Post new topic Reply to topic  [ 7 posts ]
PostPosted: Thu Feb 21, 2013 7:33 pm
As per title looking to get rid of the silver on bars and stem?
Dont want to end up messing them up any info would be great :beerchug:
COLNAGO C59 MATT BLACK
VOLVO FH 12 480 BHP
PostPosted: Thu Feb 21, 2013 7:57 pm
Administrator
You could simply get some new bar tape and re wrap your bars a bit further up. leaving just a few cm. of the LTD silver visible. the other option is to start sanding or shaving your bars and then relaquer them.
Follow me on twitter. I try to be interesting ;)
On Facebook!
PostPosted: Thu Feb 21, 2013 8:00 pm
If by sanding or shaving can you damage the carbon if you go to far?
VOLVO FH 12 480 BHP
PostPosted: Thu Feb 21, 2013 8:10 pm
Wet sanding works great.....once you get through the grey and start seeing black dust/water you know you've gone far enough.
PostPosted: Thu Feb 21, 2013 9:02 pm
i think when you factor in the time and loss of resale value on those parts by doing that, you'll be ahead buying a new stem and handlebar and reselling your current ones than by putting in the time/effort/cost of sanding and relaquering your current ones.
2010 Trek Madone: viewtopic.php?f=10&t=115249
2012 Trek SpeedConcept
2012 Trek Cobia
2013 Trek Superfly: viewtopic.php?f=10&t=115542" onclick="window.open(this.href);return false;
PostPosted: Thu Feb 21, 2013 9:04 pm
....hi , usually most paint on carbon will come off if you use a rubbing compound paste which car sprayers use for over spray (car accessories shops stock it)......its a coarse paste and with a bit of elbow grease gets through the paint.or as advised earlier wet and dry and lacquer ....
PostPosted: Fri Feb 22, 2013 9:22 am
btompkins has the message :thumbup:
I work further with a dry piece of cloth to wipe off the surface frequently to see exactly where you still need to sand.
Users browsing this forum: 54x11, Bing [Bot], Exabot [Bot], Google Adsense [Bot] and 48 guests
There are no new unread posts for this topic. Lightest silver metal bar and stem?
CharlesM
Fri Jun 15, 2012 9:45 am
KB View the latest post
There are no new unread posts for this topic. What bars / stem?
mrfish
9
643
Tue Oct 30, 2012 3:12 pm
project3 View the latest post
There are no new unread posts for this topic. 80mm stem and bars
gherkin
Thu Jul 05, 2012 3:55 pm
yeagermeister View the latest post
There are no new unread posts for this topic. Black stem, white bars?
LVGH
10
967
Thu Jan 03, 2013 9:55 pm
Don View the latest post
There are no new unread posts for this topic. Bars to match a Thompson X2 stem?
Snicks
19
836
Tue Nov 06, 2012 2:31 am
whydobearsxplod View the latest post
It is currently Sun May 26, 2013 12:34 am
