Hongfu FM-066/Chinese open mould frame thread
I have not gotten to the cablerouting yet, but i pulled through one of the brakecable and one shiftcable since you asked and it went through without issues. I will def keep the white liners for re-use when its time to change the cables. I think it would be hard to do the routing without them.
robbern wrote:I have not gotten to the cablerouting yet, but i pulled through one of the brakecable and one shiftcable since you asked and it went through without issues. I will def keep the white liners for re-use when its time to change the cables. I think it would be hard to do the routing without them.
With a good quality magnet, it is really easy to route the cable. You will not need the liners
Thats a good tip, thank you. I will still keep the liners though, its not like they take up a lot of space.
For the other 069-owners out there, I was sqeezing the top and downtube today and i feel like they "squish" together quite a bit. When I sat on the bike for testing, it felt solid as a rock. Are your tubes the same way and what about other carbon frames? Ive only had one differen carbon frame, and that is a quite heavy and feels pretty thick. Its squishes together, but not as much.
robbern wrote:Thats a good tip, thank you. I will still keep the liners though, its not like they take up a lot of space.
I was wondering the exact same thing. I'm coming from an FM098 and wanted something lighter. Should there be any concern on the squish factor?
ToffieBoi wrote:robbern wrote:I have not gotten to the cablerouting yet, but i pulled through one of the brakecable and one shiftcable since you asked and it went through without issues. I will def keep the white liners for re-use when its time to change the cables. I think it would be hard to do the routing without them.
This is a carbon frame.
I don’t think I need to elaborate further for everyone here to infer the implications of your suggestion.
You are not meant to run cables inside the liners. No. Cables don't rub against anything.
maxxevv wrote:REALLY .... ??!!
Then please explain how you get them to go around corners and bends while actuating mechanical motion. This is a NEW branch of physics to me.
often the wire comes out under the bb, and re-enter the frame just behind. still haven't seen a fram where the liner should be left in the frame, but it thats the case here, it´s a stupid construction considering friction and considering that the liner isn't rigid like a shifting hose
Cable will rub only under the bb, and that's perfectly normal.
Anywhere else inside the tubes, they design the enter and exit to prevent cable touch anywhere.
That's why, you don't need liners inside. I use them only under the bb to reduce the friction.
Sent from my HTC One using Tapatalk
The FM069 has a cover underneath and then there is a little piece of plastic that routes the wires to FD and chainstay. Finished the build today and almost everything went smoothly. The liners for the FD and RD should we on opposite sides, so i had to switch that myself, but easy job.
All done:
All done:
maxxevv, have you built a frame with internal housing? It is a direct, straight line from the entrance to exit points, or to the plastic guide at the BB. No need for a liner. At no point will the cable be rubbing on anything other than the housing (before it enters the frame), or the plastic guide which is designed to be used without a liner.
As a side note, there are a select few frames with liners built in, perhaps that's what you have experience with? Regardless, those are considered inferior due to the generally non-replacable nature of the liner and the inevitability of said liner filling with dirt, gunk, etc.
Take your irony somewhere else if you haven't built one of these frames. Or any other internal routed frame apparently.
- Similar Topics
- Replies
- Views
- Last post
Guide me to the best open mould frame (super light and super stiff)
by KOMwannabe » Sun Nov 12, 2017 9:02 pm » in Road - 8 Replies
- 2557 Views
Last post by KOMwannabe
Tue Nov 21, 2017 2:11 pm
- 3 Replies
- 834 Views
Last post by mekineer
Mon Mar 05, 2018 6:25 pm
Weird Lightweight Chinese Steel Frame - CLR6200 Reynolds 520
by waltthizzney » Mon Oct 30, 2017 7:19 pm » in Road - 15 Replies
- 3324 Views
Last post by ernestkus
Sat Nov 18, 2017 12:43 pm
- 10 Replies
- 1302 Views
Last post by akafinto
Tue Jan 16, 2018 6:47 pm
- 15 Replies
- 3034 Views
Last post by apctjb
Sat Nov 18, 2017 9:22 pm
