Post new topic Reply to topic  [ 8 posts ]
 Post subject: GXP over BB86 Specific
PostPosted: Wed Mar 06, 2013 4:07 pm
Currently I have a GXP crank wiht the GXP to BB86 BB. Is it worth it to go to a straight BB86 setup?
Thoughts?
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=112078
PostPosted: Wed Mar 06, 2013 4:24 pm
Do you mean by just replacing the bearing? BB86 is a Shimano spec design, but there are GXP bearings that adapt that BB format for GXP cranks, but you can't run a GXP crank on a BB86 (Shimano) bearing.
2010 Trek Madone: viewtopic.php?f=10&t=115249
2012 Trek SpeedConcept
2012 Trek Cobia
2013 Trek Superfly: viewtopic.php?f=10&t=115542" onclick="window.open(this.href);return false;
PostPosted: Wed Mar 06, 2013 4:41 pm
My SLR01 accepts BB86. I am looking to not do the SRAM GXP conversion. Is it worth it to go BB86 crank with BB86 BB?
PostPosted: Wed Mar 06, 2013 4:56 pm
There are no BB86 cranks. BB86 bottom brackets are designed to work with specific GPX or HT2 cranks.
"Step forward the climber and all those who worship at the altar of lightness" - R. Millar
PostPosted: Wed Mar 06, 2013 5:24 pm
BB86 is essentially a press fit version of BSA.
PostPosted: Wed Mar 06, 2013 7:40 pm
SRAMs own bb86 set is paractically the same as the Shimano one with an adapter workaround. The step-down on the left bearing is built in, that's about it. Key with gxp on any pressfit system is getting the wavy washer on the right side as flat as possible without actually being flat.
PostPosted: Wed Mar 06, 2013 10:24 pm
How much weight does the adapter workaround weigh vs straight shimano...?
PostPosted: Thu Mar 07, 2013 3:10 am
^ Essentially none. They are the exact same thing, a plastic cup on each side with a bearing. The internal diameter of the non-drive side bearing is just a little smaller with the GXP vs. the Shimano.
Really the weight difference is the weight difference of the crank.
It is not really a conversion. Essentially you are just pressing in the appropriate BB for your crank. I think some BBs like the Chris king have sold a small sleeve for an adaptor but I am not sure they work terribly well.
Users browsing this forum: Bing [Bot], CBJ, dj97223, Exabot [Bot], Google [Bot], Google Adsense [Bot], highwater, lechat, wrcompositi and 52 guests
There are no new unread posts for this topic. BB86 help
btompkins0112
11
642
Tue Feb 26, 2013 5:40 pm
ms6073 View the latest post
There are no new unread posts for this topic. BB86 installation help
liam7020
7
575
Mon May 20, 2013 9:39 am
liam7020 View the latest post
There are no new unread posts for this topic. fsa bb86/ultegra c.set do they work together.
SDP
Mon Aug 27, 2012 10:17 pm
There are no new unread posts for this topic. BB86 to ISIS conversion? Anything out there?
pawnii
9
503
Tue Jan 29, 2013 12:57 am
pawnii View the latest post
There are no new unread posts for this topic. BB86 ultra torque compatible?
rhyslewisdavies
Mon Jun 04, 2012 9:00 am
rhyslewisdavies View the latest post
It is currently Thu May 23, 2013 1:50 am
