Post new topic Reply to topic  [ 20 posts ]
Go to page 1, 2  Next
 Post subject: New fork for TI frame
PostPosted: Wed Feb 27, 2013 6:35 pm
I am looking to upgrade the fork on my Dean TI bike. At the present time in is sporting a Ritchey pro fork from 2006.
I am seeing some light stress cracks were the drop outs are glued into the fork body. I am not sure if they are just in the finnish or into the carbon. So to be safe I will be replacing the fork in the next few weeks. This one has the alloy drop outs glued into the fork body. I am looking for a one piece fork. (No glued in drop outs).
This bike has a long HT so I need a 43degree fork with a steer tube of about 220cm. It will have a 10cm spacer below the stem and a 10cm spacer above the stem. It will be going into a standard TI king HS. I would also like straight fork legs as opposed to curved.
I would like a few options for a replacement.
ENVE 2.0 is at the top of my list. Any other I should look at?
Thanks
Skiezo
PostPosted: Wed Feb 27, 2013 8:07 pm
Just putting in my vote for the Enve. I have one on my Ti bike and have been very pleased!
PostPosted: Wed Feb 27, 2013 9:03 pm
I'd also have a look at the 3T Funda Team
http://www.3tcycling.com/forks/funda
PostPosted: Wed Feb 27, 2013 10:23 pm
ive owned the 3t fork. they dont look as nice in person. its actually an "aero" for and looks a bit funny (to me) from some angles. also the headset compression system is a little bit annoying. there is an alloy sleeve that you need to glue in. actually not a bad idea but you do need to let the epoxy dry over night before riding.
enve 1.0 would be my first choice.
PostPosted: Thu Feb 28, 2013 12:30 am
Administrator
I love my Alpha Q GS 30 on my Lynskey R320. I know they are not made anymore and that is why I have a new one stashed.
Are the forks your considering the same dropout to crown length?
PostPosted: Thu Feb 28, 2013 12:42 pm
I've just gone enve1.0 on my litespeed archon Ti. fantastic upgrade.
Di2x2
PostPosted: Thu Feb 28, 2013 2:02 pm
i had an Enve 2.0 on my Litespeed. one of the better upgrades on that frame. prior to...had a Reynolds Pro Ouzo with alloy steerer. the Enve felt like it dampened more road vibration.
- Storck Fenomalist + Campy SR11 + Enve 45
- Parlee Z5 SL + DA7900 + Enve 3.4
PostPosted: Thu Feb 28, 2013 4:32 pm
That is a great question?????
On my spec sheet from the build in 05 it lists the dropout to crown length as 372mm and 43degree rake.
All the forks I have found are 368mm in 43degree rake.
I can not find any spec on the alpha Q forks.
I did find this tho and I will be looking at it in more detail before I drop the $$$$$$
http://sheldonbrown.com/rinard/forklengths.htm" onclick="window.open(this.href);return false;
So will 4mm shorter make that much of a difference in the ride or handling?
PostPosted: Thu Feb 28, 2013 4:54 pm
Administrator
The Alpha Q is 371mm and so is the THM fork. King does make a crown race that os 5mm taller than the standard but i think its fugly.
Will you notice? Maybe. You might also have to change the level of your bars.
PostPosted: Thu Feb 28, 2013 9:30 pm
4mm shorter axle to crown will correspond to an effective ~0.25 degree increase in head-angle. Whether that's something that you'll notice or care about only you can really answer. But unless you think the steering on your bike is already really fast, I'd say that you'll be fine with the change.
Enjoying my Funk
PostPosted: Fri Mar 01, 2013 12:40 am
Think about what sorts of rims and tires you want to use.
It was recommended to me that if I want to run 25c tires, go the Enve over the 3T. My Enve 2.0 fork will just fit Michelin Pro Optimum 25c on Hed Belgium 23 mm rims. I think the Michelin 25c tires are on the larger side, compared to a Continental for example.
I doubt you'd get enough clearance on a 3T fork to run that.
PostPosted: Fri Mar 01, 2013 3:40 am
I found a NOS EDGE branded fork from an online retailer. It has a crown to dropout length of 371mm and a 43degree rake. So it is about as close as I can find spec wise to my existing fork. I run a 25 on the rear and a 23 on the front so clearance will not be a problem. I ordered it today so it should be here the middle of next week.
I have a EVNE 1.0 fork on my steel bike that I had built so I now of the quality of there products.
Thanks
Skiezo
PostPosted: Fri Mar 01, 2013 4:06 am
After 2 other carbon forks, I put an Enve 1.0 on my Merlin CR Works. I absolutely love it.
PostPosted: Fri Mar 01, 2013 4:19 am
I've only ever had the chance to ride the funda, but I've always been green for the enve.
PostPosted: Fri Mar 01, 2013 10:15 am
Tinker, Taylor, Tart
Pegoretti Falz.
Post new topic Reply to topic  [ 20 posts ]  Go to page 1, 2  Next
Users browsing this forum: kya, n8davies, sugarkane and 36 guests
There are no new unread posts for this topic. Buying a CAAD 10 frame/fork?
jjones
13
1220
Thu Jan 24, 2013 3:55 pm
yourdaguy View the latest post
There are no new unread posts for this topic. 2012 Caad8 frame and fork weight
RMcC
Fri Aug 10, 2012 2:43 pm
RMcC View the latest post
There are no new unread posts for this topic. Question about fitting after market fork to a frame
veloman
Thu Jun 28, 2012 6:57 am
michel2 View the latest post
There are no new unread posts for this topic. Fitting the proper fork and headset to a frame
LouisN
Fri Feb 22, 2013 2:30 am
There are no new unread posts for this topic. 2013 Giant TCR SL frame/fork weights
Ryan94
19
1342
Tue Jan 01, 2013 1:57 pm
Firetrail View the latest post
It is currently Sat May 18, 2013 9:34 am
