Post new topic Reply to topic  [ 80 posts ]
Go to page 1, 2, 3, 4, 5, 6  Next
PostPosted: Thu Mar 14, 2013 2:49 pm
Online
http://cervelo.com/en/bikes/project-california/rca.html
looks pretty cool but 10 large for just the frame haha
"But when you hit that asphalt down below nothing else matters, your pulse is skyrocketing toward 200"
Speed Concept
Colnago Mapei
S-5 VWD
PostPosted: Thu Mar 14, 2013 3:07 pm
Is that not the price they advertised the R5ca for as well? It still sold; couple members here with them.
PostPosted: Thu Mar 14, 2013 3:17 pm
they need to make a California version of the S5.....
PostPosted: Thu Mar 14, 2013 3:45 pm
Anyone else think it looks stinkingly similar to the EVO Black
http://www.cannondale.com/2013/bikes/ro ... e-crankset
PostPosted: Thu Mar 14, 2013 4:07 pm
Maybe slightly similar to EVO but the rear triangle is much different on the RCa. Look at the chain stays alone. As much as Cervelo is into being aero I wish they would engineer a better way to route the cables, especially in the front. They don't enter the frame until about an inch into the top tube. I really like the way some frame makers have created entry points right on the front of the head tube. It looks much cleaner and minimizes any extra cables being exposed to the wind.
PostPosted: Thu Mar 14, 2013 4:21 pm
Is this any different from the "California" Versions they've offered the last couple of years?
PostPosted: Thu Mar 14, 2013 4:57 pm
They changed over to a "kamm tail" tube shape like Scott and Trek, and it may be lighter. Claimed 667g for a 54cm.
PostPosted: Thu Mar 14, 2013 5:36 pm
Wow. Love the frame, I'll consider one when they start making them in Taiwan for a reasonable price though. $10k...
PostPosted: Thu Mar 14, 2013 6:15 pm
I will get one, it looks nice. It is a little lighter, maybe 30-40 grams lighter. But it uses the Pressfit BB which adds weight because you have to install cups. But then the drive side bearings are outboard and you can use the Ax Lightness or Clavicula cranks which are lighter. The lightest crank you could use on the R5ca was the THM M3.
PostPosted: Thu Mar 14, 2013 6:18 pm
Stunning - in a pretty developed market they always seem to come out with improvements.
PostPosted: Thu Mar 14, 2013 6:24 pm
If I were to create a $10,000 frame I would at least have made the wiring in the front end more neat and thought of some place to hide the di2 junction box and battery.. But well, who am I to say so.
After all Cervelo is the best at engineering.. :wink:
PostPosted: Thu Mar 14, 2013 7:13 pm
Wow -- gorgeous!
This is the nicest stock bike I've seen: good combination of aerodynamics, mass, stiffness.
Geometry doesn't work for me, though. Short reach due to slacker seat tube.
They backed away from the R5-Ca geometry of moving the seat tube forward of the BB then slacking it back to 72.5 deg. Here the seat tube intercepts the BB center and they're back to 73 deg. That seemed like a nice experiment so I wonder why they retreated.
Also curious they stick with 68 mm BB drop across all sizes. Cannondale goes to lower BB in smaller sizes due to shorter cranks. That makes sense. Lower BB results in stealth HTL increase, however.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Thu Mar 14, 2013 7:23 pm
this frame is a great blueprint for how it should be done - selective tube shaping. I'm looking forward to someone building a production ready version of this type, with a shorter head tube and BB30.
PostPosted: Thu Mar 14, 2013 8:15 pm
I liked the look of the R5ca better. The cable routing is definitely a put-off.
Also on a side note: the fork is apparently 250g.
PostPosted: Thu Mar 14, 2013 8:19 pm
Very clean, I like it. Reminds me of a skinny, no nonsense, version of my Wilier Cento 1SR. Similar cable routing and tubes.
Post new topic Reply to topic  [ 80 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
Users browsing this forum: Bing [Bot], Google [Bot], Majestic-12 [Bot], Mario Jr. and 69 guests
This topic is locked, you cannot edit posts or make further replies. Cervelo S2 & S3
JBV
Fri Feb 01, 2013 10:34 pm
NGMN View the latest post
There are no new unread posts for this topic. Cervelo R5 VWD - What's it like ?
roadiesean
Sat Oct 27, 2012 2:38 am
spandexboy817 View the latest post
This topic is locked, you cannot edit posts or make further replies. Cervelo R3 SL vs R5
Naturel
Thu Nov 15, 2012 9:24 pm
Naturel View the latest post
There are no new unread posts for this topic. Cervelo S5
DartanianX
18
1445
Mon Mar 11, 2013 11:31 pm
delonaBianchi View the latest post
There are no new unread posts for this topic. New Cervélo P3
Tillquist
Wed Apr 17, 2013 5:38 pm
It is currently Wed May 22, 2013 2:38 pm
