Hongfu FM-066/Chinese open mould frame thread
fletch62
by fletch62
Leviathan
by Leviathan
Indeed. But "one swallow doeth not a summer make. "
shadwell
by shadwell
My missus said the same thing......
Leviathan
by Leviathan
:shock:
Hawkwood
by Hawkwood
shadwell wrote:My missus said the same thing......
Love it! Another forum that shall remain namelesss has got a `best lube' thread at the moment, one can only wonder....
racermech
by racermech
shadwell wrote:I f?&$in hope they're legitiate, as i have ordered an FM-066sl and its about 40 days away acording to Hongfu peeps....
At the end of the day, the manuf have posted avdeo of a single unit undergoing testing of sorts with an accompanying cert....
I am not nieve enought to think that the tests were not low cycle count, and that the cert could not be fake if they wanted too, or that the manuf. will not adertise any of the test units which failed within protocol cycle count...
That said I sought none of hese assurances when i purchased LOOKS, or Cannondale's or Scott's or, etc etc... and i have had those other brands products fail in use, some reaonably (stack) others less so..
So all in my take is... these producs are no less suspect than any other source, and in some regards are trying equally hard to qualify themselve sin the market place.... fair enough..
When it finally arrives i will be sure to scrutinize it thoroughly, and it'll be interesting what turns up...
Its funny you bring up the testing cert. I just pulled the trigger on a frame and without asking they sent me the certs. I had a similar thought of this could all be fake. But really what do they have to gain from that? Not a lot really. If it get outs that the certs are fakes and there is no testing all it will do is hurt their business. If they never tested and never sent certs I doubt it would really matter. I know I have never asked for a testing cert for any other bike i have or still do own. Yet my cheap Chinese frame I have a cert for.
I think someone in this thread basically said why both buying one of these. It is simple for me. I like the look of the frame, the price is right and for the type of riding I am doing now it really wont matter if I gain some grams, loose a little stiffness...etc. If (or when) I get back into racing I will look at the name brad frame and their benefits.
The other thing is for me at least is I get to ride "my bike" I have had a little company for a while and this frame I am going to logo up with my company as if it was my frame. Not trying to sell them, or sell anyone on them but I think it will be pretty cool. My logo, my name even made up a model name for it, again all in good fun. Should be interesting to see what looks i get on the group rides...lol
shadwell
by shadwell
Hey guys,
OK so i promised I'd feedback my impressions on the frameset / bike once i had some miles on it...
Quick comments on myslef and the build on this travel bike so you can judge relevent points for yourselves.
Weight: 80kgs
Height: 183cm
Star sign: kidding.. hippies !!!
Environment: Gold Coast Queensland (Oz for this who missed class), sub tropical coastal, breezy to windy, (15 - 40kmhwinds) hilly (5% to 25%). Tarmac a mix of coarse chip seal and the occasional reverred patch of hotmix.. (ever gone back to go over a dream bit of tar again.. i have.. ) Temps 10C in winter to 40C in Summer (now.. ) Humidity bloody high 60 to 100%..
Current Build;
Bontrager 3 tyres, 23mm, 95/105psi FR/RR
Continental Racelight inner tubes.
HED Ardennes SL
DA cassette
Shimano Ultergra groupset
Sram Force callipers (dura ace alu pads)
KMC X10sl chain
3T ARX Team stem (ALU 110 mm 7degree)
3T Ergo sum Team bars (42ctc at hoods 44ctc at drops)
Bontraget Gel race tape (it's great BTW)
Selle italia SLR
Speedplay Zero (Wade Ti spindles)
Okay, with that out of the way, here's some ride impressions;
In summary, frame manufacturing quality is surprisingly good... Better than most folks, including myself I have to say,expect, but still below the best Brand names
Internal frame tube inspection reveals no scandalous practice evident, just clean internal surfaces, and very little mould flash or excess resin
Alignment was good, assembly no issue though I did clean up every frame appeture with the dremmel prior to build....OCD.. I know..
Rear mech hanger did require adjustment, 30 seconds later it was fine and has remained so.
Ride wise, it's lively and direct / immediate under power in a nice way.. So good connection from head tube to B/B and rear axle....
Ther is no wagging through the B/B torsionally, no chain rub on the FR mech under load, and no brake rub at the rear under power, climbing TT or sprint (I sprint shite BTW)
The tapered head tube, steering and fork feel very supportive, i.e little flex under load…fore and aft, or side to side.
From a handling perspective; lively, not unstable, not ponderous.. A reasonable balance... Not crit bike lively but nippier than a sportive bike..... It's good in this regard....
