Post new topic Reply to topic  [ 4 posts ]
PostPosted: Thu Mar 07, 2013 8:38 pm
Sorry.. Not much action in the Everything Wheels subforum so I thought I would post here.
I bought some old Zipp 404's off someone last fall and have only ridden them for about 100km.
I noticed this crack only after changing a tube.
How would you go about fixing them? Just dab some epoxy or get a carbon fiber repair kit?
Here is a link to a photo:
http://www.pinkbike.com/photo/9232971/
PostPosted: Thu Mar 07, 2013 11:36 pm
Conatct Zipp... get their advice..
When you see it's likely to be "replace the rim" and as you are not covered under warranty as not the original purchaser, you will be left in a quandry as to what to do.....(but at least you asked..)
If it was a rear wheel i would look into a possible repair with a crabon bike repair specialist.. by the time anything was done you may be approaching th cost of a replacment rim anyway? Worth checking.
If it was a front wheel I prsonally would not even bother with a repair an simply stump up for the replacment rim.
"IF" you are a very light rider and you ride flatish routes on smooth roads you may elect to just continue to rid eit.. with a spoke pulling through being the worst likely out come... which in the event is like a broken spoke... i.e. open the brake and ride home carefully.....
PostPosted: Fri Mar 08, 2013 3:20 am
ahhhhhh.....maybe not....I typed a "repair it" post and posted THEN looked at the pic......you could repair it but that crack seems to be heading up into the rim.....take it to a pro and have THEM repair it.
Used to race....got too wrinkly and old ;) Updated: Racing again! Thought this was unlikely! Eventually, I may even have a decent race!
PostPosted: Fri Mar 08, 2013 6:37 am
It's your face, but it's worth some consideration as to what an accident from wheel failure would entail. I really couldn't advise anything but replacement or professional repair.
Users browsing this forum: Exabot [Bot], Google Adsense [Bot], Miller and 51 guests
There are no new unread posts for this topic. Replacing a Zipp 88 Spoke Retention ring
BeeSeeBee
Sun Dec 09, 2012 5:01 am
BeeSeeBee View the latest post
There are no new unread posts for this topic. Wheelbuilding tool - Nipple Starter
runner999
Sun Mar 10, 2013 10:13 am
MajorMantra View the latest post
There are no new unread posts for this topic. Bontrager Aeolus 5 16/16 spoke vs newer model 18/24 spoke
reason
Wed Oct 10, 2012 8:17 am
reason View the latest post
There are no new unread posts for this topic. zipp 303 FCC Front / zipp 404 FCC Rear
jameskack
Mon Sep 10, 2012 8:10 pm
dmoneysworks View the latest post
There are no new unread posts for this topic. spoke length
thijsken
Sat Aug 18, 2012 9:10 pm
thijsken View the latest post
It is currently Thu Jun 20, 2013 9:46 am
