It is currently Thu Apr 27, 2017 2:22 pm
Post new topic  Reply to topic  [ 2573 posts ]  Go to page Previous 145 46 47 48 49172 Next
PostPosted: Thu May 29, 2014 11:29 am
seanblurr wrote:
My size 50 FM069 frame was 880g
Same.....my 50 FM069 frame was 880g.
PostPosted: Mon Jun 02, 2014 4:47 pm
Here's mine:
https://secure.flickr.com/photos/103539683@N04/14143574397/
FM066SL, size 56 frame was 900g
https://www.flickr.com/photos/103539683@N04/16589200022/in/album-72157650512336519/
PostPosted: Tue Jun 03, 2014 12:52 pm
I run Ultergra 6800 cranks no issue
PostPosted: Tue Jun 03, 2014 5:45 pm
I hope the 069 has the same clearance as the 066. I'm really looking forward to sticking some Parigi Roubaix tires on it.
PostPosted: Wed Jun 04, 2014 8:25 am
My FM069 58cm UD matt is now under way. Bought directly from Hong Fu through Summer. Paid via PayPal and had my tracking number the next day.
I went with the BB30 version as I have a set of FSA SLK Light cranks to use for the bike. Can I get any kind of BB30 BB to use? I've read a lot about creaking and BB30 BBs, are there any precautions I can do to minimize the chance of creaking?
If it turns out that I am too weak to do the standard crankset I also have a set of FC7950's. Can I use a FSA BB30 to BSA adapter to fit it and can the adapter be removed at a later point if I should need/want to switch back?
PostPosted: Thu Jun 05, 2014 2:37 pm
prendrefeu wrote:
Does anyone have the weight of an FM069SL in 53 frame and fork?
While I wait for an estimate on frame repair after extensive damage, I'm considering my options... while I absolutely *LOVE* my current frame and it rides like no other - but possibly too stiff actually - if there is an opportunity to go lighter with a wash in cost, it may be worth considering.
I have just finish to build a HF-FM069 size 50 bike . The frame and fork weight was 888 and 376 g. Hope this help. The size 50 was for my 5ft8 rider and it fit perfectly. I am 5 ft6 and but with long arm and leg and it also fit me well. Make shure to check the horizontal tube length (and other spec) to be shure you have the wright size.
Build was with the new Ultegra 6800 and the front derailleur was touching the frame and could not be set perfectly. I have a post on this on RoadBikereview forum. Make a search on HF-FM069 + Shimano ultegra 6800.
PostPosted: Thu Jun 05, 2014 2:56 pm
hernluis wrote:
any body have issues installing an ultegra double 6800 derailleur. ive heard some issues with other dengfu frames that the spring hits the frame.
I have a post on Roadbikereview forum regarding this issue. Do a search with HF-FM069 and Shimano ultegra 6800 11V.
First, I had to cut the excess length of the spring of the derailleur flush to the leg that hold it
With a 52-36 crank, the leg of the spring tend to touch the frame, when you jower the derailleur in position. The closest I could get to the big chanring was 4 mm instead of the 1-3 recommended. I have tried to place some shim on the derailleur and the holder to aleviate the problem without success. Hong-Fu is sending me a new derailleur holder but I have not received yet.
At 4 mm above the chainring, it shift fine, but could may be )or not be improve if it was lower.
If you have a 50-34 compact crank the problem will be a lot worse.... A standard crank with a 53 chainring might be Ok after cutting the derailleur spring.à
This problem is caused by the specific design of the 6800 derailleur. The Dura-Ace version seems to have the same design as the 6800 from the picture I saw.
I would recommend to check with HongFu if you want to go with HF-FM069 + ultegra 6800 combinaison, before ordering.
SRAM or Campy, or Shimano 10 spd wont have this issue, from what I know.
I am waiting for the front derailleur holder from Hong-Fu and post the result on the Roadbikereview forum.
Hong FU assure me of there full support to solved the problem (including returning the frame if I want to)
UPDATE :
I have received the new derailleur holder and it did not solve completely the problem. The best I could get is 3mm above the chainring. Shifting is fine. However, this wont solve the problem if you have a 50-34 crank since the derailleur have to go another 4 mm lower.
Except for this , the frame is very good and Hong FU said that they will help. So contact them if you run in the same problem.
Microshift is coming with a 11V front derailleur Shimano compatible very soon. This could be an option.
Again, this is a compatibility issue between the 6800 front derailleur and the FM069 frame. You shpuld not get this issue with other groupsets.
PostPosted: Thu Jun 05, 2014 4:45 pm
A 1~2mm spacer between the BB and the frame would probably solve the problem.
PostPosted: Fri Jun 06, 2014 1:59 am
Pivens wrote:
Here is mine. It's a 45cm IP066 SL, (the same as FM066 SL) the frame weighs exactly 850g, and the bike, as pictured, weighs in at ~6.7 kg.
The build is still not definitive though, as non matching yellow housings will go in favour of black or matching highlight yellow housings.
May I ask how you source an IP066SL in Europe? I note that they come in smaller sizes than FM066SL, but is the same frame as FM066SL. Thanks.
PostPosted: Fri Jun 06, 2014 3:30 am
Now IP-066-SL have size 45/48/50/52/54/56/58/60cm. and the price of IP-066-SL from IPLAY is about 600usd/set. their email: bella@xmiplay.cn or Peter@xmiplay.cn
web: www.xmcarbonspeed.com
Email: bellajian@foxmail.com
Skype: bellajian1988
PostPosted: Sat Jun 07, 2014 10:58 pm
My frame arrived:
size 58 UD bb30.
PostPosted: Sun Jun 08, 2014 9:06 pm
Hi,
I'm currently weighing 115kg.
Could you advise me a frame how could support my weigh? FM069?FM066 or anther one?
Best regards
Fabien
PostPosted: Sun Jun 08, 2014 11:49 pm
Probably something along the lines of a Caad10. I can get this thing to flex pretty well under load and I am only 68kg
Instagram @seanblurr
PostPosted: Wed Jun 11, 2014 9:14 pm
Finally making some progress on my FM069, hope to get the drivetrain on tomorrow.
PostPosted: Thu Jun 12, 2014 4:22 am
robbern, based on my uneducated look at your frame pics, it appears that routing cables is straight forward. Was this the case with your frame ? Am I missing anything ? thanks !!
There are no new unread posts for this topic. And the FSA wireless group set is out in the open
2old4this
Thu Jul 21, 2016 8:15 am
2old4this View the latest post
There are no new unread posts for this topic. Challenge Strada 25 on Mavic Open Pro rims blow off
roadchallenge
Mon Dec 05, 2016 5:58 pm
roadchallenge View the latest post
There are no new unread posts for this topic. List of 320tpi Open Tubular-Style Clincher Tyres
Valbrona
7
655
Tue Apr 04, 2017 1:35 am
ferrarista View the latest post
There are no new unread posts for this topic. Another Pedal Thread..
[ Go to page: 1 2 3 4 5 6 ]
3Pio
86
6720
Sat Apr 22, 2017 4:04 pm
3Pio View the latest post
There are no new unread posts for this topic. UCI abolishing 3/1 rule thread
ultyguy
12
2105
Wed Sep 07, 2016 5:52 am
cyclenutnz View the latest post
Users browsing this forum: benzebub, bikemaniack, Bing [Bot], CallumRD1, Google Adsense [Bot], madik, mnmasotto, Pajjy and 47 guests
