Post new topic Reply to topic  [ 6 posts ]
PostPosted: Tue Mar 05, 2013 7:28 pm
Hi everyone!
I bought a used 5-year old SRM Dura-Ace 7900 power meter. It's been used only about 500h by a pro cyclist few years ago.
Anyway, when I first time did the zero offset, the value was 6500 +-10, so pretty stable, but the reading was insanely high!
Well I didn't mind and went for a ride. The power seemed to be way too low. Went back home, did a calibration check with a 10kg weight and changed the slope from 19.6 to 16.1.
After that I went out again, and the readings were somewhat normal. At least I think so. Did few sprints and the max power was about the same I knew I could do.
So do I have a problem here? Should I send it to SRM or just leave it like this _if_ it works well? Only one (or actually two) ride(s) done.
Thanks for your help.
PostPosted: Tue Mar 05, 2013 7:46 pm
5 years old, with original batteries?
assuming it's using the ltc-7pn, according to the spec. sheet an isolated battery has c. 10-year shelf life, there must be more drain than that even in an idle srm so it's probably due for some new batteries and a calibration
PostPosted: Tue Mar 05, 2013 8:09 pm
When you have an SRM, you should be able to say more than "max power was about the same I knew I could do."
I understand what you mean, but I'd send it in. Then you can check your own calibration method against the factory-calibration. It's worth it.
I love you guys. Seriously.
PostPosted: Tue Mar 05, 2013 10:13 pm
Kraaf as sungod mentioned maybe it's the batteries and a second opinion check the magned maybe it's not in the right position.
Panther
motivation can't take you very far if you don't have the legs
PostPosted: Tue Mar 05, 2013 10:40 pm
If you are mechanically inclined and know what digital VOM stands for, since the SRM is way out of warranty, I suggest that you pop off the back cover and measure the voltages of the batteries and compare to the spec printed on the label of the battery. If the measured voltage is more than .25-.35 volts below spec, time for new batteries.
PostPosted: Wed Mar 06, 2013 3:45 am
And make sure you measure the battery voltage when it's under load. I think turning the SRM on by waving a magnet by the reed switch will do.
Users browsing this forum: addictR1, Bing [Bot], Google Adsense [Bot], mdeth1313, nickel, Yahoo [Bot] and 49 guests
There are no new unread posts for this topic. Offset, 2-bolt seatposts
MileHighMark
10
423
Tue Mar 19, 2013 2:42 am
MileHighMark View the latest post
There are no new unread posts for this topic. SRM zero offset fluctuation after battery change
pcates
11
289
Thu Apr 18, 2013 12:04 am
Squint View the latest post
There are no new unread posts for this topic. Dura Ace FC-7900 chainring width offset?
hjb1000
Mon Jul 16, 2012 7:01 am
pawnii View the latest post
There are no new unread posts for this topic. SRM and Garmin Edge 800 - incorrect slope and offset
djm
12
1381
Fri May 17, 2013 8:27 pm
djm View the latest post
There are no new unread posts for this topic. For the SRM Gurus.. offset change with new crank arm install
ParisCarbon
15
599
Mon Dec 31, 2012 5:48 pm
ms6073 View the latest post
It is currently Sat May 25, 2013 11:58 pm
