Sram Exogram Cranks & Extralite RC2 chainrings
nickf
by nickf
What is the weight of the stock exogram rings?
Beancouter
by Beancouter
Mine were 154 grams.
drainyoo
by drainyoo
Does this setup work with the new Sram Red Yaw FD or do you need to use the older FD?
Beancouter
by Beancouter
I'm using yaw with no problems!
drainyoo
by drainyoo
Great, thanks. A side question, did you just use grease on the chainring bolts, or some kind of locktite?
Beancouter
by Beancouter
Locktite!
drainyoo
by drainyoo
Thanks again. Looking forward to getting this setup together.
drainyoo
by drainyoo
I don't understand how to install the chainring bolt that's hidden behind the arm. I have the Extralite chainring bolts and it doesn't reach the threads in the arm. There's also nothing between the two rings. Are they just suppose to float like that? Do I need a special bolt?
deek
by deek
You need the bolt and spacer that came with the Red crank.
drainyoo
by drainyoo
I see. Damn. I found just the arms on eBay, so they didn't come with it. Do you know if I can purchase it from somewhere?
Wookieopolis
by Wookieopolis
This is the Sram part number for the chainring bolts and spacer for the hidden 5th bolt cranks: 11.6918.000.001 I do not think you can buy just the spacer and the one bolt individually. They are available all over the web.
drainyoo
by drainyoo
Awesome, thanks.
Denavelo
by Denavelo
Has anyone run the new Extralite RC2 rings? I'm thinking about getting a set from Fairwheels and I've been hearing rumors of dripping flex.
I've been running Praxis rings for the last year and love them.
Just want the minimal look and 94g 50/34 weight!!
Speedvagen Road Machine "2011 Surprise me | Cannondale SuperSix Evo | Rob English "Mudfoot" 29er | Firefly Ti #419
drainyoo
by drainyoo
I'm running them and I don't notice any flex and I'm 200lbs. They've been great, and are really well made.
Denavelo
by Denavelo
Swooped a set of Lightning Compact cranks and purchased RC2 rings.
So light, even with BB30 BB. 560g complete.
The pic was before I moved the rings around.
Does anyone know where I'm supposed to put the included pin? They usually hide behind the crank arm.
