Post new topic Reply to topic  [ 8 posts ]
 Post subject: Re-painting stem
PostPosted: Sun Mar 17, 2013 4:49 pm
Dear Weenies
I would like to re-paint my FSA OS 115 Stem, as it has some paintscrubs over the last year. I want it to have a clearcoat finish to match my new bike.
How would you recommend it to be done? Should i just get all of the old paint off with sandpaper, and then re-paint it with black spraypaint and then a clearcoat layer?
 Post subject: Re: Re-painting stem
PostPosted: Sun Mar 17, 2013 4:59 pm
Tried to sand mine, lots of work and not a detailed outcome
Orbea Orca Gold 6430gr, Orbea Aqua, Tommasini Tecno, FM-066SL 6480gr, Kinesis RaceLight T2, Trek Superfly 100, Trek Session 88, KTM EXC-250
PostPosted: Sun Mar 17, 2013 6:10 pm
It really depends. If it is actually painted, then you could use paint stripper to remove the paint.
If its anodized (which I think it might be) then caustic soda/oven cleaner will remove the anodizing. Use it carefully though. Go easy on bolt threads.
If you've stripped it back ot bare metal, then theres no need to clearcoat it. Just polish it up and give it a clean every once in a while.
PostPosted: Sun Mar 17, 2013 7:05 pm
Sounds good with the oven cleaner. But i need the stem to be a clear black.
I want it to get the look of a FSA SL-K stem (not the graphics) just the finish. How should i proceed?
PostPosted: Mon Mar 18, 2013 5:53 am
I painted my stem. It's a 3T ARX LTD stem. It's a carbon stem with a clear coat but the process is the same with aluminium.
I did it because i wanted the stem i a Matte finish to match my bike.
I used 800 grit wet sandpaper and then 1200 grit wet sandpaper. You don't need to take off all the paint, just make it smooth and get out any scratches or dents.
Then i used 2pack paint. it's a 2 part mix, paint and hardener.
This was sprayed with a gravity feed paint gun and compressor.
Alternatively you could just use acrylic pressure packs but it's not as glossy and won't last as long.
2012 Scott Foil Premium
PostPosted: Mon Mar 18, 2013 11:17 pm
Went ahead and did it.
Currently it's drying up and i hope that the result will look as good tomorrow as it does now.
Will post some pictures.
PostPosted: Tue Mar 19, 2013 9:53 am
The result should get better as the paint/clear coat dries and hardens.
Cannondale SuperSix 105 Team Replica: viewtopic.php?f=10&t=85941
PostPosted: Wed Mar 27, 2013 8:00 pm
Would be interested in how it turned out. Pics?
Dedacciai Scuro RS - For Sale (frame & fork)
Greg Lemond Maillot Jaune Columbus TSX
Merlin Extralight
Santa Cruz Tazmon
Users browsing this forum: Bing [Bot], Google [Bot], Google Adsense [Bot], kaaos, Majestic-12 [Bot], petal666 and 49 guests
There are no new unread posts for this topic. Hand painting - spray painting
itsacarr
Fri Sep 21, 2012 7:16 pm
Berk View the latest post
There are no new unread posts for this topic. Painting a titanium frame
Sisbud
10
738
Sat Feb 16, 2013 10:31 am
Sisbud View the latest post
There are no new unread posts for this topic. Painting Cannondale hollowgram SL
loco2546
15
1842
Thu Sep 06, 2012 2:19 pm
KB View the latest post
There are no new unread posts for this topic. Attachment(s) Painting small metal components
NiFTY
Wed Oct 17, 2012 2:31 pm
bura View the latest post
There are no new unread posts for this topic. Which stem?
BeeBee30
Fri Jun 01, 2012 7:52 am
SWijland View the latest post
It is currently Sun May 19, 2013 12:51 pm
