Post new topic Reply to topic  [ 13 posts ]
PostPosted: Thu Feb 14, 2013 5:01 am
Guys i have a question, my stupid lbs ordered me the wrong size sram cassette. Instead of 11-26 they ordered 11-28
I ride mostly flats with little elevations, and my crank is standard not compact.
Should i keep it or shud i wait for 11-26? Are they much difference? Thankyou
PostPosted: Thu Feb 14, 2013 5:12 am
Your lowest end (hardest) gear ratio is still the same, only difference is that you will find your riding lower down the cassette more frequently than with the 11-26.
Consider 12-23 cassettes if you really don't climb that much.
Norwood & Adelaide Uni CC
PostPosted: Thu Feb 14, 2013 5:25 am
I would get what you asked for.
PostPosted: Thu Feb 14, 2013 6:59 am
No reason for anything higher than 23 if no serious hills are around. have them get you 23 or 25b as you originally ordered
Racing and Training Cycling Tires
www.tiremaniacs.com
PostPosted: Thu Feb 14, 2013 7:00 am
Save 20g, get the 26
PostPosted: Thu Feb 14, 2013 4:18 pm
For what it's worth, here are the gear spacings for both:
11-26 : 11, 12, 13, 14, 15, 17, 19, 21, 23, 26
11-28 : 11, 12, 13, 14, 15, 17, 19, 22, 25, 28
The big difference is when running in the biggest three cogs (bigger jumps between gears). If you are running in those gears frequently, then yes, there is a difference. If not, just go with what you've got.
2010 Trek Madone: viewtopic.php?f=10&t=115249
2012 Trek SpeedConcept
2012 Trek Cobia
2013 Trek Superfly: viewtopic.php?f=10&t=115542" onclick="window.open(this.href);return false;
PostPosted: Thu Feb 14, 2013 6:35 pm
28 is heavier. My vote is 11-23 or 12-25.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Thu Feb 14, 2013 10:22 pm
Get the one you wanted. I live for climbing and hit up mountains multiple times a week and kicked myself when I had a 28 as I never used it (non-compact 53-39 up front). I have the 11-26 now and even now the 26 rarely gets dirty except on stuff like this.
You'll be glad you did.
PostPosted: Fri Feb 15, 2013 7:42 am
If you ride mostly flat, go with 11/23. Gives you the least amount of change between shifts and allows you to dial in your cadence better. 11/27 is really reserved for at least some elevation. I'd switch it out for sure to 11/25 at the least but would rather go 11/23.
PostPosted: Fri Feb 15, 2013 11:20 am
Compacts and wide ratio cassettes are unnecessary for almost all regularly ridden terrain. An 11-26 with a 39 gives you plenty of gearing for the slopes.
Evo 5.63kg SL3 7.045kg viewtopic.php?f=10&t=110579" onclick="window.open(this.href);return false;
PostPosted: Fri Feb 15, 2013 3:33 pm
It depends on where you live and what you ride. In any case, "conventional" cranks are equally unnecessary. For most terrain either can work. For super-steep stuff compact is nice, especially if you don't feel like riding super-hard (like during my commute home from the train, which peaks @ 24%). But even that I can do 38/28 without too much worry.
Fuji SL/1
PostPosted: Sat Feb 16, 2013 5:48 pm
I would stick with the 11-26. I didn't need to move to a 28 until I began training for serious climbing. The 11-26 has a much more natural spacing too, to me. I've considered moving back to one ... now that I'm stronger. :D
PostPosted: Sat Feb 16, 2013 10:22 pm
The jump between the 19 and 22 tooth cogs on the SRAM 11-28 cassettes is really annoying. I stopped using the cassette after about 2000 kms because I couldn't handle the spacing anymore - I was often wanting something between those two. I'd therefore only consider the 11-26.
If anyone does need an 11-28 cassette, then go with a Shimano cassette instead of SRAM. The Shimanos have 19-21-24-28 as the biggest four cogs instead of 19-22-25-28 on the SRAMs. However, I now prefer a 12-28, with 19-21-23-25-28 at the top in exchange for not having the 11 tooth (just learn to spin at a higher cadence, and you won't need the 11).
Users browsing this forum: bigkraig, Bing [Bot], HammerTime2, Kayrehn, roadieboy, timj and 57 guests
There are no new unread posts for this topic. XG-1090 Questions
lalahsghost
Thu May 31, 2012 8:45 pm
lalahsghost View the latest post
There are no new unread posts for this topic. SRAM 2013 Rings on non SRAM crank?
itsacarr
Tue Jul 03, 2012 3:48 am
boots2000 View the latest post
There are no new unread posts for this topic. upgrade Sram Red 2011 Brakes to the new Sram Red 2012 brakes
poppiholla
Wed Jul 04, 2012 10:20 am
MarkThailand View the latest post
There are no new unread posts for this topic. Sram Red FD with yaw
jrafter
Thu Aug 09, 2012 5:24 pm
seandonovan View the latest post
This topic is locked, you cannot edit posts or make further replies. Sram Red 22
BeeBee30
Sun Apr 14, 2013 1:44 pm
BeeBee30 View the latest post
It is currently Sat May 25, 2013 4:08 pm
