Post new topic Reply to topic  [ 15 posts ]
 Post subject: 11sp Shimano quick link
PostPosted: Sat Mar 09, 2013 10:51 pm
Does anyone know if there's an available quick link for the 11sp Shimano chain?
PostPosted: Sat Mar 09, 2013 10:54 pm
I have been using the 11 sp KMC on 2 different bikes and no issues yet. :beerchug:
PostPosted: Sat Mar 09, 2013 11:05 pm
For the Campy chain?
My LBS was telling me the width wasnt correct.
PostPosted: Sun Mar 10, 2013 3:54 pm
The width that matters is in between the outer plates. Install the link and use feeler gages to check the side clearance between the inner and outer plates. You should have at least .1mm of clearance, but no more than .2mm is preferable. You can get by with up to .3mm, but it's not a great fit with that much side clearance.
KMC master links tend to have more side clearance than the rest of the chain.
PostPosted: Sun Mar 10, 2013 4:34 pm
I think you will find that the KMC website now says that the X11SL is compatible with both campag 11 and shimano 11. The only issue is that the quick link is supposedly non-reusable but although you may need to use a quick link tool to remove it, it can be put back on and still seems to work fine.
PostPosted: Mon Mar 11, 2013 2:54 am
concurring. been using the kmc 11sp chain too, not just the Missing Link.
http://www.roadiemanila.com
PostPosted: Mon Mar 11, 2013 6:41 am
KMC quick links can be re-used for the life of the chain with no issues. Make sure they are still hard to remove ....if they become sloppy, I'd replace it but I've never struck that, and I take my chain off for ease of cleaning (not that i clean my poor old bike often). Re-using them say 6-8 times before I biff the chain out (the link goes with it).
Used to race....got too wrinkly and old ;) Updated: Racing again! Thought this was unlikely! Eventually, I may even have a decent race!
PostPosted: Mon Mar 11, 2013 7:44 pm
I keep an old worn link as a spare in the seat bag. Takes nearly no room and hardly weighs anything. I have yet to need one but I've used them to fix chains for people I'm riding with.
PostPosted: Tue Mar 12, 2013 1:13 am
Tubbie Guru
Hi,
The entire idea of quick links being usable just once is in all respects just plain commercial horse crap anyway.
Ciao, ;)
PostPosted: Tue Mar 12, 2013 3:19 am
edited
PostPosted: Tue Mar 12, 2013 11:22 am
Horacio, I thinking you're jumping the gun. fdegrove is referring to the fact that KMC state that the 11spd quicklinks are use once and discard when opened. KMC state that the 10spd links are reusable.
This has been discussed in other threads with the general feeling that it's okay to reuse the 11spd links. You just have to monitor them to make sure the link still feels secure.
PostPosted: Tue Mar 12, 2013 3:26 pm
You're right, I totally misread that post. Thanks for pointing that out. I will edit as such.
PostPosted: Tue Mar 12, 2013 3:33 pm
and apologize to fdegrove is a good idea, also ... :)
PostPosted: Tue Mar 12, 2013 3:43 pm
Well, he did edit what he originally posted to what he meant to convey.
My apologies to fdegrove.
Now back to topic.
PostPosted: Tue Mar 12, 2013 6:27 pm
Tubbie Guru
Hi,
I only edited it this afternoon to change one into once.
Anyhow, no problem. Apologies accepted. :thumbup:
Ciao, ;)
Users browsing this forum: doomith, Google [Bot], Yahoo [Bot] and 48 guests
There are no new unread posts for this topic. Shimano DA 9000 11sp - any compatibility with Campag 11sp?
[ Go to page: 1, 2, 3, 4 ]
fivethirtyonepm
52
5236
Sun Mar 24, 2013 11:51 pm
Ritterview View the latest post
There are no new unread posts for this topic. Zipp wheels conversion to Shimano 11sp
DKTYO
Fri Jan 04, 2013 4:13 pm
CharlesM View the latest post
There are no new unread posts for this topic. Source for i-Link & mini i-Link inner liner replacements
Velofreak
Sat Nov 17, 2012 8:46 pm
runner999 View the latest post
There are no new unread posts for this topic. Attachment(s) Upgrading Sram Red to 11sp
[ Go to page: 1, 2, 3, 4, 5 ]
monchito
67
7171
Sun Jan 27, 2013 12:30 am
KLabs View the latest post
There are no new unread posts for this topic. campagnolo 11sp lock ring tool
digitalnorbs
Thu Oct 11, 2012 8:15 pm
paulandmonster View the latest post
It is currently Mon May 20, 2013 12:19 am
