It is currently Wed Jan 17, 2018 6:09 am
PostPosted: Tue Mar 12, 2013 7:37 am
Which body is there on a Lightweight Gen II rear?
See all my bike h e r e
PostPosted: Tue Mar 12, 2013 8:38 am
Pretty sure they had moved to DT Swiss by Gen II. Obermayers have always been Tune.
PostPosted: Tue Mar 12, 2013 9:59 am
Dt Swiss 240
PostPosted: Tue Mar 12, 2013 2:40 pm
WWotY 2007
Lightweight wheels all use DT Swiss internals since the Generation 2.
Standards receive 240s internal and Obermayer receive 190cc.
Best regards,
Adrien Gontier.
RAR wheels
Roues Artisanales
PostPosted: Tue Mar 12, 2013 3:43 pm
Adrien, are you sure about that?
I thought that the initial Gen. II Obermayers used a Tune (internals) rear hub, as did Ventoux Tune. Later in Gen. II, I thought that Obermayer switched to DT 190 rear internals, as did Ventoux Tune, which was eventually renamed Ventoux 190. All Gen. II Standards, as well as Ventoux DT (later renamed Ventoux 240) used DT 240s rear internals.
PostPosted: Tue Mar 12, 2013 11:22 pm
I have a pair of GEN III and i wonder if its possible to convert from 10 speed to 11 speed using the converter free hub that DT have on their web site?
And do i have to do something else with the hub to get it working?
PostPosted: Wed Mar 13, 2013 2:05 am
Venge80,
Read http://weightweenies.starbike.com/forum/viewtopic.php?f=3&t=100549&p=909861#p909815
and http://weightweenies.starbike.com/forum/viewtopic.php?f=3&t=100549&p=909861#p909861
PostPosted: Fri Mar 22, 2013 5:07 pm
Best regards,
Adrien Gontier.
Adrien, I hope you don't mind if I have to correct you a little:
When CarbonSports started production in 2004, for the very first wheels we used the same setup as Heinz Obermayer did: modified but original Shimano Dura Ace / Campagnolo Record hubs. One of the first modifications was to switch to DT for the "Standard" and "Ventoux (240)". For "Obermayer" and Ventoux (Obermayer) there were first used TUNE hubs (easily identifiable by the red freehub body - DT are all black).
That setup was unchanged until Feb. 2008 (Gen.III started September 2007) when we switched from TUNE to DT 190 Ceramic/DT 190s (depending on the wheel model).
Andreas Schiwy, CarbonSports GmbH
http://www.lightweight.info
support[at]lightweight.info
There are no new unread posts for this topic. Attachment(s) Need help - Is this cassette body from Novatec F482 rear hub?
itspat
Thu Nov 23, 2017 9:54 am
alistaird View the latest post
There are no new unread posts for this topic. Exustar pedal body parts?
loudtiger
Sun Apr 23, 2017 1:12 pm
alcatraz View the latest post
There are no new unread posts for this topic. shimano freehub body for chosen hub?
simoncx
Mon Jan 01, 2018 6:23 pm
simoncx View the latest post
There are no new unread posts for this topic. A Review: Body-Customized Meld Saddles
antonioiglesius
33
5989
Fri Nov 03, 2017 5:35 am
random101 View the latest post
There are no new unread posts for this topic. Hugi DT240 freehub body pulls right off?
Catagory6
12
633
Fri Jan 05, 2018 3:13 pm
Catagory6 View the latest post
Users browsing this forum: Bing [Bot], FLYNLZRD, Google Adsense [Bot], tonytourist and 30 guests
cron
