It is currently Sat Jan 20, 2018 6:26 pm
Post new topic  Reply to topic  [ 25 posts ]  Go to page 1 2 Next
PostPosted: Thu Mar 21, 2013 3:30 pm
My existing bar/stem setup is pretty stiff (Pro Vibe 7S), and the new one should be equally or more so (Thomson bars/Zipp SL stem). Where I do get some flex is in the steerer tube. I can see it when I hold the front wheel and twist the bars. Any way to stiffen that up without either (a) adding a bunch of weight, or (b) replacing the fork? The expander in there now is quite large and was intended to stiffen/strengthen the steerer. I thought about replacing it to save weight but didn't want to make the steerer even MORE flexy.
__________
Seven 622 SLX
Colnago C50 Extreme Power
Zanconato CX
PostPosted: Thu Mar 21, 2013 3:39 pm
There really isn't much that can be done about a flexy steerer without replacing the fork, I'm afraid. Much like you can't fix a floppy stem without replacing it, I think you're just out of luck.
PostPosted: Thu Mar 21, 2013 3:46 pm
But this brings up a question - who makes the longest compression plug?
I had an issue like this on a bike and finding a compression plug that went below the stem and the HS top cap helped quite a bit (albeit up top, the fork blades were noodles too. Bummer.)
PostPosted: Thu Mar 21, 2013 3:57 pm
you are imagining things.
This is weight weenies not stiffness weenies.
Fuelled by kofein
PostPosted: Thu Mar 21, 2013 4:04 pm
Yeah, I don't know how I'd feel about being a member of a website called "Stiffness Weenies"...
On topic: Are you talking about a soft compression plug or a starnut?
PostPosted: Thu Mar 21, 2013 5:59 pm
To reconnect the original question to the broader mission of the site:
Is the collective "wisdom" that changing from a burly compression plug to a lightweight one will have minimal - if any - effect on the stiffness/durability/etc. performance of my fork?
If so, it seems like a cheap & easy way to drop some grams.
__________
Seven 622 SLX
Zanconato CX
PostPosted: Thu Mar 21, 2013 6:03 pm
If you're sure that the flex is in the steerer tube and not the fork blades or the head-tube/downtube/seat-tube junction maybe you could get Mattias Hellore or someone like that to epoxy another carbon tube inside your steerer?
PostPosted: Thu Mar 21, 2013 6:04 pm
OK, but that does not necessarily translate into a flexy cockpit/steertube/headtube when you actually ride the bike. Are you actually feeling flex when you ride...noticable enough to be robbing energy from your forward momentum?
The plugs that are epoxied in to your steertube do not stiffen your steer tube, but are claimed to add a bit of internally reinforced strengthening of the steertube to protect agains ham fisted "mechanics" who over torque stem bolts.
Tell us more about the frame you are riding? How many spacers are you using below ur stem? You may also want to double check the adjustment of your headset and make sure that your bearings are properly compressed.
EM3
______________
PostPosted: Thu Mar 21, 2013 6:40 pm
I confess that I do not know if the flex is from the fork blades or steerer tube. I'm confident it is neither the wheels nor stem/bars. My basis of comparison is a very rigid fork on my winter/cross bike (Stevens Team Carbon), which just feels much more solid when I pull on the bars riding the same road wheels on the the same roads.
I run about 1cm of spacers under my stem, and there is a conical spacer that I can't recall the height of - maybe 1.5cm? By comparison, my cross/winter bike has 0 spacers and a top conical spacer of about equal height.
If there's nothing to be done, I'm not necessarily bummed. It just means I may try to pull out the compression plug and sub in a lighter one. I'm my own ham-fisted wrench, so if I stupidly over-torque a stem bolt then I deserve a cracked steerer tube.
__________
Seven 622 SLX
Zanconato CX
PostPosted: Thu Mar 21, 2013 6:43 pm
Get another frame set? :noidea:
PostPosted: Thu Mar 21, 2013 6:48 pm
Considering that the typical steerer tube on a fork is about 200mm long I don't think there's any way that beefing up the top 30mm with a thicker plug (or conversely replacing such a plug with a light one like an extralight ultrastar) can greatly affect your perceived stiffness. I highly doubt that the flex you're feeling is the top 30mm of the steerer bending while the rest stays entirely rigid; rather than the entire steerer is bending (whilst the positions supported by the headset stay still; eg if your stem is going to the right then inside the headtube the steerer is going to the left). As others have said, I think the only way you'll improve your stiffness is either to 1) change the fork; 2) get Mattias or someone to reinforce the entire length of the steerer of your existing fork (probably not cost, or weight effective); or 3) reduce your leverage by lowering the bars relative to the upper headset race (by removing the spacer and/or getting a shorter headset top cover).
Rise Bikes
Wilier Cento1SR Disc
PostPosted: Thu Mar 21, 2013 6:54 pm
what fork is it?
PostPosted: Fri Mar 22, 2013 2:49 am
Get rid of all spacers. Other than that you'll have to get a different fork.
Your test jig is also seriously flawed so the "flex" you're seeing could be almost anything, from tires to perceptual distortions from much force you feel you're applying.
PostPosted: Fri Mar 22, 2013 8:44 am
TBH, comparing a cross bike fork (designed for 1 hour race pace blasts at speed over varying surfaces, using Canti brakes) to a road bike (designed for several hours use at varying pace on moderately smooth tarmac with a crown mounted caliper) is a bit odd. I'd expect the cross fork to be significantly stiffer in most directions, especially on a bike as focused and "race ready" as Stevens Team Carbon.
PostPosted: Fri Mar 22, 2013 2:08 pm
Like another here, I believe you are seeing fork blade flex rather than steerer tube. Some forks are flexier than others. Tell us what you have.
There's sometimes a buggy.
One.
There are no new unread posts for this topic. Steerer offcut weight
SABARRAS
Thu Feb 02, 2017 12:29 am
SABARRAS View the latest post
There are no new unread posts for this topic. 0 Degree 1.25" Steerer Stems?
HugoDrax
Sun May 07, 2017 9:09 pm
HugoDrax View the latest post
There are no new unread posts for this topic. Attachment(s) Canyon aeroad steerer plug adjustment
dannyBBo
Mon Aug 07, 2017 2:21 pm
alcatraz View the latest post
There are no new unread posts for this topic. Lightest Stem with 40mm Steerer Clamp
Lelandjt
9
594
Thu Dec 07, 2017 8:44 pm
stormur View the latest post
There are no new unread posts for this topic. Attachment(s) Fork Needed - straight, carbon, 1" threaded steerer - suggestions?
dadoflam08
12
739
Wed Jul 26, 2017 11:31 am
dadoflam08 View the latest post
Users browsing this forum: BdaGhisallo, Bing [Bot], Google [Bot], jpshorts, L3X, Leviathan, photek, Rando29, taztaylortaz, Yahoo [Bot] and 41 guests
