Post new topic Reply to topic  [ 8 posts ]
PostPosted: Thu Mar 07, 2013 8:03 pm
I have a 2010 Dura Ace WH-7850 C24 wheel set that has less than 30 miles on them. After approximately 10 miles of riding the wheels lose their true (the front wheel isn't as bad as the rear). The route I've been riding is mostly smooth, but there are some areas of the 10 mile loop that are bumpy and in bad shape, and I do my best to avoid as much of the rough parts as I can. My thought is the low spoke count (Front: 16, Rear: 20) is the primary cause, but this is an amateur diagnosis. Due to a minor knee injury and the winter months, I've gained some weight, and I'm around 190 lbs and 5' 9". I don't want to give up on these wheels, but only getting 10 miles down the road before they lose true is frustrating. Any thoughts or suggestions? If you tell me to lose some weight it won't hurt my feelings, and it needs to happen anyway. Would 24 spoke rear wheels solve my problem?
Thank you in advance.
-p
PostPosted: Thu Mar 07, 2013 8:56 pm
Once it's true, tensioned, and even, apply spoke freeze or any other wicking Loctite to the area where the spoke meets the nipple. This will help prevent vibration induced unwinding.
PostPosted: Thu Mar 07, 2013 9:29 pm
These wheels should eventually prove fine for someone of your weight and the riding you described.
It is not that unusual to have new wheels come out of true after a short time. I have the RS80-C24 wheels and they came out of true after just a few rides. However, I trued them up once and now they've been fine for well over a thousand miles. I wouldn't worry about applying loctite or getting too concerned unless you trued them multiple times and had them come out of true multiple times.
PostPosted: Thu Mar 07, 2013 9:44 pm
Thank you to both of you for your input.
I've ridden the bike twice with these wheels and have had to true both wheels after the first ride, and the rear wheel only after the second ride. I'm shooting for a quick ride this evening after work, so hopefully I will have more info tomorrow.
Really appreciate your feedback.
-p
PostPosted: Thu Mar 07, 2013 10:56 pm
One of my MTB ride buddies had the same wheels, and the same problems.
He was about 90kgs at the time. He's 85kg now.
He chased the true on these for about 6 monthd then gave up.
Corrected and bonded spoks did not sem to cure it.
Sadly the wheels were just too light for his mass...
He moved to more robust wheels.
I'd recommend trueing and seling the DA wheels as there i nothing inherently wrong with them.
Then getting some Pacenti SL23 on Alchemy ORC & ELF hubs 20 / 24 radial Front, 2 cross BOTH sides Rear with CX Rays, from Fairwheel bikes in the US. Approx $950US.. NOT A QUOTE.. estimate only!!!
Drop Jason a line there and explain your intended use and mass (fully kitted).
Or if you want off the shelf, sightly cheaper and similar function look to pick up some of the 2013 HED ardennes. Hubs not as good but very similar otherwise.
PostPosted: Thu Mar 07, 2013 11:26 pm
Likely not enough tension - once tensioned sufficiently these wheels should not go out of true as the spokes will have tension even under pedaling loads. Then there is no need for spoke locking compounds. I would ask an experienced mechanic to take a look.
PostPosted: Fri Mar 08, 2013 3:47 pm
To echo mrfish, it's an issue of tension. Just because the wheels look to be trued doesn't mean the tension is evened out properly nor does it mean it is high enough. Either you or a good wheelbuilder should de-tension all the spokes and work them back up properly. Those wheels should be fine under you.
PostPosted: Fri Mar 08, 2013 6:12 pm
Thanks everyone for your feedback. Taking the wheels to an experienced mechanic next week.
Thanks again, and happy riding.
Users browsing this forum: Doolop, Google Adsense [Bot] and 59 guests
There are no new unread posts for this topic. Buying used Dura Ace WH-7850-C24-CL
BTM
15
2261
Sat Sep 01, 2012 1:14 am
BTM View the latest post
There are no new unread posts for this topic. Dura ace c50 7850 wheels.... Which hubs??
dane476
Sun Jun 03, 2012 8:08 pm
dane476 View the latest post
There are no new unread posts for this topic. Replacement rims for Dura Ace 7850 wheels
Beancouter
Fri Feb 22, 2013 8:18 pm
Beancouter View the latest post
There are no new unread posts for this topic. Rebuilding dura ace front wheel
dane476
Wed Jun 06, 2012 5:51 pm
seandonovan View the latest post
There are no new unread posts for this topic. losing 1000g
canbakay
Tue Dec 18, 2012 1:42 pm
SDP View the latest post
It is currently Sat May 25, 2013 7:29 pm
