Post new topic Reply to topic  [ 24 posts ]
Go to page 1, 2  Next
PostPosted: Tue Feb 26, 2013 1:10 am
The other month I thought about making a pair of super light road/mtb shoes from carbon, but it would've been just a bit to much for my experience with carbon at the moment, so the next best thing was to buy a pair of what is one of the lightest football boots out there (adidas f50 adizero) and convert them!
Its a bit easier for me to do this because I use SPD's and Mid Sole Cleats.
So, here's how it went:
First weight the shoes with insole and laces,
Right ~ 165
Left ~ 163
Next up is to trim the studs and try to make the bottom as flat as possible for the 7 layers of carbon.
16 grams saved from the trimming of the right, trimmed the left more.
Slap 7 layers of carbon onto the bottom and roughen them up for clear coat.
Put a couple of layers on the inside for the cleat fixings.
Weight without insoles and laces.
Needed to add a carbon wrap over and under the toe to help the carbon sole remain in contact with the plastic base (my first pair lifts off after months of walking around).
Clear coat. Should've done the toe wrap first.
Fit cleats and weigh.
Left 241g
Right 238g
Each shoe was just over 200g before cleats and fixings.
So, after all that work, I have a pair of race shoes which are nearly half the weight of my actual races shoes I have been using for years (modified mtb shoes)!
Because the F50's are so cheap on ebay (around £20/$30), I am going to get myself a few more pairs and make some summer ones with lots of vents, and I plan to see if I can remove the original plastic sole and save myself maybe 80g+ a shoe!
Because I was surprised how flexible a single layer of carbon is, I decided to finish of by making some toe warmers!
This one weighs 12.8g and is obviously not perfect, so I will have a few more tries and see if I can get it looking a bit nicer :)
PostPosted: Tue Feb 26, 2013 1:27 am
Love it- great work. Let us know how they hold up!
Speedplay is the devil.
PostPosted: Tue Feb 26, 2013 1:32 am
Location: somewere floating between here and the other side
Midsole cleats ? Do you use these for "normal"ridding purposes ?
PostPosted: Tue Feb 26, 2013 2:11 am
midsole cleats it's quite popular in triathlon apparently.
Happy Trails !!!
MTB / Giant Xtc '05 / 8.7Kg
ROAD / La Perla Negra - FM015 / 7.0Kg
PostPosted: Tue Feb 26, 2013 2:46 am
Awesome!
PostPosted: Tue Feb 26, 2013 3:41 am
That's awesome! How stiff are they compared to your normal road shoes?
I also really like the carbon toe warmers, I just wonder about breathability. You could use the carbon like you have done to make a bracket, and then perhaps glue some water proof breathable fabric in place. There is some pretty light stuff out there, like the 1.4oz per square yard cuben fibre (47gsm). A 10x15cm piece of that would come in around 0.7grams.
PostPosted: Tue Feb 26, 2013 4:00 am
That's a pretty cool idea. You will be able to make some really cool stuff with carbon fiber! 8)
PostPosted: Tue Feb 26, 2013 4:39 am
Nice project. Thanks for sharing. First time I've seen midsole cleats.
I just made some custom commuter shoes last month. They're not weightweenie so I won't post them, but isn't it a fine feeling riding around in shoes you made yourself?
PostPosted: Tue Feb 26, 2013 4:43 am
How did you source the carbon fiber? What was the process to mold and cure it?
PostPosted: Tue Feb 26, 2013 11:22 am
Cool project!
Not that far back! :unbelievable:
I ride "mid sole" (speedplays with the aluminium baseplate) as it saves my calves to run off the bike.
Makes a big difference, but I couldnt imagine riding with the cleats that far back. Would be very weird climbing out of the saddle!
PostPosted: Tue Feb 26, 2013 11:48 am
Formerly known as CAADHEAD
Isn't a cleat positioned there gonna cause problems with toe overlap on the front wheel?
Ti or dye!
PostPosted: Tue Feb 26, 2013 2:37 pm
You have a point there. Looks like you would have a half a foot into the wheel area.
PostPosted: Tue Feb 26, 2013 2:45 pm
Shop Wrench
Have you ridden these yet? I find that generation of f50's to be extremely flexible and generally unsupportive. Not sure how well they would translate to a cycling shoe.
PostPosted: Tue Feb 26, 2013 5:44 pm
Not to mention he probably has to really watch it in the corners as I would think it would be quite easy to catch the shoe on the ground if pedaling during hard cornering. :shock:
PostPosted: Tue Feb 26, 2013 5:56 pm
Interesting project, but I would think mid cleats on such a flexible sole is not gona be much good.
I wouldn't like to pedal hard with my arches.
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
Users browsing this forum: bigkraig, Bing [Bot], Exabot [Bot], Google Adsense [Bot], Majestic-12 [Bot] and 41 guests
There are no new unread posts for this topic. Homemade full carbon shoes.
megalightman
Tue Jan 29, 2013 9:00 am
Burgunder View the latest post
There are no new unread posts for this topic. Homemade Hubset Project. Ratchet ring question
swimmingskibble
Thu Oct 18, 2012 7:13 am
WMW View the latest post
This topic is locked, you cannot edit posts or make further replies. Anyone tried the D2 custom shoes?
JWolf
Fri Jul 27, 2012 5:42 am
JWolf View the latest post
There are no new unread posts for this topic. Giro empire shoes
brearley
Sun Jan 13, 2013 5:54 am
russianbear View the latest post
There are no new unread posts for this topic. Attachment(s) Shimano R320 shoes
boots2000
29
4012
Wed Apr 10, 2013 12:38 am
blaireau View the latest post
It is currently Fri May 24, 2013 12:55 am
