Post new topic Reply to topic  [ 3 posts ]
PostPosted: Thu Feb 28, 2013 12:16 pm
Hi Guys,
have a question regarding this setup.
I have followed the Rotor manual and have this going from non drive side to drive side:
Crank arm and preload nut - washer 1mm NO DUST SEAL - BB - NO DUST SEAL large conical spacer - Crank arm.
Something doesn't seem right, the manual says to only use the dust seals on bare bearings without a shell but I am not sure? I also have no 'wavy' washer installed.
Does anyone have any experience of this setup on the BBright cervelos?
Cheers
James
PostPosted: Thu Feb 28, 2013 12:29 pm
The manual states no dust shields because it assumes there will be some present from the pf30 bb assembly. So yes, use the dust shields that say SRAM pf30. Do not use any wavy washer, the crank has the preload collar that does the wavy washer's job.
Last thing is most Cervelos I've built required the extra 1mm spacer to be left off. Installing it resulted in binding. So don't be afraid to leave yours off if you need to.
PostPosted: Thu Feb 28, 2013 1:14 pm
Awesome, thanks for the quick response. The crank is indeed binding with the 1mm spacer.
Users browsing this forum: ewwhite, Google Adsense [Bot], Rey and 46 guests
There are no new unread posts for this topic. SRAM Truvative Pressfit 30 BB
Horacio
Sun Nov 11, 2012 5:15 pm
Horacio View the latest post
There are no new unread posts for this topic. Rotor 3D+ vs Sram Red for bbright
1415chris
22
2352
Wed Nov 21, 2012 3:28 am
There are no new unread posts for this topic. Rotor 3D+ compatible with Sram Red 2013 Yaw???
Naturel
Thu Jan 03, 2013 5:38 pm
CharlesM View the latest post
This topic is locked, you cannot edit posts or make further replies. Sram Force crank vs Rotor 3D
rich00
Wed Mar 20, 2013 2:36 am
rich00 View the latest post
There are no new unread posts for this topic. Rotor Power Crankset with Sram Yaw Chainrings?
trtimothy
7
646
Sun Jan 06, 2013 3:20 am
refthimos View the latest post
It is currently Thu Jun 20, 2013 9:27 am
