Post new topic Reply to topic  [ 22 posts ]
Go to page Previous  1, 2
PostPosted: Mon Mar 04, 2013 8:56 pm
LionelB wrote:
Is the Parlee Z0 out yet on the road ?
I haven't read an actual road review so I'm assuming it's not out yet. Proud owners of these are usually quick to post opinions.
PostPosted: Mon Mar 04, 2013 9:01 pm
If a stock frame fits you and your usage, there's nothing wrong with it.
When adding up the weight penalty of discs, don't forget to include the rotors themselves, the heavier hubs plus bolts and adapters. In addtion to the levers, cables/hoses and calipers. If the best currently available disc system is only 250g more than say EE brakes (remember this is a high end WW build) I would be very surprised.
Personally I think it'd be a shame to built a super expensive custom WW bike and hang the heavy current technology disc brakes on it, but it's your bike.
PostPosted: Mon Mar 04, 2013 9:40 pm
We should be clear in regards to the Parlee Z0:
It has the options of disc brakes or Standard brakes.
I don't want others to get the impression it only comes with disc brakes (it doesn't. It is totally custom in every way).
Just take a look at the website (www.parleecycles.com) the first two pictures are of a Z0 without disc brakes and the next couple are of a Z0 with disc brakes.
If you want a total WW build you would not want disc braks. Sure you get get one pretty light, but it is not an "all-out WW build" type of frameset.
PostPosted: Mon Mar 04, 2013 10:32 pm
The geometry on the Storck and the Cervelo are so dramatically different it's clear you've given the fit issue little consideration.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Mon Mar 04, 2013 11:28 pm
True -- although I realize fit is a key aspect, I did not consider it of paramount importance. I was under the impression that a proper fitting session for whatever frame I chose would provide a "good enough" fit -- not perfect, but good enough.
I guess the R5CA, being no longer in production, is out.
PostPosted: Mon Mar 04, 2013 11:47 pm
Depends on how "enough" that is. For example I'd balk at an expensive frame which required me to use a 9cm stem or a 14cm stem to get the bars in the right place or whose head tube was too long to get the bars low enough.
PostPosted: Tue Mar 05, 2013 1:37 am
Point well taken -- proper fit is critical.
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
Users browsing this forum: BeeSeeBee, Bing [Bot], Exabot [Bot], FastTarik, Google [Bot], Google Adsense [Bot] and 40 guests
There are no new unread posts for this topic. Which to Build - Opinions req'd...Tommasini Tecno or C40
haydos
26
1881
Mon Nov 26, 2012 2:52 am
haydos View the latest post
There are no new unread posts for this topic. Vittoria Corsa Evo SC opinions
wassertreter
Fri Jul 06, 2012 11:18 am
fdegrove View the latest post
There are no new unread posts for this topic. Superfeet yellow opinions
MaxDaddy
11
734
Wed Jan 16, 2013 3:46 pm
spytech View the latest post
There are no new unread posts for this topic. Colour coding opinions?
alexh
16
443
Tue Apr 16, 2013 12:30 am
alexh View the latest post
There are no new unread posts for this topic. Opinions - CX bike as a winter roadie?
alexh
23
469
Mon Apr 22, 2013 3:27 pm
It is currently Sun May 19, 2013 12:40 am
