Post new topic Reply to topic  [ 15 posts ]
PostPosted: Mon Mar 18, 2013 8:11 pm
Dear all,
Does anyone know whether a Rotor 3D+ crankset that has a Power2Max installed, can be outfitted with a Osymetric chainset (110BCD)? I just came to the conclusion that the Rotor Q Rings XL that I ordered do not fit, at least not the outer ring. For the time being, I'm not yet willing to take it to the next level with the Rotor Q Rings and to use the dremel. Any input on whether Oysemtric rings would fit would be helpful.
These won't fit :
Would these fit ?
Not yet ready to do this with my Q Ring XL, as seen on slowtwitch, as Power2Max says it should be 'avoided' .. :-)
From the homework done by the individual on slowtwitch, I would believe that the Osyemtrics might be just about right?
PostPosted: Tue Mar 19, 2013 6:14 pm
I've obtained an answer through Power2Max, and they let me know that the Osymetrics 110 BCD should fit the Rotor 3D+ Powermax
PostPosted: Wed Mar 20, 2013 7:10 pm
i asked them this same question and the response was 130mm osymetric only which was upsetting but now im not sure. but now im thinking about praxis 52/36 but i like the osy a lot.
Full steam we go against the odds
Headfirst we go against the grain
Against the odds, against the grain
We go against the odds, against the grain
PostPosted: Wed Mar 20, 2013 8:16 pm
I'll have an answer for you within a week, I hope. I ordered the 110 BCD Osymetric. I'll post the result here
PostPosted: Wed Mar 20, 2013 11:04 pm
this is a 130
PostPosted: Thu Mar 21, 2013 10:15 am
Hi all,
Nicolas here from power2max. I am happy to confirm that you can mount 110BCD Osymetric rings without problems. The reason the 110BCD Aero Q-Rings don't work is that they interfere with the battery cover. The Osymetrics are cut out in that area, so no problem there. A training buddy of mine uses both the compact and the 130BCD version, I run the 130 BCD on my TT bike
I hope this helps,
Best wishes
Nicolas
power2max
power2max
PostPosted: Thu Mar 21, 2013 6:55 pm
Allright, thanks for clarifying Nicolas ! I'll post a picture once it's mounted.. To be sure, the cut out area is the one that needs to go underneath the battery cover, right ?
PostPosted: Thu Mar 21, 2013 7:02 pm
@lyot: that's right. Enjoy your power2max and osymetrics!
Sent from my HTC One X using Tapatalk 2
power2max
PostPosted: Fri Mar 22, 2013 11:23 pm
Thanks for the reply Nicolas, had been wondering this myself, time to break out the credit card I guess :D
PostPosted: Sat Mar 23, 2013 4:50 pm
Hallelujah, succes ! :) It's not the cut out area though that needs to go underneath the battery holder. It's the opposite part of the ring Image
PostPosted: Sun Mar 24, 2013 7:40 pm
Sorry lyot, I misunderstood what you meant with cutout.
Enjoy your new p2m :)!
power2max
PostPosted: Mon Mar 25, 2013 7:38 pm
this is top new's think i no what's next on the list
a tip for you if you would like to remove the osymetric graphic from the chainrings park chain degreaser rub it on
use it a couple of times and hey presto blacked out
PostPosted: Mon Mar 25, 2013 9:19 pm
Thanks for the tip ! I'll let it on for a while, but probably will remove it within a couple of weeks/months.. A bit too white, indeed !
PostPosted: Thu Mar 28, 2013 6:24 am
Does anyone know if you can fit the Power2Max meter to the Rotor Flow crankset? I had a search around but couldn't find an answer.
PostPosted: Thu Mar 28, 2013 12:24 pm
Hi 54x11,
yup, fits the 3D+ model.
Best
Nicolas
power2max
Users browsing this forum: 573, angrylegs, Bing [Bot], CarlosFerreiro, dgran, Google [Bot], headwind816, LionelB and 63 guests
There are no new unread posts for this topic. Osymetric chainrings (mountians)
guttengeo
21
935
Mon Apr 01, 2013 9:58 pm
tdudzik View the latest post
There are no new unread posts for this topic. Rotor Q-Ring vs. OSymetric for TT bike
tdudzik
7
1803
Thu Oct 04, 2012 3:25 pm
Machinenoise View the latest post
There are no new unread posts for this topic. Ordered my Osymetric chain rings today.
kevosinn
Tue Jul 31, 2012 11:31 am
alibongo View the latest post
There are no new unread posts for this topic. Nice cranksets for BB90 Madone and Osymetric rings
Kayrehn
Fri Apr 26, 2013 4:48 am
Kayrehn View the latest post
There are no new unread posts for this topic. Osymetric rings verses Q Rings.
Juanmoretime
7
868
Thu Mar 14, 2013 6:33 pm
tinozee View the latest post
It is currently Tue May 21, 2013 2:38 pm
