Post new topic Reply to topic  [ 5 posts ]
PostPosted: Fri Feb 15, 2013 3:05 pm
I want to rebuild an Easton rear hub with what ressembles the most to an Easton EA90 aero wheel.
From what I measured, the rim has a 33mm profile.
I only find some Mavic 33 rims, with 28/32h configuration. Nothing else... :noidea:
Anyone has an idea ?
Only options I know so far now is Kinlin XR 380, or AM Classic 420.
Louis :)
http://www.ccsalma.com
PostPosted: Fri Feb 15, 2013 5:16 pm
Ok just took a micrometer to kinlin xr300 and an Easton ea90.
Xr300 was 31.48
Easton was 32.28mm
Can't you make that work?
If you have to, couldn't you get 16mm nipples to make up any slight difference in spoke length?
I am assuming you are wanting to re use the spokes...
TIME RXR
PostPosted: Fri Feb 15, 2013 6:47 pm
Thanks for the information Gregorio,
Yes ideally, I'd like to use the same spokes.
I didn't know the XR 300 was that much above 30mm.
Do you have the ERD of the rims ? Maybe it could work.
I don't think longer nipples make for stronger build though.
Louis :)
PostPosted: Fri Feb 15, 2013 9:39 pm
I got this from the BHS
Btw this was for the rear ea90 sl aero. The front is suppose to be 28mm deep.
Easton's website says 32mm
With a depth of 30 mm, the Kinlin XR-300 is an aerodynamic rim with extraordinary stiffness, but with very little weight penalty.
Weight:      465 grams
Width:        19 mm
Depth:       30 mm
Drillings:   16, 18 (black only) 20, 24, 28, 32
Color:        Black and Silver
ERD:         577
Price: $42.95
Edit
I think Easton uses an xr270 front and an xr300 rear. I think you will be golden. Easton doesn't make the strongest wheels anyway... Go with a longer BRASS nipple if need be and report back.
TIME RXR
PostPosted: Fri Feb 15, 2013 9:44 pm
577mm is what I measured to be as well.
www.thecycleclinic.co.uk
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 41 guests
There are no new unread posts for this topic. Question about fitting after market fork to a frame
veloman
Thu Jun 28, 2012 6:57 am
michel2 View the latest post
There are no new unread posts for this topic. New weight weenie pedals on the market- Ultralite Sports
[ Go to page: 1 ... 9, 10, 11 ]
thprice
154
11188
Tue Apr 16, 2013 1:50 pm
Fuchspk View the latest post
There are no new unread posts for this topic. 30mm 18h aluminium rim
Rob81
Sun Feb 17, 2013 9:21 pm
GonaSovereign View the latest post
There are no new unread posts for this topic. Polishing an aluminium stem
GASer
12
791
Sun Nov 11, 2012 11:26 am
User Name View the latest post
There are no new unread posts for this topic. aluminum or aluminium bike thread???
tigoose
Tue Aug 14, 2012 4:58 am
tigoose View the latest post
It is currently Sat May 18, 2013 2:46 pm
