Post new topic Reply to topic  [ 12 posts ]
PostPosted: Thu Feb 21, 2013 1:05 am
what should I expect, I cant take how fast the veloflex is wearing out, I do love them, but just cant keep up, please advice friends, thank you
PostPosted: Thu Feb 21, 2013 1:15 am
I used Veloflex Corsa 22 clinchers for two years without a flat. I recently purchased Veloflex Corsa 23, on the first ride I cut the rear tire so severely it had to be trashed. Bad luck, so I bought Veloflex Master 23 for that retro goodness, same thing - cut through the casing on the first ride. The newer Veloflex tires (23mm) seem thinner and softer than the older 22mm versions. Can anyone confirm this?
I've been riding Pro4 Service Course 23mm since late January on the same dirty roads without a problem. What can you expect? Longer life and less road feel, however kind of nice to just plow through rough pavement sometimes :)
Pro-Lite Cuneo
PostPosted: Thu Feb 21, 2013 1:22 am
Tubbie Guru
Hi,
Expect it to wear out the way you use it.
You can do years/ n miles with a single Veloflex tyre. You can also shred it in a day or two....
IOW, I don't think the wear pattern is brand related.
Ciao, ;)
PostPosted: Thu Feb 21, 2013 1:27 am
Tubbie Guru
Hi,
Maybe a bit more accuracy? As in 22mm Veloflex tyres predate 23mm wide ones for starters?
Ciao, ;)
PostPosted: Thu Feb 21, 2013 1:41 am
D'oh. You're right...22, then the 23. Do you have any comments on the construction/rubber?
Pro-Lite Cuneo
PostPosted: Thu Feb 21, 2013 2:05 am
Tubbie Guru
Hi,
One could write volumes on how tyres should not be made.
I can write a book on how lucky we are to still have tyres like these around.
Ciao, ;)
PostPosted: Thu Feb 21, 2013 11:46 am
Agreed. I think you have just been really unlucky. I use veloflex almost exclusively, nowadays (20mm versions mainly). Not puncture proof, but given how cheaply they are available from UK online stockists, they are the best value for money upgrade regardless of how quickly they puncture (on average....I really do think you've just had some local dickheads dropping glass).
Used to race....got too wrinkly and old ;) Updated: Racing again! Thought this was unlikely! Eventually, I may even have a decent race!
PostPosted: Thu Feb 21, 2013 12:05 pm
@digitalnorbs
The Pro4 Endurance is the replacement for the Krylion. This tyre is more like a Conti 4 Seasons. Durable, v.good puncture protection but will not roll as well as the veloflex or Pro4 SC.
ie not very exiciting for a WW bike.
You need to try the Pro4 SC for yourself. It's the only way to see if they work for you.
Check the "best clinchers" threads to see the huge difference of opinions.
PostPosted: Thu Feb 21, 2013 1:13 pm
Online
In terms of ride quality (and rr I guess) there is no comparison at all. Veloflex is miles ahead.
I agree you had back lack, I found my Veloflex tires rather durable for their weight.
Wilier Cento Uno
Colnago Master X-light
Wilier 18carati
PostPosted: Thu Feb 21, 2013 2:10 pm
Same. I love Veloflex Blacks for their weight and performance and had no flats last year riding them. Think it was a bit of bad luck.
PostPosted: Thu Feb 21, 2013 5:01 pm
OK, got another pair, will kep the veloflex love alive=)
PostPosted: Thu Feb 21, 2013 5:15 pm
Been very "lucky" with Veloflex as well. Rode all last season with Corsa 23 and only one flat (which was my fault when the tire eventually wore through and needed to be replaced). That was on a fair bit of rough roads as well as quite a bit of gravel. I put on a new set of masters and so far so good with similar experience. No flats on those yet.
Users browsing this forum: Bing [Bot], Google [Bot], mpower, Yahoo [Bot] and 50 guests
There are no new unread posts for this topic. Veloflex record, Black sidewalls?
Ruds
Sun Jan 20, 2013 3:20 pm
commfire View the latest post
There are no new unread posts for this topic. 24 mm carbon clincer wheel set
kingkongsfinger
Tue Feb 12, 2013 12:40 pm
kingkongsfinger View the latest post
There are no new unread posts for this topic. ax lightness endurance
dierix
Sun Jul 29, 2012 11:56 am
sungod View the latest post
There are no new unread posts for this topic. Veloflex Master 23
mriddle
9
1083
Tue Jul 10, 2012 11:22 am
fdegrove View the latest post
There are no new unread posts for this topic. Evo CX v Evo SC v Veloflex Corsa
finner
Fri Jun 15, 2012 10:41 am
finner View the latest post
It is currently Wed May 22, 2013 11:05 am
