Updating 10 speed Ultegra Di2 to 11 speed
Gazelleer
by Gazelleer
Thanks!
I am thinking about the new ST-R785 hydraulic STI's and an Ultegra RD-6770 rear derailleur for a single chainring cyclocrosser...
hubert222
by hubert222
When i ride with my friend yesterday , he is using Ult Di2 Shifters , and 11s D/A Rear Derailleur and Front Derailleur. It works fine from his experience.
The best Quality bike i had - colnago - c40, c50 , time -vxrs , bianchi, Look - 381, 585Ultra. giant- Adv SL isp
The Worst Quality bike i had - wilier Centro 1. (https://www.facebook.com/media/set/?set ... 551&type=3)
ms6073
by ms6073
hubert222 wrote:When i ride with my friend yesterday , he is using Ult Di2 Shifters , and 11s D/A Rear Derailleur and Front Derailleur. It works fine from his experience.
Which shfioters - Ult 6770 or 6870 shifters? 10-speed or 11-speed cassette? If 11-speed with 6770 shifters, it would be really nice to know how your friend got that to work?
Briscoelab
by Briscoelab
The 10 speed shifters work just fine with 11 speed everything else. Assuming you have the latest firmware.
FIJIGabe
by FIJIGabe
I believe this has been answered ad nauseum. 10-speed shifters (Ultegra 6700) will work with 11-speed derailleurs. The E-Tube system was designed to allow this. No need for special programming or fiddling. Just plug and play. The 11-speed function is controlled by the rear derailleur. All the shifter does now is send an electronic signal to the rear derailleur, telling it to shift up and down, that's it. It doesn't tell the derailleur to shift to gear 4 or 7 or 11, just "up one" or "down one" or "up X" depending on what you have programmed.
hubert222
by hubert222
hi, I think he is using Di2 6770 and 11s cassette. And he told me , it need to use the 11s cable.
Maybe i try to ask him more when i meet him next time.
ms6073
by ms6073
FIJIGabe wrote:I believe this has been answered ad nauseum. 10-speed shifters (Ultegra 6700) will work with 11-speed derailleurs. The E-Tube system was designed to allow this.
Actually it has not been definitively answered with regards to specifics of what is required. The versatility of e-tube technology is still somewhat confusing and I think those running Ultegra Di2 6770 groups are wanting to know whether they can simply upgrade derailleurs and cassette or is there more to it than that in order to run 11-speed shifting from what was originally a 10-speed Di2 group.
FIJIGabe
by FIJIGabe
ms6073 wrote:Actually it has not been definitively answered with regards to specifics of what is required. The versatility of e-tube technology is still somewhat confusing and I think those running Ultegra Di2 6770 groups are wanting to know whether they can simply upgrade derailleurs and cassette or is there more to it than that in order to run 11-speed shifting from what was originally a 10-speed Di2 group.
The original question was regaring shifters. Here's an answer, as posted on day one of the announcement:
"The 6870 and R785 groups are cross-compatible with both 10-speed 6770 components as well as the new Dura-Ace 9070 components, but [not] Dura-Ace 7870, as it does not use the E-Tube software. This means riders with 10-speed 6770 have the option to upgrade to 11-speed without having to replace their ST-6770 levers or brake calipers." - http://velonews.competitor.com/2013/07/ ... kes_292856
I understand the issue with the cableing, and that is something left to be researched, given that Shimano did upgrade the cables to make them lighter/simpler, but they also did that to the shifters as well.
nickl
by nickl
Jman wrote:
nickl wrote:What options are there for using 10 speed wheels with 11 speed Di2? Is there a magic "I'm in 10 speed mode" button so I can switch between a 10 speed & 11 speed wheelset quickly & easily?
No unfortunately there is no software option (yet) to change that. However you can use 11speed cassette and remove one cog. So spacing between cogs is correct.
Can you put the 11-speed cassette, with one less cog on a 10 speed wheel? It will fit ok?
hubert222
by hubert222
Ult Di2 , can use 10T Jockey Wheels ?thx
paulm2322
by paulm2322
Hi Folks, I just wanted to let you all know that I now have the Dura Ace 9000 crank fitted to my 10 speed drive train. 53/39 combo and it works perfect with Ultegra Di2. This is my bike http://www.evanscycles.com/products/tre ... 1#features
This set up seems to have a lot of controversy surrounding compatibility issues - on forums and my LBS. For anyone wanting to buy this great bit of kit with a similar set up to me then go for it. If people don't believe me I can post a video to youtube of the front derailleur shifting as it should.
:D
You can't 'out train' a bad diet : )
