Post new topic Reply to topic  [ 44 posts ]
Go to page 1, 2, 3  Next
 Post subject: hand pump after a flat
PostPosted: Mon Feb 18, 2013 5:13 am
Have you all been wondering after a flat, you use your hand pump to re-inflate, what psi you will get?
I did a simple test at home. Fully un-inflate the air from the tube. pump with lezyne road drive till my arms get tired and give up, use a digital pressure gauge and i only get 50psi - pump 120 times. Rest for a while, pump another 20 times till i tired and i only get 56psi.
My conclusion is to bring a CO2 systems :lol:
PostPosted: Mon Feb 18, 2013 5:43 am
Or you could use a better pump: http://www.topeak.com/products/Pumps/Ro ... _framesize
PostPosted: Mon Feb 18, 2013 6:00 am
Great info. Thanks for taking the time to post this!
PostPosted: Mon Feb 18, 2013 8:04 am
You gave up after 140 pumps?!?!
Exp001
PostPosted: Mon Feb 18, 2013 8:21 am
hand pumps suck. the only reason I bring one is to partially inflate the tube so I know it is not pinched, then I use C02 (carry two cartridges just in case the first one fizzles). some people blow into the tube instead of using a hand pump...I never was good at that
PostPosted: Mon Feb 18, 2013 9:05 am
I use a Lezyne Carbon Drive, it is small, compact and has an inflator hose that allows you to inflate tyres without pressure on the valve stem.
I swapped to this from CO2 cartridges as it is LIGHTER than a single cartridge and control valve. Also can be used multiple times. On long solo rides it means carrying less weight with the ability to deal with more than 1 flat. An extremely rare occurrence, but sometimes when bad luck strikes it seems to do so in a big way.
The Lezyne seems to pump up to 110 Psi pretty easily. About 100-120 pumps and you are ready to go.
Might take a minute or two longer, but nothing significant.
Ozrider - Western Australia
Parlee Z5 XL 2011 (6055g/13.32lbs) Raleigh RC Ltd 2008 (7.6kg) Reynolds 653 Custom 1990 (9.8kg, now 8.8kg)
The accumulation of marginal gains is what makes the difference between winning and losing
PostPosted: Mon Feb 18, 2013 9:32 am
my lezyne after 120 pump feels very hot 160 pump can feel the heat.
My suggestion to you all is uninflate your tube, use your hand pump, if you do not have a digital gauge, use a floor pump with meter to check.
agreed with "pdmtong" suggestion.
PostPosted: Mon Feb 18, 2013 10:13 am
Online
I carry a Lezyne Pressure Carbon Drive - it's very compact and fits in a jersey pocket. Using a digital pressure gauge at home, I have tested it to achieve 90psi in 200 strokes. Not too bad.
PostPosted: Mon Feb 18, 2013 10:33 am
as above, the lezyne cf one, i got the add-on pen gauge as i'm useless as estimating pressure from pinching the tyre
the metal end on the pump does get very hot, especially in warm weather, i wet my mitt to help cool it, or if i'm not in a hurry just enjoy the scenery while it cools down a bit
PostPosted: Mon Feb 18, 2013 10:51 am
With a toppeak master blaster, I reckon I can get close to 80psi on first go, and 100 on the second if I want to.
They really are very good pumps, and the reason you only see old skool riders using them is because they know what a proper frame length pump can do. All the new riders with co2 cartridges don't know, thus don't understand :P
And a frame length pump costs $0 per inflation after buying the pump :) (Just don't give it to your mates to use to pump up, for sure they will bend in backwards if given the chance. I'd rather pump the mates tube up than risk them breaking the pump due to hopeless pumping skillz)
Cheers,
metal
PostPosted: Mon Feb 18, 2013 10:58 am
No way can any of the Lezyne minipumps hit 110psi easily.
It takes a lot of effort to get to 90-95psi, but it's doable. They are good pumps.
The problem is it's slow. It's ok if it's a solo training ride with nothing to rush back for, but for some of us every 10 minutes is precious.
PostPosted: Mon Feb 18, 2013 12:50 pm
It takes about 160-180 pumps to reach 100 psi on my lezyne road drive cfh. After that it's still very little effort to get higher pressures.
Wouldn't give this pump up ever. :beerchug:
    2011 Cannondale Flash F1
      2010 Cannondale Caad9
        2000 Cannondale Caad 4 aero
          1999 Cannondale Caad1
            ???? Concorde SS
PostPosted: Mon Feb 18, 2013 1:07 pm
Came to this conclusion some time ago. Although I never tested what sorts of psi I was getting per amount of time with a hand pump, I knew I didn't like the results or the space a hand pump was taking up. Switched to CO2 and never looked back. I don't get a lot of flats, so ymmv, but even if I got more than a couple a year is still stick with CO2.
On the pinching thing, I'm able to do a small burst of CO2 to check for pinching etc and, if I'm satisfied, finish inflation. Doing that I find still inflates the tire enough, although I often have an extra cartridge and tube.
PostPosted: Mon Feb 18, 2013 2:09 pm
That's ridiculous. The Specialized 4 Force pump does easily in under 50 pumps.
Tip: pump the tire when it's off the frame.
PostPosted: Mon Feb 18, 2013 7:00 pm
Not sure about all this hand pumping....... :lol:
Post new topic Reply to topic  [ 44 posts ]  Go to page 1, 2, 3  Next
Users browsing this forum: Alexa [Bot], CSKeller, Exabot [Bot], Google Adsense [Bot], kyng, tommasini and 48 guests
There are no new unread posts for this topic. Second hand Dura Ace Di2 v Ultegra Di2
Roark
11
1556
Mon Jul 09, 2012 8:37 am
Tinea Pedis View the latest post
There are no new unread posts for this topic. Servicing Shimano 105 8-speed (right hand) shifter
the_marsbar
Wed Dec 19, 2012 8:32 pm
the_marsbar View the latest post
There are no new unread posts for this topic. Help on Mavic Cosmic Carbone Ultimate - Second hand - Fake??
Bregne
Sun Jan 13, 2013 7:59 pm
superb View the latest post
There are no new unread posts for this topic. My Custom Hand Made in Italy Sarto Cima Coppi 820gr Frame
MOTOMATT
34
4024
Sat Dec 08, 2012 4:38 am
MOTOMATT View the latest post
There are no new unread posts for this topic. last tubular flat?
Monkeyboy3333
20
1059
Mon Apr 15, 2013 3:45 pm
bjorn240 View the latest post
It is currently Thu Jun 20, 2013 4:47 am
