Post new topic Reply to topic  [ 5 posts ]
PostPosted: Sun Feb 24, 2013 5:48 pm
When set to imperial measurements when it reads for example 16.09 lbs does that mean 16 pounds 9 ounces or is the .09 a decimal proportion of a pound? (i.e. 0.09x16ozs)
many thanks
Mike
PostPosted: Sun Feb 24, 2013 11:09 pm
Park tool's scale measures in pounds-ounces. A reading of 16 09 would be 16 lbs and 9 ounces, so an ounce over 16 1/2 lbs.
CAAD10: viewtopic.php?f=10&t=107612
PostPosted: Sat Mar 02, 2013 11:10 pm
Hmmm...you sure about that? So if the scale shows a reading of 1.54, that would equate to 1lb and 54oz...or 4.375lbs?
PostPosted: Sun Mar 03, 2013 1:11 am
If it reads 1.54 you must have it set for kg. I have a DS-1 and am just confirming the measures. But it started giving erratic readings (a different reading each time you weighed exactly the same thing). Replaced the batteries and same thing. Finally gave up and got a different scale. I liked the scale and it seemed fine and I still have no idea why it went wonky. It wasn't abused, and hardly got used. Maybe it was just a freak fault but it was out of warranty so I replaced it with a different scale.
My Colnago C59
My Special Colnago EPQ
PostPosted: Sun Mar 03, 2013 1:22 am
trial end error it. see what it is in metric then convert it, should have your answer 50/50.
Dogma 6650g
Users browsing this forum: carbon337, Majestic-12 [Bot] and 75 guests
There are no new unread posts for this topic. SRM zero offset value, off the scale.
coureur1
Wed Mar 06, 2013 3:45 am
Squint View the latest post
There are no new unread posts for this topic. recommend me a <$20 scale for weighing parts
odin99
Sun Mar 03, 2013 4:05 am
vwo05 View the latest post
There are no new unread posts for this topic. NeilPryde Bura SL Frame on scale
mastaYD
10
1242
Mon Mar 11, 2013 5:58 am
NWSAlpine View the latest post
There are no new unread posts for this topic. New red question
Koballa87
Sun Jun 03, 2012 10:24 pm
Koballa87 View the latest post
There are no new unread posts for this topic. Campagnolo pro fit plus - question
paengn
10
639
Thu Aug 30, 2012 2:28 am
eugkim View the latest post
It is currently Fri May 24, 2013 9:06 pm
