Post new topic Reply to topic  [ 7 posts ]
PostPosted: Sat Jan 24, 2004 12:36 pm
I have 2 speedneedle saddles that I can try out. But the rails are 8mm... Anyone know any seatposts that are compatible?
I have Thomson posts, but they can only be used with 7mm saddle rails...
I can get Tune posts cheap, but don't know if there are different kinds... Although their posts should fit their saddles...
PostPosted: Sat Jan 24, 2004 12:46 pm
http://weightweenies.starbike.com/forum ... .php?t=597
The Easton seatposts will work.
 Post subject:
PostPosted: Sat Jan 24, 2004 5:57 pm
I have a Thomson post with a Tune Speedneedle on and that works fine, no problem there !!!
 Post subject:
PostPosted: Sat Jan 24, 2004 6:02 pm
I use a Speedneedle with a WR carbon post
 Post subject:
PostPosted: Sat Jan 24, 2004 7:34 pm
I tried them with a Thomson post at work, I didn't tighten the bolts really hard, just enough to see if it would fit... The marathon fitted perfect, but the lighter saddle (109gram version, full carbon rails) had a small gap between the clamp and the rails... Maybe tightening it to the correct tension would press it in, but since Thomson only guarantees a perfect fit with 7mm saddle rails, I didn't want to risk it...
I think I'll just try the marathon on a Thomson then, and maybe get a Tune post or something for the other saddle...
@Joel, thanks for the link, since I was at work, I didn't have a lot of time to search the forum...
 Post subject:
PostPosted: Mon Jan 26, 2004 12:35 am
My Speedneedle is with the alu rails, and they are 7mm that's why they fit :D
 Post subject:
PostPosted: Mon Jan 26, 2004 9:54 am
I put the one with aluminum rails (carbon rails with aluminum shell) on the Thomson and tried for a 90 minute training on the Tacx and it worked fine... Will try it on a real ride when it stops raining...
Haven't tried the full carbon one, since I don't want to risk breaking it...
Users browsing this forum: Bing [Bot], Google Adsense [Bot], gravity and 39 guests
There are no new unread posts for this topic. 89 gram Tune Speedneedle?
CGT
Mon Oct 08, 2012 9:21 pm
CGT View the latest post
There are no new unread posts for this topic. Attachment(s) Carbon wearing away on speedneedle, recommendations?
kman
Tue Jan 22, 2013 11:36 am
kman View the latest post
There are no new unread posts for this topic. Attachment(s) Tune Speedneedle owners out there!! Saddle Height? :) :)
Estuche
Mon Oct 08, 2012 5:37 pm
Estuche View the latest post
There are no new unread posts for this topic. Specialized Srm - BB compatibility
micky
Sat Apr 20, 2013 10:35 pm
Machinenoise View the latest post
There are no new unread posts for this topic. Campagnolo BB compatibility.
Lewis
22
903
Fri Jan 25, 2013 8:44 am
paddyrider View the latest post
It is currently Sat May 25, 2013 11:46 am
