Post new topic Reply to topic  [ 9 posts ]
PostPosted: Wed Mar 06, 2013 10:22 pm
Hey guys,
After hearing creaks and clicking in my bike I got home and begun to go around checking everything over and I found this. This arm is only around 3months old too!
Less than ideal, but is it still rideable? At least for the mean time whilst a replacement is found? All thats missing is the self extracting bolt assembly so it is being held on by friction. Similar to a 3 piece crank arm.
And any ideas about how to remove this?
Cheers,
PostPosted: Thu Mar 07, 2013 1:17 am
I went through 4 pairs of the original K-force cranks in just over 2 years. I'd either rip the pedal insert out or delaminate it at the BB. I noticed that Spartacus was using gossamers relabeled as K-force during his CSC days. I feel your pain buddy.
PostPosted: Thu Mar 07, 2013 2:00 am
That is not safe to ride. Without any pinch bolts, friction is not enough to keep the arm secure. Once you obtain the self extracting bolt assembly, you can just install the assembly and then remove the arm. Kind of a catch 22 situation.
PostPosted: Thu Mar 07, 2013 3:14 am
This is why I choose NOT to ride with co-molded carbon/alloy cranks...they FAIL under consistent, high-wattage loads.
Due to the urging of all the ladies...I do NOT shave my legs!
PostPosted: Thu Mar 07, 2013 4:36 am
Darcy, there isn't any tearing of the metal or delamination of the carbon or seperation of the carbon from the aluminium is there? (hard to tell from the picture).....if there isn't......I can send you a bolt and extractor cap (I never use them anyway....I use an old-school crank puller) to tide you over until a matching one arrives. It's Geoff. Ring/txt me 021 2162328....get a bolt in it NOW.....and I'll send you a "semi matching one" while your replacement arrives.
Used to race....got too wrinkly and old ;) Updated: Racing again! Thought this was unlikely! Eventually, I may even have a decent race!
PostPosted: Thu Mar 07, 2013 5:04 am
Update,
So this is how I'm running it atm
Found a bolt from one of the other K-Force cranks I have been through. So this will hold it on. Just need to get another self extracting bolt set up and loctite it in and hopefully get my crank off.
What loctite would be best suited to holding the self extracting bolt in?
@Theremery The cranks fine from the looks of it. I need to get a new self extracting bolt set up so I'll just put one on order and I've got bolt in it now so I'll be sweet till then.
PostPosted: Thu Mar 07, 2013 5:14 am
That bolt, when adequately torqued, should render the bike safe to ride. I use Permatex threadlocker blue #24240 in this type of application. Your best bet is to stick with the blue threadlockers; do not use red.
PostPosted: Thu Mar 07, 2013 6:37 am
yep....just a low strength loctite will be fine. Red is overkill and may lead to dramas if you later decide to pull the crank using a standard extractor.
PostPosted: Thu Mar 07, 2013 9:49 am
I also happened to me. I bought two to spare. It seems to me very lightweight but very weak .
The screw i cost €8 each.
http://mikipov.blogspot.com.es/2012/07/mantenimiento-bielas-bb30.html
Users browsing this forum: dha, fiti, Kayrehn, Kermithimself, periodcorrect and 42 guests
This topic is locked, you cannot edit posts or make further replies. Sram Force crank vs Rotor 3D
rich00
Wed Mar 20, 2013 2:36 am
rich00 View the latest post
There are no new unread posts for this topic. SRAM Force crank upgrade to ?
PoorCyclist
Thu Apr 25, 2013 9:52 pm
gilesharrison View the latest post
There are no new unread posts for this topic. Force or Centaur?
alexh
31
874
Tue Apr 23, 2013 11:38 pm
alexh View the latest post
There are no new unread posts for this topic. Should I just force these two part together?
Y26
Mon May 13, 2013 11:26 am
SWijland View the latest post
There are no new unread posts for this topic. SRM K-Force Light PC 7 compatibility
DamoRider
Thu Dec 06, 2012 2:46 am
It is currently Sun May 19, 2013 1:33 pm
