Post new topic Reply to topic  [ 24 posts ]
Go to page Previous  1, 2
PostPosted: Fri Mar 08, 2013 3:46 am
The "bulgy" sleeve is indeed a Trek part and not a Shimano part.
From the factory, the SMBTR2 battery does not come with any type of adapter.
I used an o-ring around the battery, shoved it into the seatpost of my TCR (aero seatpost) and then made up the difference with packing foam - work's just fine.
Turn down the suck knob.
PostPosted: Fri Mar 08, 2013 4:53 am
Can this battery be charged through the "old" style junction box jc-4x if I disconnect a cable, or must this be through the new Ew-90-x models? Sorry if this is explained elsewhere I'm confused. Thanks.
PostPosted: Fri Mar 08, 2013 7:07 am
The charging port on the new junction box is some type of USB port separate from the other plugs. The charger does not plug into one of the cable ports. So you need one of the new junction boxes. Also need to update firmware.
PostPosted: Fri Mar 08, 2013 10:04 am
Battery, AKA round hole:
Charger, AKA square peg:
As far as I can see there is absolutely no way to connect the internal battery charger to the internal battery itself, you have to get the new junction box.
I've ordered the junction box from Bike24.net and will finally allow me to put everything together.
PostPosted: Fri Mar 29, 2013 4:24 am
Hi All,
i wondering if the following setups would work -
1) DIY or third-party charger
a) Cable Junction SM-EW67-A-E
b) Internal Battery SM-BTR2
c) Charger with DIY connector to plug into EW-SD50 cable
2) SM-BCR2 Charger
c) SM-BCR2 Charger, with DIY adapter to plug into EW-SD50 cable
With setup 1, the cost is reduced by not using 1 x SM-EW90-A junction, 2 x additional EW-SD50 and 1 x SM-BCR2 Charger (substitute with 8.4V, 0.4A charger).
With setup 2, the cost is reduced by not using 1 x SM-EW90-A junction, 2 x additional EW-SD50. The OEM charger is used for firmware updates.
Both setups are based on the assumption that the SM-EW90-A junction does not have any circuitry. It seemed to be the case as charging with SM-PCE1 can be done at any exposed connection - http://www.youtube.com/watch?v=Bh7XoKQzJ6A. Besides cost saving, the advantage of this approach is no hacking to the OEM parts is required.
PostPosted: Tue Apr 02, 2013 5:23 am
I just received the SM-BTR2 internal battery. To install in a seatpost, Shimano includes a plastic shim, some washers and a snap ring. These bits are only useful if your seatpost includes a Di2-ready/friendly sleeve.
I have an 27.2mm FSA K-Force seatpost from a stock Cannondale EVO Hi-Mod Di2 that includes such a sleeve. I don't know if FSA or Cannondale installed the sleeve, but it seems semi-permanent. Battery installation pics...
Alternative #1: a little foam and zip ties: http://glorycycles.blogspot.com/2013/03/Ultegra-Di2-Internal-Battery-Conversion.html
Alternative #2: ask a Trek dealer to help procure this elegant rubber leaf spring: http://www.bikerumor.com/2013/01/10/closeup-look-at-shimano-dura-ace-di2-9070-internal-battery-more/
PostPosted: Tue Apr 02, 2013 7:40 am
My LBS have just taken delivery of most of my Di2 parts. Apparently Shimano have specified how to design a seat post to hold the internal battery and secure it with the parts they supply. To date very few manufacturers have started to modify their seatposts to do this.
Riding my road bike in North Wales
http://www.strava.com/athletes/keith_robertson
PostPosted: Tue Apr 02, 2013 8:13 am
here's a scale shot with the battery installed...
PostPosted: Tue Apr 02, 2013 8:29 am
So, no more cutting down seatposts to save weight?
TED ESSENFELD
Schoorl, Noord-Holland, Nederland
Bike Pics
English Custom Steel Internal di2
Litespeed Ghisallo
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
Users browsing this forum: CarpetFibre, Google Adsense [Bot] and 35 guests
There are no new unread posts for this topic. Shimano 9070 internal battery harness
Bely
Sun Apr 14, 2013 12:19 am
There are no new unread posts for this topic. Shimano Di2 9070 Internal Battery BTR2 in a Thomson seatpost
steveorocks
9
832
Mon Apr 22, 2013 7:11 pm
steveorocks View the latest post
There are no new unread posts for this topic. Internal or external sapim Sils nipples?
poppiholla
Mon Jul 23, 2012 11:51 am
saroadie View the latest post
There are no new unread posts for this topic. Shimano 9070 in stock???
mnmasotto
11
837
Mon Apr 01, 2013 10:50 pm
petal666 View the latest post
There are no new unread posts for this topic. Shimano 9070 rear junction box
Horacio
Mon Mar 11, 2013 4:43 am
It is currently Fri May 24, 2013 9:03 am
Shimano Dura-Ace Di2 components at cheap prices - starbike.com
