Revised Scott Foil?
Omiar
by Omiar
Foil is a great frame. I ride it with 60mm carbon clinchers daily. Just hammered it in a tailwind 45kph the day before yesterday - it sure felt good.
But yes, you don't want to ride it on rough roads for too long with high rear tire pressure.
GaBa wrote:The thing I started noticing is that the front is too high for me (no spacers) and I'd prefer it lower. I'm riding size L with 183cm height and few mm less than 88cm inseam. Was wondering what size you guys ride?
I'm almost the with the same height (184cm) and inseam and I ride a large frame. I ride with one 5mm spacer under the stem. Will see wheter I can go lower, aero wise is my position quite good already.
Foil is marketed as an aero frame and its got a relatively long headtube, so the position is already quite streched out for the rider. Some say its geometry is more like a TT bike one. A high HT probably gives a more comfy position for the average cyclist. While being around 185cm has usually been a height for a L size Scott frame, in case of Foil it seems to me that a M frame gives more flexibility in terms of riding position.
I myself did go -10mm on the stem length to get the handlebar in a much more comfortable position, but im on the lower limit of stem size now. With the size M frame itself being 15mm shorter, I could easily compensate it with a longer stem and not being on the limit. I would also have some more "steering force".
Scott Foil Ultegra Di2
Scott Scale 35 26"
Scott Spark LTD 29" M8000
Zigmeister
by Zigmeister
As an update to my earlier posts in this thread...I switched from a Team version to a Foil 15 Di2 9070. Run Pro Carbon stem/bars with tubulars. The ride is very tolerable since that switch, but stiffness/responsiveness hasn't been compromised at all IMO. Besides the slight weight penalty of about 100gms, which in a race really means nothing when loaded, weighs just at 15.2lbs right now with the current setup.
I also run slightly lower pressure in the tires, 95-100psi F/R. Except the roughest roads..no problem on 50-60mi rides/races. Got two top 5 sprint finishes the past two races on this setup. Still a great bike, and the used market/new market even has come way down on the frame prices. I bought an extra Foil 15 fork on eBay for like $70, just in case...sweet.
jvanv8
by jvanv8
redcard wrote:What do people think of using a Foil 15 as a commuter? Bad idea?
Or how about using the Foil as a garden cart? I've got some weeds I need taken care of and the Foil is a nice looking bike.
:wink:
AX Vial Evo: 4970g
Addict SL : 5235g
My Cycling Blog
Strava: Wayward Cyclist
kulivontot
by kulivontot
Only with lightweights. Ask durianryder.
