Post new topic Reply to topic  [ 71 posts ]
Go to page Previous  1, 2, 3, 4, 5
PostPosted: Sat Mar 09, 2013 3:18 pm
Tubbie Guru
Hi,
Quote:
I use slickoleum also known as buzzy's honey.
That's a calcium grease similar to Galli (among others) in Europe. I quite like those as well.
For the Ceramic bearings you really ought to give Krytox grease (or oil if you're feeling adventurous) a shot. It's really great as it bonds to metal reducing friction noticeably.
Ciao, ;)
PostPosted: Sun Mar 10, 2013 11:45 am
I would love to have tried the Kytox. Problem is getting some to try in AU, and then getting some in a sell-able size to sell in the shop. When it comes to grease etc customer would really like to spend on say $15-Kytox is pretty expensive to have in a size that would retail for that much even if I could get it. A 1 or 2oz tube would be perfect.
signature deleted by the Admin.
PostPosted: Sun Mar 10, 2013 12:09 pm
Hi Phill P, I am getting the Krytox 105/205 from amazon (USPS to Oz) and they are 1oz/28g and 2oz/56g quantities ... http://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=krytox+gpl&rh=i%3Aaps%2Ck%3Akrytox+gpl
thanks KL :)
PostPosted: Sun Mar 10, 2013 12:12 pm
Tubbie Guru
Hi,
Maybe Dupont de Nemours has a sales office, agency or whatever in Oz?
This is the Krytox grease Ceramic Speed offers:
It contains 10ml of 225 Krytox grease which is ample for servicing a single bike in most cases. Like everything else Ceramic Speed it is a bit pricey at 8 Euro a pop but I think it's worth it though.
Ciao, ;)
PostPosted: Mon Mar 11, 2013 7:31 am
Looks similar (or exactly the same) to what you get with a ceramic SRAM bottom bracket?
Storck Fenomalist 6.8kg
PostPosted: Mon Mar 11, 2013 1:05 pm
Tubbie Guru
Hi,
It is exactly the same Krytox grease FSA uses for their ceramic hybrid bearings which AFAIK are ABI Enduro sourced.
I guess it's type GPL 225 or something at Dupont's.
Ciao, ;)
PostPosted: Tue Apr 09, 2013 10:00 am
I have just used the Krytox105 oil on the pawls and seals, in conjunction with R&R Red Devil grease, and repacked the main ABEC5 Sealed Bearings with Krytox205 grease.
So far, it seems to be very good and very smooth. The R&R Red Devil grease makes the pawls very quiet without affecting their spring action :)
thanks KL :)
PostPosted: Tue Apr 09, 2013 12:02 pm
I just put in an order for Ceramicspeed grease together with some Enduro grade 5 bearings. Let's see if I can get my Dura Ace 7700 hubs even smoother than they already are :)
My Renovo R1 wooden bike project
Check it out: the most amazing vintage Colnago, Merckx and Pinarello collection
PostPosted: Tue Apr 09, 2013 2:10 pm
BobDopolina wrote:
...Shimano, Novatec and most others use thicker greases with varying adhesion properties and higher viscosities. They also use more of it. This makes a quieter mechanism.
Bob - can you advise/recommend which to use on Novatec hubs (A291SB-SL / F482SB-SL)?
PostPosted: Tue Apr 09, 2013 8:21 pm
Hi SWijland, ABEC5 Sealed Bearings use Grade10 SS balls ... let us know how it goes :)
thanks KL :)
PostPosted: Wed Apr 10, 2013 2:52 pm
thanks KL :)
Hi All, after some testing with using the Krytox105 oil and 205 grease, well, I have changed my mind.
I would not use Krytox205 grease anywhere on a bike, but maybe the Krytox225 grease is ok :)
I have found that the Belray Waterproof grease (or the Nulon Extreme Performance Grease) is better (much better).
This is what I did and recommend (unless the manufacturer states otherwise) ...
For sealed or loose bearings I use Belray Waterproof grease (or the Nulon Extreme Performance Grease).
The FreeHub I have has a needle bearing so I applied a generous amount of Belray Waterproof grease to this bearing.
For the pawls I smeared a generous amount R&R Red Devil grease around them (it does not stick), a small amount on the ratchet teeth, and a small amount on the seal.
At least for my hub it now spins and freewheels nicely :)
thanks KL :)
Post new topic Reply to topic  [ 71 posts ]  Go to page Previous  1, 2, 3, 4, 5
Users browsing this forum: 1415chris, Bing [Bot], Google [Bot], Google Adsense [Bot], lechat, octav, verycreativeusername and 39 guests
There are no new unread posts for this topic. Groupset mounting bolts... to grease, or not to grease?
Stats
Tue Dec 25, 2012 12:09 am
yourdaguy View the latest post
There are no new unread posts for this topic. Road shoes - Ratchet vs Lace-ups
dillonko
Wed Mar 13, 2013 4:16 pm
VMac View the latest post
There are no new unread posts for this topic. Homemade Hubset Project. Ratchet ring question
swimmingskibble
Thu Oct 18, 2012 7:13 am
WMW View the latest post
There are no new unread posts for this topic. Campy UT Crank Cult Bearings - Replace or just re-grease.
JWolf
10
659
Sat Aug 04, 2012 9:03 am
Mattias Hellöre View the latest post
This topic is locked, you cannot edit posts or make further replies. dt swiss 240s freehub
ColnagoJohn
Tue Mar 05, 2013 1:59 pm
maverick_1 View the latest post
It is currently Tue May 21, 2013 9:52 am
