Hongfu FM-066/Chinese open mould frame thread
SLCBrandon
by SLCBrandon
oreoboreo wrote:With replica watches and replica high end bike frames it is not what is on the outside, since they look almost the same. It is what is on the inside that could matter???
Replica? Of what?
Enkei
by Enkei
rainerhq wrote:Make sure the minimum diameter of that new expander fits your steerer tube. My chinese fork takes only Carbon Ti expander (and Neco) which has 21,2mm min diam. It is because the steerer tube has very thick wall.
It's possibly a little tight. The CarbonTi Expander seemse to offer the same performance and weight at a cheaper price though so might just go for that. It's the same type of skrew right? I mean it's compatible with the MCFK Ahead cap?
Cheers
rainerhq
by rainerhq
Yes, I think that M6 bolt is pretty much standard.
"Nothing compares to the simple pleasure of a bike ride"
Jamis Renegade Expert
Spark 900 RC
2002SaecoReplica
by 2002SaecoReplica
So with my road season coming to a close I wanted to get a cheap bike to just derp around on until my race bike for next season comes in. Does anyone know who sells Hong Fu in the US or do you just buy direct? The FM069's looks kind of interesting and the claimed weight is crazy light.
- Zipp rims will break if you look at them too hard
- R-Sys wheels will spontaneously explode
- The ZG crankset will never, ever exist
- Everyone needs Lightweights, even if they're fat and old
- Parts actually made of metal are SO 10 years ago
eric
by eric
You have to buy direct from HongFu.
Ahillock
by Ahillock
mastaYD wrote: I weighed frame includes hanger, cable guide. It is 940g, size 54.
Its shape looks like 2013 cervelo r3, but much lighter than same size R3.
Really? Much lighter? I thought a painted R3 is around the same weight, maybe slightly more. I can definitely see a nude R3 as being the same weight, at least from the few R3 frames that I have seen weighed.
winstonc
by winstonc
I'm considering getting an FM066SL. Does anyone who has one of these frames know how much tire clearance there is - or what the fattest tire is that will fit?
On one of my bikes, for the rear I have a 23mm wide rim (Kinlin XC279) and a Continental GP4000s 700x25 tire, and there's very little clearance below the brake-mount arch. It's so close that when it's wet out and I ride over sand, I can hear the sand that's stuck to the tire grinding against the brake.
If I build up an FM066SL, I want to make sure there's enough width and vertical clearance for wider tires and rims.
SLCBrandon
by SLCBrandon
I run a 25mm Sprinter tubular in the rear on mine. Too lazy to go look at how much clearance there is right now, but I've been running it for a month or so now with zero issues while sprinting or out of the saddle climbing.
Hope that helps.
trilocus
by trilocus
I'm going to buy this frameset but i have doubts about the size. My height is 180 cm and my inseam is 86. What size should fit me best?
Thank you
metanoize
by metanoize
trilocus wrote:I'm going to buy this frameset but i have doubts about the size. My height is 180 cm and my inseam is 86. What size should fit me best?
Thank you
Hopefully you can find a shop that carries Cannondale SuperSix Evo. It has identical geo to the FM066.
winstonc
by winstonc
SLCBrandon wrote:I run a 25mm Sprinter tubular in the rear on mine. Too lazy to go look at how much clearance there is right now, but I've been running it for a month or so now with zero issues while sprinting or out of the saddle climbing.
Thanks for the info.
glepore
by glepore
Fm066 has amazing amounts of clearance-I've run 28mm Parigi/Roubaix clinchers on Heliums and 25m Open Pro's on A23's no issue. Just ordered a set of 25mm carbon clinchers to go with the Vitts...
Cysco Ti custom Campy SR mechanical (6.9);Cannondale SS Evo Di2 7970 (5.79); Willier Cento Uno Air Di2 9070 (7.0); C40 Mk2 DA 7800 ; Anvil Custom steel Etap;1996 Colnago Technos Record
amey
by amey
Just finished my FM066:
The overall quality of the frameset is astonishing! And its the best $35 paint job I've ever seen!
Here are specs:
Frame: FM066
Fork: Hong Fu
Headset: Necco
Seatpost: Hong Fu
Saddle: Arione Carbon
Stem: 3T ARX
Handlebar: 3T Ergonova Pro
Seat clamp: Token CNC
Bar tape: Syntace
Pedals: Look Keo classic
Front Wheel: Kinlin XR200 on BHS ultralight hub
Rear Wheel: Kinlin XR200 on Novatech ultralight
Tyres: Ultermo DD + tubes
QR axle: BBB hex
Groupset: Ultegra 6700
Crankset: Rotor 3D+ 170mm 53/39
Weighs exactly 7015 grams with pedals and bottle cage and garmin mount
chalkie
by chalkie
Just finished mine. Weight at the moment: 6.0 kg including pedals and bottle cage. Frame was 903 grams in size 56.
http://fotos.rennrad-news.de/p/320860
http://fotos.rennrad-news.de/p/320859
HammerTime2
by HammerTime2
chalkie, that spacer looks rather unusual, what is it?
