Post new topic Reply to topic  [ 14 posts ]
 Post subject: Tune freewheel bearings
PostPosted: Wed Mar 13, 2013 10:59 am
An impulse buy, which was then resold now has potential to turn into a nightmare.
In brief I bought a Reynolds wheelset with a Tune rear hub. From what I could gather it is an early Mag180. The freewheel bearings seem to be shot and need replacement.
Do any of you know where I could source said bearings from? Or if any online shops sell replacement freewheels? So far I found it on starbike and hibike in Germany?
TIA
PostPosted: Wed Mar 13, 2013 12:09 pm
You need to talk to Poshbikes to get replacement bearings.
Strada Hand Built Wheels
http://www.stradawheels.co.uk
PostPosted: Wed Mar 13, 2013 12:35 pm
If in the US I would give Fairwheel a shout. They are a Tune dist.
www.ergottwheels.com
PostPosted: Wed Mar 13, 2013 12:46 pm
Thanks Jon.
Spoke to poshbikes already, they claim it needs a new freewheel and cant do the bearings seperately.
As much as I love bikes and cycling, so much I sometimes hate the industry. Sometimes things just don't make sense at all.
PostPosted: Wed Mar 13, 2013 12:53 pm
Freewheel bearings can't be replaced? That's a new one for me. Freewheel bearings are standard size. You don't need the XO bearing. Unless there's more wrong with it that wasn't mentioned here.
PostPosted: Wed Mar 13, 2013 3:41 pm
Tubbie Guru
Hi,
This may be of help:
http://weightweenies.starbike.com/forum/viewtopic.php?f=3&t=100223
Ciao, ;)
PostPosted: Wed Mar 13, 2013 4:34 pm
Fdegrove, thanks I found that earlier on in my search.
So its a simple as buying the two bearings and putting it all back together as in the exploded view in that thread, right?
From any place that sells bearings?
PostPosted: Wed Mar 13, 2013 4:39 pm
That's right. I've personally done it so I know it works.
PostPosted: Wed Mar 13, 2013 4:59 pm
Tubbie Guru
Hi,
Yep. I'd use SKF 2RS ones if I were you as I think that's what Tune uses.
SKF often puts a 1 after the 6 in their nomenclature. (61902-2RS and 61802-2RS in this case)
Ciao, ;)
PostPosted: Wed Mar 13, 2013 5:40 pm
:beerchug:
Thanks gents.
What the hell did we do before internet forums if something like this happened?
PostPosted: Wed Mar 13, 2013 5:47 pm
Tune no longer makes freehub bodies for the Mag180. I'm on my 5th or 6th set of Tuns hubs. I'm in love with the sound and the smoothness of the hub itself. Fairwheel Bikes should be able to send you a bearing if you're in need. They're running out of 180 spare parts, but I don't think a bearing should be that unique to a Tune hub.
PostPosted: Wed Mar 13, 2013 6:29 pm
We have the freehubs and bearings on stock. Tune mostly sent distributors full freehubs with pawls,springs and bearings but you could buy from the them all the parts individualy. The problem with earlier models is that they use the XOT bearing on the middle. Some people have been able to use two bearings together instead of the XOT. The other bearings are regular ones you can find easily.
www.royalbicycles.com
PostPosted: Thu Mar 14, 2013 11:41 pm
Hi jmartpr - just wondering if you have the XOT bearings available for the 180s. Also, do you have experience in replacing the 6802 bearing in the freehub?
Thanks
PostPosted: Fri Mar 15, 2013 12:14 am
Yes....the XOT is in stock. We have the Tune tools for replacint all bearings, it's a very simple job.
If you don't have the tune tools you need something to push the bearing out (round cylinder) and also for installation.
You could tap them in and out if you don't have access to a press
Users browsing this forum: Bing [Bot], Google [Bot], tommasini and 40 guests
There are no new unread posts for this topic. Fulcrum Racing 1 freewheel body on Fulcrum Zeros
digitalnorbs
Sat May 04, 2013 1:19 am
digitalnorbs View the latest post
There are no new unread posts for this topic. Powertap SL 2.4 bearings
Master-Ti
Sun Jun 17, 2012 12:14 am
eric View the latest post
There are no new unread posts for this topic. HELP! Changing Look 695 ZED 2 bearings
Graysk
Fri Sep 21, 2012 7:52 am
Graysk View the latest post
This topic is locked, you cannot edit posts or make further replies. Ceramic bearings for BB - worth it?
NiFTY
Wed Aug 08, 2012 2:00 pm
NiFTY View the latest post
There are no new unread posts for this topic. Replacing Powertap Hub Bearings
dhendriksen
7
791
Wed Aug 01, 2012 5:53 am
Rick View the latest post
It is currently Sun May 26, 2013 4:52 am
