Post new topic Reply to topic  [ 5 posts ]
PostPosted: Sun Feb 17, 2013 10:25 pm
I wrongly order a front shimano caliper for my TT rig and actually need a rear. Anyone know where I'd get a pivot bolt shown in shimano tech doc's?
Key:
Front (highlighted blue)
Rear (highlighted yellow)
PostPosted: Sun Feb 17, 2013 10:33 pm
Probably easier to cut the bolt down and put a thread on it.
PostPosted: Sun Feb 17, 2013 10:40 pm
surely someone sells a Ti version and then I can save weight at the same time (this is WW after all!) :thumbup:
PostPosted: Mon Feb 18, 2013 12:49 am
Toronto Cycles sells Ti bolts for Shimano calipers. I have a set of 7800s tuned with them.
If you are not mechanically inclined you will find disassembing and reassembing the calipers less than enjoyable. Especially if you like working brakes. If you're a reasonably good mechanic they're not difficult.
I use small locking pliers to unhook the return spring without scratching the calipers.
PostPosted: Mon Feb 18, 2013 1:18 am
eric wrote:
If you are not mechanically inclined you will find disassembling and reassembling the calipers less than enjoyable.
For the OP, also take note of item 7 as that is a very small bearing race with micro sized bearings. I took apart a set of DA 7900 to try and find a way to make them expand a tad wider for Zipp Firecrests and was surprised when a bunch of sub ~1mm diameter ball bearings suddenly spilled out and rolled across the workbench.
Users browsing this forum: addictR1, FIJIGabe, Kayrehn, MixMastaPJ, mvacolnago, rijndael, VMac and 64 guests
There are no new unread posts for this topic. DA rear caliper on the front?
wassertreter
Sat Sep 08, 2012 4:53 am
oysters View the latest post
There are no new unread posts for this topic. Strange noise in front brake caliper/cable
Burning Dogma
Sat May 26, 2012 6:27 pm
madmole View the latest post
There are no new unread posts for this topic. Front/rear brake choice...
mdeth1313
Fri Nov 23, 2012 8:48 pm
mdeth1313 View the latest post
There are no new unread posts for this topic. Shimano Ultegra SL front and rear derailleur bolts size
cryfish0816
Mon Jun 11, 2012 10:27 am
cryfish0816 View the latest post
There are no new unread posts for this topic. 7900 Front caliper pivot bolt damaged. Replacement options?
racermech
Tue Sep 18, 2012 1:18 pm
It is currently Wed May 22, 2013 4:29 pm
