Post new topic Reply to topic  [ 16 posts ]
Go to page 1, 2  Next
PostPosted: Sat Feb 16, 2013 8:17 pm
Hi Guys, I'm looking for a bit of help setting up my Sram Red Rear deralleur.
The Screw Limits seems to be fine (did the adjust acording with the sram manuals), b-limit screw also (setting up for get a 6mm distance), the longitude of the chain is also correct (acording with sram manuals), Im running it with a sram red 11-26 cassete with 2000 miles
The problem is if I adjust it with the chain in the big ring for a perfect out of noise in all the cogs setting, as soon as i put the chain in the small cog it seems to be fine in the cogs between 11 to 19, but when I try to put 21-23-26 it makes noise and have a hard time going up between cogs,, so puting more tension in the wire it fix the problem, but ... when i Put the chain back in the Big Ring now i have noises with most of the cogs.
Long History Short, adjusting the wire tension for dont have noises in the small ring makes the chain sound when I use the big ring and viceversa... teoricly if you setup it in the small or big ring, should keep the settings in both rings.
Any ideas?
Thank u in advance
PostPosted: Sat Feb 16, 2013 8:39 pm
i had a similar situation, and replacing the cable and housing fixed it...there was just enough drag in the housing that it wouldn't work through the entire range. cable tension adjustments moved the problem, but new cable and housing fixed it.
PostPosted: Sun Feb 17, 2013 1:12 am
Check for bent derailleur hanger. If you don't have the tool have a dealer do it.
For certain parts stiffer is more important than lighter.
PostPosted: Sun Feb 17, 2013 5:12 am
Yes bent derailleur hanger is a possibility and check for worn jockey wheels.
Also for any situation like this if your chain is worn you are wasting your time trying to eliminate mysterious drive train noises.
swinter wrote:
Mr.Gib got it right
PostPosted: Sun Feb 17, 2013 5:19 am
A primary reason there have been suggestions regarding the hanger is because of what happens to the cage position/orientation when in small vs large chainring.....that rotational/position change impacts the pulley positioning and therefore can result in a magnification of problems when the hanger is out of alignment.
PostPosted: Sun Feb 17, 2013 3:24 pm
Ty guys for the help im receiving the deralleur hanger tool tomorrow will check if the alingnement is correct
Regards
PostPosted: Wed Feb 20, 2013 5:09 pm
Ok Guys, checked the deralleur hanger with the tool and was a bit bend,
Now is working better that before but is still not perfect.All the Wires are new (alligator i-link)
Could be a problem of the last segment of wire between frame and deralleir that is a big long-short? have u got any formula or tip for know the exactly meausre of this segmet?
Thank u again guys for the help
PostPosted: Wed Feb 20, 2013 5:33 pm
From my setups the red rear dr likes a larger rear loop than most.
PostPosted: Wed Feb 20, 2013 6:02 pm
Just thought of something - what chain are you using? I have found the quietest set up on a SRAM Red cassette is with a SRAM 1091R chain.
swinter wrote:
Mr.Gib got it right
PostPosted: Wed Feb 20, 2013 8:53 pm
What frame are you riding and does it feature internally routed cables?
If you have accidentally crossed the cables then it will definitely cause this problem.
(Common problem on the Specialized Venge, SL4 Tarmac, and Roubaix frames I have built up)
My drawings:
http://www.facebook.com/andrewlivingstonart
My bike:
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=107451
PostPosted: Wed Feb 20, 2013 9:17 pm
Hi, I believe your problem is the Alligator I-Link cables. I too tried the cables on Sram Force and the rear D does not shift as well as with normal cables. It's not as bad as yours but I can tell it's clearly not as crisp I believe it is due to the inner liner of the I-Links being a tad compress-able (spongy). Btw I'm using the 4mm shifter specific I-Links.
This problem is only visible in the rear D due to the short indexing. I recommend you switch back to normal cables for the rear and see how it works out.
I have not switched mine out yet as it is tolerable. But I will definitely use normal cables next time.
"It doesn't get easier, you just go faster"
http://bb2stem.blogspot.com.au/
PostPosted: Wed Feb 20, 2013 10:10 pm
even if the cable is new, if the housing is not new, or the rear loop is too tight (as someone else mentioned), it could def. cause this issue.
PostPosted: Wed Feb 20, 2013 10:38 pm
Great info here. I can remember going through these issues years ago and figuring it out by buying all new parts one by one within a few days. swapping them out I could see the effect each change made. Needles to say you start to appreciate keeping an eye on chain wear, der hanger alignment, cable routing... once you realize you can fix it and what to look for it's way less of a pain. The red rear der is great. Good luck!
PostPosted: Wed Feb 20, 2013 10:49 pm
As mentioned these red rear derailluers are sensitive to the cable housing loop and actuall brand of cable. I use the Yokozuna cables and they work great on SRAM red.
PostPosted: Wed Feb 20, 2013 11:15 pm
Ok Guys ty for your help, I think is fixed finally.
Just for clarify , I was using a new KMC SL 10v Chain + Sram Red 11-26 (2010 Cassete), the frame is a Fm066SL with internals wires and Ilink Alligator.
As Lwrncc suggested i replaced the last I-link segment (between frame and rear derailleur) with a segment using the original sram red wires (i think are gore-on) also a bit shorter (like 1cm less) and now is working perfectly, i think the problem was that the ilink is not stiff-rigid enought
Many thanks for the help guys, you rock!
Post new topic Reply to topic  [ 16 posts ]  Go to page 1, 2  Next
Users browsing this forum: CBJ, crimsonbadger, eric and 55 guests
There are no new unread posts for this topic. Attachment(s) My Lightweight rear hub has a problem...
CarpetFibre
Thu Jan 17, 2013 10:16 pm
Steve_W View the latest post
There are no new unread posts for this topic. Campy 11 Rear Shifting Problem
goldmine848
11
626
Fri Sep 21, 2012 2:43 pm
edmundo View the latest post
There are no new unread posts for this topic. Problem: New Sram Red 2013 brakes setup
poppiholla
10
987
Fri Dec 21, 2012 8:12 am
refthimos View the latest post
There are no new unread posts for this topic. Sram Red Rear Derailleur tuning
NiFTY
Sat Jul 28, 2012 1:18 pm
NiFTY View the latest post
There are no new unread posts for this topic. Sram rear derailleur issues
boolinwall
9
370
Fri May 24, 2013 1:25 am
It is currently Fri May 24, 2013 1:37 am
SRAM Red rear derailleur
