It is currently Thu Feb 23, 2017 1:29 pm
Post new topic  Reply to topic  [ 77 posts ]  Go to page Previous 1 2 3 4 5 6 Next
PostPosted: Thu Mar 21, 2013 9:21 pm
I'm going to blame this thread if this Velocite thing doesn't work out...
2011 Tarmac Pro SL3 Project Black (gone but not forgotten)
2012 Parlee Z5 SLi (just because)
2014 Colnago C59 (why not)
PostPosted: Fri Mar 22, 2013 6:35 am
^^ that's a nice looking saddle... would like to know if there's some flex in the saddle to act a cushion or if it's stiff and hard as hell. :)
PostPosted: Fri Mar 22, 2013 9:18 am
I think this velocite looks exactly like a mega sq1 without the horrible graphics, very comfortable saddle
http://item.mobileweb.ebay.com/viewitem ... 0940598916
Planet-X Nanolight HM - 5.63kg
PostPosted: Fri Mar 22, 2013 2:51 pm
The velocite saddle was first brought up earlier in this thread, so there are some experiences posted. Based on the claimed size specificationd, I'm not sure this is exactly the same saddle as the mega, although there is a similar "suspension" design. Am going for first ride today, I'll report if my butt can tell the difference.
Last edited by carlislegeorge on Wed Mar 27, 2013 4:10 pm, edited 1 time in total.
PostPosted: Wed Mar 27, 2013 4:07 pm
Well...here's my report after 3 rides. Generally, the saddle is pretty comfortable for me. This is a semi-round shape at the rear, so not perfectly flat. The claimed spring-like flex design, based on how the rails are attached at the rear, is noticeable and saddle doesn't ride too stiff.
Where it doesn't work perfectly for me is primarily the size, being relatively short length-wise (website claims 26cm x 13.5cm) makes it hard for me to find the sweet spot. Also, the perineal cutout feature typically doesn't add to comfort for me, no matter what saddle it's on, and this one is no different.
Riding in the drops, however, the negatives noted above disappeared. I may give it a few more rides, but have ordered a Prologo Scratch Pro to try out for non-WW comfort testing. If that works, I'll sell this Velocite saddle cheap to anyone that is interested.
PostPosted: Wed Mar 27, 2013 4:16 pm
I has that sensation at first. It felt like I couldn't find the right place on the saddle to sit, if you know what I mean.
What worked for me was making sure that the saddle was completely level, or very very slightly nose up. When I did that I found that I naturally slid into the slight dip in the centre of the saddle (you can see it in that profile shot).
From your photo it looks like the saddle is slightly nose down. Try leveling it off.
PostPosted: Wed Mar 27, 2013 6:36 pm
You're right, I re-checked and it was very slightly nose-down. I've adjusted to level or tiny bit nose-up, and will see if that makes a noteworthy difference. I'm still thinking the real drawback for me is the length, though. The "rear suspension" design approach, as illustrated below, seems to require a little adjustment period, too.
PostPosted: Thu Mar 28, 2013 12:21 am
I considered that saddle and even a Smud.
I decided to try the Williams Aurora SLC+ and still considering the new toupe pro which looks awesome.
PostPosted: Thu Mar 28, 2013 5:53 am
I often wondered, if the nose is slightly up, wouldn't it hurt ur boys when riding in the drops? At least for me...
PostPosted: Fri Mar 29, 2013 4:07 am
I took a Kit Carbonio flow and stripped the leather off and it works like a dream. That being said the KCF was working for me before the strip but it was waaaaay lighter after getting rid of all the extra bits. Maybe you should try something that worked in the past and "modify" it like we WW like to do.
R.J.
Some people tune their car, I prefer to tune my bike.
http://ilcappellino.blogspot.com/
PostPosted: Fri Mar 29, 2013 5:27 am
I had a KCF for about a month...no thanks, never got close to comfortable on longer rides. The cutout isn't something i need, that's a lesson learned that i need to remember...along with correct fore-aft positioning.
PostPosted: Fri Nov 22, 2013 4:02 pm
Ah yes, Saddles....huge subject. Standard disclaimer: everybody is shaped a little differently, so you have to find what works for you.
But for what it is worth:
I have tried a LOT of saddles over the years, and always had either numbness or simple discomfort.
I seemed to gravitate towards the Turbomatic and Turbomatic Gel Flow. The Selle Italia Signo Gel Flow was also pretty good. Both had cutouts.
But neither was perfect, so I would still occasionally try another saddle. Then I tried the Pro Turnix. It is obviously shaped just a little differently than most, with no cutout, but a gentle "relief area" molded in. It seems to fit my crotch perfectly, and suddenly I just quit thinking about saddles. I guess that's the way a good fitting saddle should be: it just disappears from thought. It's 170 grams, so pretty darned light, but not extreme weight weenie.
So every time I saw one on sale, I would buy it. Now I have one on each bike and a couple spares stashed for future use. They are pretty cheap on sale.
PostPosted: Sat Nov 23, 2013 1:53 am
When I do saddle setup I do it sans padded pant. This helps me quick tell where me sit bone are and fine tune.
PostPosted: Sat Nov 23, 2013 7:37 am
Seems like a good idea. But don't the neighbors complain? :noidea:
PostPosted: Thu Jan 16, 2014 6:06 am
I started this thread almost a year ago but many miles and dollars later I am still searching for a saddle that doesn't cause me discomfort or numbness.
This is what I have spent time on.
Specialized Toupe 143
Specialized Toupe S-Works
Specialized Romin Pro 155mm
Selle Italia SLR Super Flow 145mm
SMP Dynamic CRB (for sale)
SMP Lite 209 CRB (for sale)
My belief is that I need a saddle in the 140mm - 150mm range that is fairly flat in all directions with a reasonable amount of padding and a massive center cutout.
At this point I would be happy with a 250g saddle if I could sit on it comfortably for more than an hour!
Any suggestions?
There are no new unread posts for this topic. Flat profile full carbon saddle w/cutout
nickf
7
807
Tue Jul 26, 2016 4:18 am
NGtim View the latest post
There are no new unread posts for this topic. Attachment(s) Saddle bolt - S-works saddle
Rodi
Fri May 20, 2016 10:12 am
Rodi View the latest post
There are no new unread posts for this topic. Can anyone help me ID this saddle?
jimwhimpey
11
1062
Fri Feb 03, 2017 9:16 pm
peroni View the latest post
There are no new unread posts for this topic. ax Leaf Plus saddle?
1272
Thu Jan 12, 2017 1:47 pm
kgt View the latest post
There are no new unread posts for this topic. Saddle woes
NiFTY
Sat Jul 02, 2016 6:04 pm
wheelsONfire View the latest post
Users browsing this forum: Bing [Bot], gmarsden, Google [Bot], Google Adsense [Bot], MSNbot Media, Orlok, Ritxis and 31 guests
