Post new topic Reply to topic  [ 71 posts ]
Go to page 1, 2, 3, 4, 5  Next
PostPosted: Mon Feb 25, 2013 10:31 am
Hi all, just wondering what you would consider is the best Hub Ratchet and Freehub Pawl grease that you use or recommend ... thanks :)
PostPosted: Mon Feb 25, 2013 11:09 am
Shop Owner / Manufacturer
What hubs will you use?
Do you want quiet hubs or can you deal with a little ratchet sound?
BDop Cycling Co., Ltd.
www.bdopcycling.com
PostPosted: Mon Feb 25, 2013 11:37 am
Hi BobDopolina, ahh, so there's not one grease that does it all, in this area ... lets say sealed bearing hubs, sealed bearing freehubs with or without a needle bearing, and quiet or louder ratchet sound is ok (such as the Novatec hubs/freehubs that you sell) ...
Also, it would be interesting to read your opinion on other types of hubs and freehubs ... thanks
PostPosted: Mon Feb 25, 2013 12:03 pm
Administrator
Bearings and free hub pawls need different types of grease or oil. While your bearings like grease that is sticky and high in Teflon. Your free hub pawls want a grease that is sticky, as in it adheres to the metal surface, but it should be soft enough to let the pawls move. Some hubs even use oil for the pawls.
There are do it all products, but those are just not as good as specific products.
Follow me on twitter. I try to be interesting ;)
On Facebook!
PostPosted: Mon Feb 25, 2013 12:20 pm
Campagnolo uses a grease from Kluber that is very light but with fantastic adhesion properties. This allows the freehub to spin and the Paul's to work with less resistance. It also means they use less grease. These two factors make for louder hubs.
Shimano, Novatec and most others use thicker greases with varying adhesion properties and higher viscosities. They also use more of it. This makes a quieter mechanism.
I don't have any numbers to illustrate my pint but I think you get the general idea.
Personally I like the sound of Campagnolo hubs and use Kluber grease.
www.bdopcycling.com
PostPosted: Mon Feb 25, 2013 12:34 pm
Hi BobDopolina, do you also like the Kluber grease for freehubs that have needle bearings and can it also be used with cone and bearing hubs like Shimano.
Hmm, Campagnolo are cone and bearing hubs, so I guess it can be used for cone and bearing hubs ... that would make it a one grease that does it all, wouldn't it :)
Which Kluber grease do you use?
One grease that has been recommended to me was RocknRoll Red Devil ... have you used it before, if so how does it compare to Kluber.
PostPosted: Mon Feb 25, 2013 12:50 pm
I use Rock n Roll Super Web Grease in my Campag hubs. Works well with the bearings and the pawls.
PostPosted: Mon Feb 25, 2013 1:23 pm
IIRC the R&R grease is similar to Bull Shot from years ago. It was good grease with great adhesion but t was certainly much more viscous than the Kluber grease Campagnolo uses.
I'n not in my office so I don't know which grease I got from Kluber a few years ago. Have a look at their website.
www.bdopcycling.com
PostPosted: Mon Feb 25, 2013 1:51 pm
Hi BobDopolina, I had a look and there are many Kluber greases ... do you mind checking when you can ... thanks :)
I also notice that they do chain waxes which look quite interesting :)
PostPosted: Mon Feb 25, 2013 2:19 pm
Hi 5 8 5, I wonder how similar RnR Red Devil and Super Web grease are. I have some RnR Super Web grease and I also have some Belray Waterproof grease.
Belray Waterproof grease is probably a little to sticky for pawls, but I guess I could always add a little teflon oil to it ...
RnR Super Web grease seems a little thin and not sticky enough, but perhaps that it ok ...
PostPosted: Mon Feb 25, 2013 2:44 pm
Kluber NB52
www.bdopcycling.com
PostPosted: Mon Feb 25, 2013 3:23 pm
Hi BobDopolina, thanks ... I will check it out :)
PostPosted: Mon Feb 25, 2013 3:36 pm
For pawls and freehubs a light motor oil will be fine. (5w30).
I have also used automotive bearing grease with good results. Light on the grease.
PostPosted: Mon Feb 25, 2013 3:45 pm
Hi stella-azzurra, won't light motor oil water washout quite easily (guess that depends on how good/tight the seals are) :)
PostPosted: Mon Feb 25, 2013 4:50 pm
You can use thicker motor oil if you ride in the rain a lot.
But then you can also use the high temp automotive bearing grease.
Just a light mount.
The seals should keep the bigger particles of dirt out.
I really avoid riding in the rain and road that have gravel which keep my maintenance intervals at a minimum.
Post new topic Reply to topic  [ 71 posts ]  Go to page 1, 2, 3, 4, 5  Next
Users browsing this forum: _scott_, adhumston, BeeSeeBee, Bing [Bot], G6612, LinasR, martroy and 65 guests
There are no new unread posts for this topic. Groupset mounting bolts... to grease, or not to grease?
Stats
Tue Dec 25, 2012 12:09 am
yourdaguy View the latest post
There are no new unread posts for this topic. Road shoes - Ratchet vs Lace-ups
dillonko
Wed Mar 13, 2013 4:16 pm
VMac View the latest post
There are no new unread posts for this topic. Homemade Hubset Project. Ratchet ring question
swimmingskibble
Thu Oct 18, 2012 7:13 am
WMW View the latest post
There are no new unread posts for this topic. Campy UT Crank Cult Bearings - Replace or just re-grease.
JWolf
10
661
Sat Aug 04, 2012 9:03 am
Mattias Hellöre View the latest post
This topic is locked, you cannot edit posts or make further replies. dt swiss 240s freehub
ColnagoJohn
Tue Mar 05, 2013 1:59 pm
maverick_1 View the latest post
It is currently Thu May 23, 2013 7:59 pm
