Post new topic Reply to topic  [ 10 posts ]
PostPosted: Thu Mar 14, 2013 9:49 am
Wondered if anyone has any recent experience of Extralite Octaramp RC2 chainrings? I am considering swapping them on my Sram Exogram crankset but would like to hear recent experiences (older posts didnt seem to be very positive). From looking at the website, it looks as though the catch pin has two insertion points which is a positive (i will confirm with Extralite) but would prefer rings that dont throw the chain in the first place!!
Also, has anyone tried them with Exogram cranks? I have pm'd Terzuya who appears to have done from the "New Red Crank" thread - but any other comments appreciated. Also, any other recommendations for compact rings (other than praxis, as i dont want a 'clover' ring).
PostPosted: Thu Mar 14, 2013 10:20 am
Having been one of the people who gave up on extralite rings a number of years back, I was pleasantly surprised when I purchased a set of lightning cranks w/ the RC rings on them. I gave them a try not expecting much and I couldn't believe it. They must have fixed something because they shift perfectly. The only chain drop I've had in the past 6 months was 1, and that was when I was still using a vumaquad crankset so it wasn't these rings. I was so impressed I purchased a set of the newer rings in black- shifting has been just as good and they look much better on my all black bike (they're also 4g lighter).
Speedplay is the devil.
PostPosted: Thu Mar 14, 2013 1:54 pm
I will let you know because I am doing the exact thing you describe. My chainrings are actually at the post office for pick-up today and I will install on the new SRAM Exogram crank tonight for riding. Hopefully everything goes well but will let you know.
PostPosted: Thu Mar 14, 2013 5:08 pm
Excellent; would be useful to hear what else you are using on drivetrain and changers.
PostPosted: Thu Mar 14, 2013 6:41 pm
I am running SRAM Red pre-2012 on FD, RD and Shifters. I will be using a Yaban Ti chain and a Ti/Alumn cassette (both were selected for weight savings 208 g chain & 98 g cassette). I am putting everything together tonight but fup'd a chainring bolt because I didn't heat up the locktite on the bolts. I am hoping my shop has a spare sitting around that I can get from them.
I tuned the RD w/carbon jockey wheels and rear plate from Fiberlyte and used the bolt kit from Far and Near. I didn't get as crazy as a lot of guys on this site with the drilling but dropped 24 g off the rear. The FD dropped 2 g with bolt kit.
I will let you know how it goes.
PostPosted: Thu Mar 14, 2013 6:46 pm
Sure you already know, but extralite have confirmed dual position for catch pin (which should work with hidden crank arm bolt). They weren't terribly helpful on compatibility with exogram cranks, other than telling me ok for 10/11 speed chains and giving me link to website.
I have asked them if they have any reviews or customer feedback .... Will wait and see!
PostPosted: Thu Mar 14, 2013 6:49 pm
Did they say where to position the catch pin in relation to the hidden crank arm bolt; if not I am sure I can figure it out once I get the rings and look at the crank.
PostPosted: Thu Mar 14, 2013 7:57 pm
No, but expect should be behind crank. As a betting man, I reckon the one supplied will be too long!
PostPosted: Fri Mar 15, 2013 2:02 am
Well here is the crank with the Extralite chainrings. Mine is compact 50/34. The pin actually fit perfectly behind the arm and actually has two options for placement which worked out well seeing as only one placement worked for the Exogram.
If I could actually figure out how to post pictures I would show you what it looks like but this site makes doing that almost impossible for the computer illiterate
PostPosted: Wed Mar 20, 2013 6:56 pm
Got an answer from extralite today:
"it's compatible but you have to insert a 0,4mm shim between bigger ring and crankarm.".
I have asked for a little more detail and will update if I receive anything.
Users browsing this forum: Anders, Exabot [Bot], jong, maddog 2 and 62 guests
There are no new unread posts for this topic. Anyone running Fibrelyte rings on Sram Exogram crankset?
Juggler
Sat Jan 05, 2013 11:35 pm
liketoride View the latest post
There are no new unread posts for this topic. Specialized Carbon Cranks - teeth breaking on chainrings
rhyslewisdavies
Sat Feb 09, 2013 10:18 pm
rhyslewisdavies View the latest post
There are no new unread posts for this topic. 2013 SRAM Red 52-36 chainrings
frafoss
Tue Dec 11, 2012 12:52 am
deek View the latest post
There are no new unread posts for this topic. Using other chainrings on 2012 sram red crankset.
mastaYD
Thu Mar 14, 2013 3:21 am
alexalecu View the latest post
There are no new unread posts for this topic. Rotor Power Crankset with Sram Yaw Chainrings?
trtimothy
7
588
Sun Jan 06, 2013 3:20 am
refthimos View the latest post
It is currently Sat May 18, 2013 9:48 pm
