], mmancini, nobuseri, ride1970, Stuartclark1977, Thenuge, youngs_modulus and 43 guests