It tracks well through corners, holds its line and can be adjusted without complaint mid corner when required
So tahst all the general and positive traits, all of which go largely unoticed after a few rides as it just gets on with the job… which a great characterisitic in a frameset…
These next couple of items are the things that you continue to notice in subsequent rides.. Not every one, but regulary enough to make you think, and sometimes smile….
Comfort is where it gets interesting ... The 27.2 set back post and pencil thin seat stays make for a very smooth back end..vertical flex is visible especially in the supplid set back seat post
Initially you wonder about tyre pressure ... Then you realise its designed that way.... Vertical compliance with otherwise very good lateral stiffness and support...
Everyone bangs on about this, some frames you really wonder if there is any give… this one (with the seatpost) has it…. And for me its defineatley a big plus.
OK so the only question mark for me; The fork. Whilst steering well and braking well..and by in large tracking well
On rough surface with a step edge (speed bump, or big road joint) it is possible to feel a kick back in the fork, or resonance if you hit the lip of the edge..
e.g. Such and lifting up onto a speedbump.. I have notice to be somewhat twangy... In as far as it feels a little underdamped in its response to a very specific input...
It's not flexible or wagging but there is a feeling a better fork may be worth it on this frame... Eg edge 2 ....
And perhaps here lies a small gap between these products and their more well developed branded counterparts….
Right that’s about it, none of the characterisitcs observed above have evolved, increased, decreased over the many hundreds of kilometers…..
The paint and finish has held up, and it cleans up as new…. Despite copius sweating all over it in the QLD summer this year.. So no complaints at all…
And last but not lest, yep it's light... Around 800gms totally stripped…frame alone for the frameset
The bike built us as spec is 6.8kgs.. Cages, pedals and garmin mount..
Finally, a parting thought… I have grabbed this bike a number of times for 1hr Tempo sessions in the evening over LOOK 595 and 695's
Yes it had an AY-UP light bracket on, but even in this esteemed company, I wasn't deterred for a second to use it… makes you think…..
PS I also couldn't be arsed cleaning the good bikes again, which may have had something to do with the selection… but still …
Hope all this helps any other guys / ladies out there decide for or against….
Any detail questions drop me a line and I'll try to help.
Sorry for the wonky pics..
shadwell
by shadwell
btompkins0112 wrote:Photos?
Mate, its a matte black frame with old and new ultegra bitsas and 3t kit with graphics removed....
Close your eyes and your about there... :lol:
I'll get some...none on the phone to upload right now..
rainerhq
by rainerhq
Bit OT, but now this frame has disc brakes.
"Nothing compares to the simple pleasure of a bike ride"
Jamis Renegade Expert
Spark 900 RC
Kasparz
by Kasparz
I also have the 066SL, I have not yet ridden it because of winter here. But what can I say, there is not better frameset even for triple the price. Frame finish is good. I agree it may not be as good as big brands, but keep in mind this frame is not painted and you do not pay extra money for things that does add unnecessary weight. I like the short'ish headtube and integrated cables. Overall it's a great frame and no doubt that big brands like Cervelo would sell same package for 3kEur with some paint. My 58cm frame comes in at 933g including rear hanger.
andylav
by andylav
Edit: Post removed (resolved by Google !).
metanoize
by metanoize
I got mine in the first wave of a group buys last year. It's an impressive bike. Prior to this bike I've only owned steel and ti. I ride it with Ryenolds 32 tubulars. It's now right up there with my Baum Corretto. All my bikes have the same components Campy and Reynolds 32 wheels. I've tested other carbon bikes. Trust me, this will be money will spent. I'll post some photos in a week or so when I get back to where I have the bike. But here is the geo for now.
wrcompositi
by wrcompositi
Wow, shadwell, your FM-066 weighs only 800g?? I suppose you probably ride a 58cm, and since you use Ultegra groupset, your frame should have BSA BB. That's just the same as my 066 - 58cm, BSA BB, but my frame(in matte clear coat) weighs 949g including RD hanger. There's a sticker inside my frame's head tube that reads "FM066SL/UD-58", so I'm sure it's not the heavier normal version. Did you stripped the paint yourself or had the factory doing so? If the paint weighs considerably, I might consider stripping it since I haven't started building ... :mrgreen:
Asymptotic
by Asymptotic
Kasparz wrote: My 58cm frame comes in at 933g including rear hanger.
Wow, lighter than my addict R1 (951g / 13g hanger, 58cm) and 1/3 the price :?
Norwood & Adelaide Uni CC
