Hongfu FM-066/Chinese open mould frame thread
spliid
by spliid
Okay. Maybe that's the way to go. It just seems a bit strange if they include a headset which don't fits perfect. That's actually pretty irritating.
eric
by eric
Make sure your crown race is seated the same amount all the way around the fork. Otherwise the bearing will be binding in one direction and loose in the other.
spliid
by spliid
Yes, will do.
It's pretty hard to disalign the lower bearing. It can nearly only happen if the frame is made wrong. I will get back when i have given it another try.
spliid
by spliid
Hello again!
I have now taken the crown race off and taken a picture. The downside is not totally flat as you see. Also a picture of the fork crown is attached.
What do you guys say?
eric
by eric
That's what mine looked like. I have the Neco headset.
I used a piece of PVC pipe of the right diameter (it fit neatly on the flat part of the crown race) and greased the fork.
I have read warnings about putting force on the underside of the fork crown, so I grabbed the fork legs
with the fork upside down and whacked the fork and pipe against the floor.
spliid
by spliid
Thx.
That's exactly what I did. I will try again. Maybe sand a bit?
rainerhq
by rainerhq
Don´t sand. Put a little liquid soap + PVC pipe method.
"Nothing compares to the simple pleasure of a bike ride"
Jamis Renegade Expert
Spark 900 RC
spliid
by spliid
Will do chief.
glepore
by glepore
Actually, it looks to me like he crown race was fully seated in the frst pic-here's mine-the gap may be just the was it is
Cysco Ti custom Campy SR mechanical (6.9);Cannondale SS Evo Di2 7970 (5.79); Willier Cento Uno Air Di2 9070 (7.0); C40 Mk2 DA 7800 ; Anvil Custom steel Etap;1996 Colnago Technos Record
spliid
by spliid
It looks like it's exactly the same.
ms6073
by ms6073
How about an image of the crown race with the bearing seated on top? My suspicion is that the bearing supplied is incorrect and does not have the correct inner/outer angles which does not allow it to fully seat against the inner race inside the headtube. Alternately, measure the stack height of the crown race and bearing and compare to the measurement inside the headtube, if the wrong bearing has been supplied, other than a lower profile headset bearing, no amount of tinkering is going to resolve it.
glepore
by glepore
Aside from appearance, its not a problem, I've ridden the bike hard for 2 weeks now, and it rides/handles spectacularly.
glepore
by glepore
If you're really concerned http://www.diymtb.com/displayItems.asp?cid=58 has the bearings in 8,7 and12(!)mm applications. If the stock bearing is 8, 7 will make it "look better" but I would want to be sure that the top of the crown doesn't rub on the lower headtube.
inertianinja
by inertianinja
I have the same gap with my Chris King Nothreadset and Funda fork - the crown race is thick enough to create a gap, and the lower bearing cup doesn't extend low enough on the sides to cover it. But it's not wrong.
glepore
by glepore
anyone using a chain catcher with this frame? Which one?
