Post new topic Reply to topic  [ 5 posts ]
PostPosted: Thu Feb 21, 2013 11:18 pm
Just got my new shoes in. Can anyone give some advice on the setup for these cleats? I got three pairs of screws. Short, Long, and the ones that came with the shoes themselves. Ideally, i'd like to use the mavic screws as those are obviously the correct length. However, I can't since they are rounded like a mushroom on the top and therefore the yellow part of the cleat doesn't sit flat on the black plate. Also, what shims should I use? The 1-R and 1-F fit pretty well, but the pamphlet says it may require the extra shim for the 2012 model. These should be 2013, so i'm not sure. It looks ok without it, but then again, I don't even know where the shim actually goes. Any advice would be great.
PostPosted: Fri Feb 22, 2013 5:09 am
had the same deal with my Huez and Zxellium w/ speedplay. Simple solution- grind down the mushroom part to be flat- (dremel). still plenty of depression for the allen wrench to get into.
PostPosted: Fri Feb 22, 2013 7:26 am
For the shims-
You won't need the thicker shims unless the cleat deforms when tightening it down.
Just make sure the top of the cleat sits flush with the contour of the shoe.
My drawings:
http://www.facebook.com/andrewlivingstonart
My bike:
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=107451
PostPosted: Sun Feb 24, 2013 6:35 pm
I've just got a pair of Zxellium Ultimate and Speedplay pedals myself. At first I mounted my Look Delta cleats (for spinning) using the screws that came with the shoes. Two of the screws snapped and it was not anything near being overtightened. I then, just for fun and to try the Speedplays, mounted the Speedplay cleats using the included screws. No problems at all. And you don't need to use the shims.
Cannondale SuperSix 105 Team Replica: viewtopic.php?f=10&t=85941
PostPosted: Mon Feb 25, 2013 1:50 am
did you use the long or short screws?
Users browsing this forum: Bing [Bot], CarlosFerreiro, darnellrm, Ekorre, Exabot [Bot], Majestic-12 [Bot], Miller, n8davies, Omiar, simnorm and 67 guests
There are no new unread posts for this topic. shoes size Mavic Zxellium vs. Pro road
superb
Mon Mar 25, 2013 7:28 pm
superb View the latest post
There are no new unread posts for this topic. Mavic R-SYS Ultimate release date?
gb103
Sun Mar 03, 2013 5:18 pm
There are no new unread posts for this topic. Mavic decals Cosmic Carbon SLR / Ultimate
bruno2000
Wed Feb 20, 2013 2:21 pm
Juggler View the latest post
There are no new unread posts for this topic. Difference b/w Mavic Cosmic Carbone Ultimate '10, '11 & '12?
Bregne
Wed Jan 02, 2013 11:17 pm
Berk View the latest post
There are no new unread posts for this topic. Help on Mavic Cosmic Carbone Ultimate - Second hand - Fake??
Bregne
Sun Jan 13, 2013 7:59 pm
It is currently Wed Jun 19, 2013 11:53 am
