Best brakepads for alloy rims in wet conditions?
mpulsiv
by mpulsiv
TonyM wrote:Looking at Koolstop salmon I see that they offer two versions, a regular "Dura-Type" and a version "Dura2" (for longer life, has a 7.65 mm contact width for narrow rims).
Which one do you use with which rim size??
(my rims have a size of 20mm outside...)
Dura2 was designed for rims with narrow brake track (e.g. Pacenti). If you don't own Pacenti then get Dura-Type salmon pads. They are fantastic, soft compound (doesn't eat your rims), superior performance in wet/dry. I threw my Shimano Dura Ace pads in trash.
TonyM
by TonyM
The contact width refers to the height of the brake track, not the width of the rim. If you have rims with narrow brake tracks, you'll want to get the Dura2s.
Thanks! Right! it is the height!
Will go to my bike and measure now....
1415chris
by 1415chris
Get yourself blue swissstop and forget about any other pads.
sugarkane
by sugarkane
i vote for swiss stops or the koolstop durra2 pads.. the important the thing is the are not the hard stock pads ( except stock sram pads as they are swiss stops ) and that they are kept clean
saeie1
by saeie1
SWISSSTOP Flash Pro Black Prince
During the carbon wheel pads, the brake operation is relatively low and the heat generation is low.
In addition to brake maneuverability, heat generation is not high in thermal friction and in inclement weather conditions.
sib
by sib
I also changed my DA pads for Swiss Stop. It eliminated the irritating pulsing I used to get when braking on my DA C24s. Highly recommended.
DavidMLee
by DavidMLee
Swissstop for alloy rims for one!
Best braking quality in wet conditions.
Legend HT 9.5 RED 22
Colnago C60 Super Record
S-Works Tarmac 2016 eTap
S-Works Tarmac 2015 DA
Cervelo R3 2015 UT
Cervelo S2 2014 UT
Spesh Venge Elite 105
cmcdonnell
by cmcdonnell
Swiss Stop BXP (the blue ones). Best wet weather pads for me
Bianchi Oltre XR2 + Campagnolo Super Record 11 + Campagnolo Bora 50C
Litespeed T1 + Campagnolo Chorus 11 + Campagnolo Shamal Ultra
hongsj
by hongsj
swissstop black is good.
