Post new topic Reply to topic  [ 289 posts ]
Go to page Previous  1 ... 14, 15, 16, 17, 18, 19, 20  Next
PostPosted: Sat Mar 16, 2013 7:51 am
That's a great looking bike !
PostPosted: Sat Mar 16, 2013 11:48 am
Slcbrandon, could you tell me where you bought those bottle cages? I can't seem to find any place to buy them..
PostPosted: Sat Mar 16, 2013 3:06 pm
PM me, my brother has quite a few of them and I can get you his contact information.
 Post subject: Re: FM-066 SL frame
PostPosted: Tue Mar 19, 2013 7:52 pm
Does anyone know if wheels mfg do a dropout to fit this frame, and if so which one? If not anywhere I can get them aftermarket in the UK?
Cheers
PostPosted: Tue Mar 19, 2013 9:07 pm
I don't, but when you order through Velobuild there's a check box for extra dropouts.
They're cheap that way.
PostPosted: Tue Mar 19, 2013 10:30 pm
I'm not buying from velobuild, but that may be a possibility to order extra from source, no doubt it will be the cheapest way, if not the most convenient. Thanks.
PostPosted: Thu Mar 28, 2013 4:51 pm
Just a datapoint. Rec'd my 50cm SL frame from Hongfu gand have it built w/ DA7800. Haven't weighed the complete bike yet, but the frame itself came in at a respectable 836g and the fork at 359g. The seatpost was a bit porky at around 230, will probably find something lighter, have a Bold Ti one but am hesitant to use it on an all black bike.
Build was no drama, frame finish is pretty nice. Internal cable routing a typical pain, not looking forward to replacement.
Also purchased the integrated bar and stem, unfortunately forgot to weigh it.
Wait was around a month, but that was mostly due to the bars, supposedly.
Will ride it today and report back.
PostPosted: Thu Mar 28, 2013 6:08 pm
A quick question for any owners of this frame: has anyone fitted a set of Hed Stinger 6's in this bike, or alternatively could someone put a set of calipers to the fork and chainstays in the area of the brake track? I'm considering picking up one of these frames, but I need to make sure that a 28mm wide rim can fit in there. Thanks!
PostPosted: Thu Mar 28, 2013 8:56 pm
@glepore though a bit late now, you should use a cable set with a line such as gore -it makes future maintenance much easier.
@jwts not tried a hed, but did try a 404fc(wide rim) and a campy neutron (wide spoke angle), both were fine with a 6700 caliper. Used a 25c gp4000 clincher for the zipp check.
PostPosted: Fri Mar 29, 2013 12:03 am
I used jagwire-nice kit complete w/ ferrules, endcaps etc. Issue isn't with the housing, its having to remove the frame caps and then grab the cable with a hemostat or something, particularly a pain at the bb area, as replace one derailleur cable means removing both.
Just rode the bike. Initial impressions are that the back end is uber comfortable-very compliant for how "sporty" the bike handles. The front end is very stiff, maybe a bit much in comparison to the rear. The steering is very quick, whether its too quick is a matter of taste. Didn't descend with it, so not sure how surefooted it is. It does accelerate noticeably quickly, particularly up little power rises.
It seems like quite a bargain for what it is, but time will tell.
I'll try to remember to check clearances tonight when I adjust the fit-I've got some that are 25mm on the way, so yeah, I guess I should check.
PostPosted: Fri Mar 29, 2013 12:14 am
I used an old spoke to grab the cables through the access ports. Doesn't seem that difficult. I think you can keep both der cables in the frame when replacing one, just loosen the other to get some slack so you can remove the plate.
I concur with your comments on the ride. The steering is slightly slower than my Cervelo R3SL. It descends fine but I seem to be ok with a wide range of handling on descents. I thought my Vitus 979 was fine too, just don't make any sudden moves.
You might want to put some padding on the rear brake cable inside the frame. I didn't and mine rattles on the frame. I need to remove it and add some rubber donuts or similar.
There's a good amount of tire clearance on the frame.
Has anyone mounted a Quark on a BB30 one of these yet? Where'd you put the magnet?
PostPosted: Fri Mar 29, 2013 1:20 am
No I mean a kit with a liner that runs from the first cable stop to the mech, so future inner replacements slide straight through.
PostPosted: Fri Mar 29, 2013 3:25 am
I've got a Quarq on mine. I put the magnet just under the bottom bracket area, glued with a little epoxy glue.
I used to have it on the chain stay near the bottom bracket, but clearance was pretty tight in there, and it eventually fell off.
Check my intro thread here: http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=113843
PostPosted: Fri Mar 29, 2013 4:25 am
JWTS- about 40mm at the bottom of the brake track, front and rear.
PostPosted: Fri Mar 29, 2013 4:47 am
Thanks for the responses on the frame width and wheel fittings. The Hed 6's are just a touch wider than the Zipp FC's, and 40mm sounds like plenty of room.
Post new topic Reply to topic  [ 289 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18, 19, 20  Next
Users browsing this forum: audiophilitis, Bing [Bot], Exabot [Bot], Google Adsense [Bot] and 61 guests
There are no new unread posts for this topic. Cyclocross frame as Road frame
tarz
7
722
Thu Jun 28, 2012 1:08 am
bonedpwinkle View the latest post
There are no new unread posts for this topic. Weight Difference 58 frame / 54 frame ?
Pepijn2010
Fri Nov 09, 2012 10:15 am
Pepijn2010 View the latest post
There are no new unread posts for this topic. Looking for new frame
dbecks7
Sun Jun 17, 2012 2:22 am
Powerful Pete View the latest post
There are no new unread posts for this topic. One frame to see you through for a little while
ultyguy
27
2094
Mon Jun 25, 2012 10:58 am
Tinea Pedis View the latest post
There are no new unread posts for this topic. What frame is this???
irf3
7
802
Mon Aug 13, 2012 4:46 pm
artray View the latest post
It is currently Thu May 23, 2013 3:06 am
