It is currently Sat Oct 21, 2017 7:13 pm
Post new topic  Reply to topic  [ 4 posts ]
PostPosted: Wed Mar 06, 2013 12:35 am
I was planning a gradual upgrade to 11 speed, can I use a DA 9000 rear derailleur with DA 7900 10speed shifters and 10 speed wheels. I understand the derailleur pull ratio has been matched to the DA 9000 shifters, but I don't think that would be much of a problem as the shifter type controls the pull ratio.
Just wanted to confirm before swapping out the rear derailleur, thanks for any advice.
PostPosted: Wed Mar 06, 2013 3:24 am
The shifter type determines its pull ratio. The derailleur is intended for a particular pull ratio, and for the most part won't work without it.
9000 derailleurs and 7900 shifters will not work together.
PostPosted: Wed Mar 06, 2013 3:34 am
I've seen people mix 9 and 10 speeds. But I think you're better off getting matching sets than experimenting. :D
http://www.roadiemanila.com
PostPosted: Wed Mar 06, 2013 4:58 am
Thats because 9 and 10 speed shifters share the same pull ratio, where as 11 speed shifters pull a different amount of cable. The anchor point of the RD is different as well leading to no compatibility.
There are no new unread posts for this topic. Dura ace 9000 rear derailleur?
sinjun
Mon Apr 10, 2017 6:02 am
richscott View the latest post
There are no new unread posts for this topic. Campy Rear Derailleur Compatibility
tomato89
Mon Nov 21, 2016 2:44 am
joeyb1000 View the latest post
There are no new unread posts for this topic. 9100 bar end shifters or 9000 cross compatibility
ultyguy
Thu Feb 16, 2017 11:05 pm
tokyodrift69 View the latest post
There are no new unread posts for this topic. Shimano Dura Ace 9000 free hub body backward compatibility?
BeeBee30
Wed May 17, 2017 7:32 am
petal666 View the latest post
There are no new unread posts for this topic. Compatibility between etap front derailleur and the 53-39 Q-ring
Eclat
Wed Mar 08, 2017 6:11 pm
1415chris View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], Delorre, DiegoMendes, Google [Bot], kordis1, Yahoo [Bot] and 42 guests
