Post new topic Reply to topic  [ 26 posts ]
Go to page Previous  1, 2
PostPosted: Wed Feb 20, 2013 4:59 am
I can't remember setting up an un-anodized rim tubeless until setting up road tubeless.
Perhaps that is the problem? Un-anodized aluminum reacting with the Stans.
(I have never seen caffe latex corrode a rim like that, even on a road tubeless setup)
My drawings:
http://www.facebook.com/andrewlivingstonart
My bike:
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=107451
PostPosted: Wed Feb 20, 2013 4:37 pm
Those rims are likely aluminum-scandium alloy.
CerveloMikey wrote:
I have a set of DA 7850 Scandium wheels that have zero corrosion.
PostPosted: Wed Feb 20, 2013 5:58 pm
Here's my data points:
WH-7900 TLs = corrosion. Silver, un-anodized rim
WH-7850SL/WH-6700 = no corrosion. Same tires, same quart of stans, same mounting procedure. Both the 7850 SL and 6700 have a black anodized finish on the rim bed, and show no corrosion.
PostPosted: Wed Feb 20, 2013 7:50 pm
aaric wrote:
Here's my data points:...WH-7900 TLs = corrosion. Silver, un-anodized rim...
I have these as well, also used Stan's 1-2 oz. My experience is some discoloration but no real loss of metal. Changing out the Stan's and cleaning the rim occasionally can't hurt.
2011 Tarmac Pro SL3 Project Black (gone but not forgotten)
2012 Parlee Z5 SLi (just because)
PostPosted: Wed Feb 20, 2013 9:20 pm
The trouble I run into is: what's a suitable alternative?
I've had very poor luck with cafelatex doing an effective job @ sealing. I'm also a skeptic of orange seal when it comes to high pressure: when I ran it in a MTB tire, it didn't seal holes that stan's would no problem.
Those on road tubeless: what sealant would you recommend?
PostPosted: Thu Feb 21, 2013 8:17 am
Dura Ace + Stan's = bad idea, stans ate my rims
Dura Ace + Hutch Fast'air = read somewhere that this is the only sealant Shimano recommends, cant find the reference now. doesnt work as good as stans though
Dura Ace + Cafe Latex = better, although i read that some people still had pitting. unsure if this was caused by Stan's before the users switched.
Fulcrum 1 + Stan's = no issues experienced personally
http://www.roadiemanila.com
*duplicate post*
PostPosted: Mon Feb 25, 2013 8:52 pm
Has anyone else noticed that Stan's NOTUBES is located in thw town of Big Flats (New York)?
http://www.notubes.com/ContactUs.aspx
PostPosted: Mon Feb 25, 2013 9:04 pm
Years ago ironically my car completely shut down on the highway passing by Big Flats. One moment I'm doing 60 mph the next I'm coasting into the side of the road.
PostPosted: Mon Feb 25, 2013 9:56 pm
Fwiw running 2 sets of zonda's tubeless for 2 year w a bit of stan's, not enough to plug a hole but just enough to get a good seal. My zondas have the black ano inside. So far so good, but I'll prob check more regularly after seeing this. Also running fusion 3's.
PostPosted: Sun Mar 03, 2013 9:53 am
Leonard Zinn wrote about this issue a couple of years ago at VeloNews- I don't have the link handy, but if you search the site, you'll find the article. As I recall, although he didn't say so in so many words, the only sealant that he recommended is CaffeeLatex.
My personal experience- I bought a pair of DA 7850 c24's on the auction site oh, maybe 18 months ago. They came mounted with Tubeless Fusions and the Stan's sealant conversion kit (the wheels were the CL's- so 3 layers of Stan's tape and Stan's sealant installed). It was not one of the best purchases that I've ever made on the 'Bay- one of the tires started leaking sealant as soon as I pumped it up, so I decided to unmount the tires and install regular clinchers and tubes; I was quite dismayed at the amount of corrosion on the rim bed, and even the spoke nipples had a little ball of corrosion on top of each nipple. Not quite as bad as CerveloMikey's photo, but real close. I cleaned up the rims with a green scotch pad and some alcohol, and inspected the clincher bead closely, and decided that they were safe, and rode them for several months, but I was never quite comfortable on them- they're sitting in my garage now.
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
Users browsing this forum: Anders, Monkeyboy3333, Yahoo [Bot] and 93 guests
There are no new unread posts for this topic. Tires blowing off Stan's Alpha 340 rims
[ Go to page: 1, 2, 3, 4 ]
WMW
59
4738
Sun Nov 11, 2012 10:38 pm
spandexboy817 View the latest post
There are no new unread posts for this topic. Stan's ZTR Alpha 340 V2.0
Mackers
9
1516
Thu Jun 07, 2012 6:22 am
shadwell View the latest post
There are no new unread posts for this topic. Stan's tube sealant
sungerdds
Fri Oct 19, 2012 2:46 am
Getter View the latest post
There are no new unread posts for this topic. Veloplugs or Stan's on Shimano RS80's
btompkins0112
19
957
Thu Sep 06, 2012 12:10 pm
btompkins0112 View the latest post
There are no new unread posts for this topic. Shimano 35mm carbon tubular rims as rims only ?
LouisN
Fri Jun 29, 2012 2:24 pm
LouisN View the latest post
It is currently Tue May 21, 2013 9:19 pm
