It is currently Fri Apr 28, 2017 9:20 pm
Post new topic  Reply to topic  [ 41 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Wed Jul 24, 2013 12:23 am
paulm2322 wrote:
I do support my LBS, however if I can save £100 on an item that my LBS cannot price match, why would I waste my hard earned money?
How about supporting fellow WWers? aerozy has a DA9000 crank for sale viewtopic.php?f=5&t=117475
PostPosted: Wed Jul 24, 2013 4:10 am
TrekUk wrote:
why not support your LBS rather than these online snakes that are destroying LBS for everyone.
You do realise this forum is hosted by an online store?
PostPosted: Wed Jul 24, 2013 3:37 pm
I have just been to my LBS - who will price match. However, they have explained in layman's terms that this is not compatible with my current set up. I'm not prepared to spend £££'s on a whole new set up. I just wanted to change the front chain set to DA9000. I will have to search for a chain set that will be 10 speed/Ultegra Di2 compatible.
You can't 'out train' a bad diet : )
PostPosted: Wed Jul 24, 2013 5:09 pm
You can run a DA9000 crank with 10 speed, no problem. If they told you otherwise... they are full of it.
PostPosted: Wed Jul 24, 2013 5:52 pm
Can you back this up with evidence? I really want this crank but don't want to buy it only for it not to be compatible.
Cheers
PostPosted: Wed Jul 24, 2013 8:16 pm
I and 3 others I know are doing just that.
It's just a crankset... it will work.
Also, 10 speed cranksets will work just fine on 11 speed as well. There isn't enough of a difference in the chainring spacing to have any effect on shifting. Now, if you were trying to put an 8 speed crank on there....
PostPosted: Wed Jul 24, 2013 8:56 pm
I also can confirm you can use any chainset with the Di2. i have used the new sram red c/set and also built one with campag s/r.
and also fsa k light and rotor cranks.
hope this helps.
cyman.
PostPosted: Thu Jul 25, 2013 3:59 am
Cheers
It's not officially supported by Shimano, but a number of people seem to be doing it. Some say it works best with the new narrower 11 speed chain.
PostPosted: Thu Jul 25, 2013 4:00 am
What options are there for using 10 speed wheels with 11 speed Di2? Is there a magic "I'm in 10 speed mode" button so I can switch between a 10 speed & 11 speed wheelset quickly & easily?
PostPosted: Thu Jul 25, 2013 4:11 am
Isn't the internal width the same?
PostPosted: Thu Jul 25, 2013 5:56 am
Yes, I believe so. But the connecting plates (is there a name for them?) are thinner, so the chain itself is thinner to fit the narrower 11 speed cassette spacing.
PostPosted: Thu Jul 25, 2013 6:14 am
So it would make no difference on the front rings.
PostPosted: Thu Jul 25, 2013 6:43 am
No unfortunately there is no software option (yet) to change that. However you can use 11speed cassette and remove one cog. So spacing between cogs is correct.
PostPosted: Fri Jul 26, 2013 1:38 pm
Dura Ace Di2 10-speed (7970) still functions without a front derailleur (just checked to be sure).
Does the same apply to e-tube Di2? (Ultegra 6770 and 6870, Dura Ace 9070)
my plastic bikes, 29ers & stable of old steel
PostPosted: Fri Jul 26, 2013 7:36 pm
Yes, you can disconnect the wire, same as 7970, but I must ask, why?
I am troubleshooting a battery drain problem on my 9070 Di2 & have disconnected my rear derailleur wire, cycling the front derailleur & vice versa.
We're flying down mountains with just a bit of carbon and two skinny tires between ass and asphalt
2017 BMC R01 RoadMachine, R9170 Di2, R9170-C40-TL
2015 GT Grade, Ultegra Di2, Reynolds ATR
2010 S Works Epic, Sram XX1, Carbon Roval Control SL
There are no new unread posts for this topic. Brake squeal slowing down from higher speed, but works fine with slower speed.
stockae92
Mon Jun 27, 2016 5:40 pm
Calnago View the latest post
There are no new unread posts for this topic. Family Budget 5700 10 Speed to 11 Speed questions
Afnole16
15
623
Thu Dec 22, 2016 5:06 pm
JamesGRC View the latest post
There are no new unread posts for this topic. Campagnolo 11 speed crank w/ 9 speed chain Compatability
rgamble
Fri Oct 28, 2016 9:09 am
icenutter View the latest post
There are no new unread posts for this topic. Campy 10 Speed left shifter with 11 Speed everything else?
toronto-rider
Tue Sep 06, 2016 1:20 am
Cheetahmk7 View the latest post
There are no new unread posts for this topic. Campag 10 speed cassette with 11 speed chain?
campagowlo
Sun Apr 16, 2017 1:10 am
BRM View the latest post
Users browsing this forum: calvin, chupster98, djgarrett21, Google Adsense [Bot], hannawald, lamphead, matejS, Yahoo [Bot] and 36 guests
