Post new topic Reply to topic  [ 8 posts ]
PostPosted: Tue Feb 19, 2013 5:00 am
PK01T Model
Spec is 162g
$260
I wonder if they use durable that some people comment
http://www.hti-pedals.com/ht_portal/pro ... tCname=pro
PostPosted: Tue Feb 19, 2013 10:56 am
More people would ride these if they didn't achieve the low weight by using a DU bush against a Ti spindle. Like Exustar and others that use the same basic design, they will have too much drag and wear at an increasingly alarming rate once the TiN coating on the spindle is worn away. Sadly, the TiN loss takes about 2 rides......and the pedals need the bin within a year. By that reckoning, you are better off with a set of Time ULteams......about 10g heavier but last such a long time and have a very low drag/bearing resistance design.
Used to race....got too wrinkly and old ;) Updated: Racing again! Thought this was unlikely! Eventually, I may even have a decent race!
PostPosted: Tue Feb 19, 2013 3:19 pm
sorry to hijack thread ,What do you think of the Time Xpresso 12 Titan Carbon Pedals ?
http://www.motomatt.com/?p=3831
http://gallery.motomatt.com/v/My+Mountain+Bikes/Trigon+MQC05+Full+Carbon+Bike+15lb+89oz/IMG_1893.JPG.html
http://www.strava.com/athletes/motomatt
PostPosted: Tue Feb 19, 2013 4:25 pm
Searching "Xpresso" would have returned this thread: viewtopic.php?f=3&t=111827
PostPosted: Tue Feb 19, 2013 5:22 pm
Estelja wrote:
Searching "Xpresso" would have returned this thread: viewtopic.php?f=3&t=111827" onclick="window.open(this.href);return false;
I wanted to get theremery's opinion.
PostPosted: Tue Feb 19, 2013 5:50 pm
I always wondered why more weight weenies don't go with Bebops. Cromo pedals plus titanium replacement spindles comes in around $150 and weigh the same as Speedplay Nanogram Zeros. I guess they're not for people that don't like floaty pedals, but they sure hit the sweet spot for price:weight:performance. Good quality bearings too, none of this durant bushung nonsense. The big thing though is that I don't have to have two different sets of pedals for my bikes--they're light and solid enough for race pedals, and cheap and walkable enough for casual bike shoes.
The one thing that the HT pedals have going for them is that they're LOOK compatible, which means you have plenty of cleats readily available. That durant bushing, though, gives me pause. At that point you might as well just go all out and get those pedals that are just titanium spindles with a durant sleeve.
PostPosted: Wed Feb 20, 2013 7:01 am
Yeah....sorry but I can't comment on the xpressos, or the iClics. I hear the 1st generation iClics are NOT good but know nothing of the xpresso model. The ones I'd recommend are the old RXS if you are on a budget, carbon Ti if you are patient (to get a good pair second hand.....or cheap via NOS, ) or Ulteams for the weight weenies who want to search. Check you don't use them with a pair of "ridged" cleats* (the brass bit can develop a ridge if you run them under constant twisting load if you set them up a bit out of alignment with your natural foot position) but otherwise these pedals last a mighty long time and the Ti spindled ones are light.
[* doing this causes the cleat to make the little u-shaped bars the cleat engages into work loose over time]
PostPosted: Wed Feb 20, 2013 7:47 am
BeBops are AWESOME for MTB or Casual, however to use them for road often means finding an adapter for road shoes, which adds to the weight, or use MTB shoes, which are heavier than road shoes... and this is weight weenies, so... :mrgreen:
But yes, agreed, love my BeBops... on my lockable bike and my MTB.
Exp001
Users browsing this forum: Bing [Bot], Google [Bot], Google Adsense [Bot], handler, maissi, starlet82, VPR, Vuong05, xis and 47 guests
There are no new unread posts for this topic. Best stability cleat pedal
Body
35
2217
Sun Mar 31, 2013 11:03 pm
Body View the latest post
There are no new unread posts for this topic. Looking for a Delta cleat compatible pedal
robncircus
Tue Aug 21, 2012 3:34 pm
giant man View the latest post
There are no new unread posts for this topic. Help to sand Easton carbon components - Logos take off
Naturel
Sat Nov 03, 2012 4:47 pm
Rick View the latest post
There are no new unread posts for this topic. look blade carbon titanium pedal body compatibility...
dallaghan
Mon Aug 06, 2012 2:41 pm
dallaghan View the latest post
There are no new unread posts for this topic. Attachment(s) Exustar Pro carbon Ti pedal (with picts)-SUPER light!
Bianchi10
19
2635
Fri Oct 26, 2012 9:11 am
Kasparz View the latest post
It is currently Wed May 22, 2013 9:14 am
